(25.11.2020 ob 10:15)some1 Napisal: (23.11.2020 ob 11:24)some1 Napisal: Mene pa zanima ali se pri toshibi da videti število defrostov?
Se nobenemu ne sanja? Danes zjutraj pri -7 je bila kar lepo bela zunanja enota defrosta pa od nikjer. Še naprej je šopala s 50% močjo.
Kolikor sem čekiral navodila mislim, da tega prikaza ni ??
Glede zunanje enote najdem le:
60 Heat exchange temperature after PMV (TE) °C
61 Outside air temperature (TO) °C
62 Discharge temperature (TD) °C
63 Suction temperature (TS) °C
65 Heat sink temperature (THS) °C
6A Current consumption inverter A
6D Heat exchanger temperatur in package (TL) °C
70 Compressor operation Hz Hz
72 Number of revolutions of outdoor fan (below) rpm
73 Number of revolutions of outdoor fan (above) rpm 74 Outdoor PMV position x 1/10 pls
ter sumarne podatke....
F0 Operation time micro computer x 100 h
F1 Operation time compressor ON domestic water preparation x 100 h
F2 Operation time compressor ON Cooling x 100 h
F3 Operation time compressor ON Heating x 100 h
F4 Operation time pump 1 x 100 h
F5 Operation time electric heater domestic water tank x 100 h
F6 Operation time backup heater x 100 h
F7 Operation time booster heater
sicer pri meni je bilo letos parkrat pod 0 in le enkrat sem zasledil, da je bila TČ malček "bela". Je pa res, da imamo te dni ko je šlo pod 0 na krasu tudi burjo in suh zrak
