7.7.2015 ob 12:11
Hello
I have source water(probably rain water coming out of the ground), but I need some system for disinfection. I have been told that a system with UV-light is needed. I will start doing some research so that a system can be installed next year.
For the moment, I have the following questions:
- Which companies in Slovenia(or others countries) have reliable systems?
- Is a system with UV-light absolutely neseccary or are there other systems?
- In case of UV-light system, should there be additional filters installed and for what purpose?
thank you
thank you
