  • Glasov: 1 - Povprečje: 5
ZADNJI ODGOVORI ROMUNA...
What is included in the price:
- 3-way valve? – NO – this is part of the each house system – not all systems are the same – not part of IVT heatpump or controller.
- which and how many sensors? – one outlet water temp sensor – all rest will be added for each house according to the needs/ room thermostat, DHW thermostat
- do you have an instruction manual in english? – it is in Romanian now but if we work together i will sent it in English
- is a wiring plan included? YES with pictures and description
- what is the WiFi range (when taking into account reinforced concrete - walls)? 300m line-of-sight /10 m – between 2, 3 walls – depends on the wall.
- delivery date for 20 pcs? – we currently have a 20 pcs order that we will finish by end of next week. If you make the order this week. We will start your order next and we will finish all 20 around December 6.
Moja pumpa gre jutri dopoldan na Prof.El (<!-- m --><a class="postlink" href="http://www.profel.si/">http://www.profel.si/</a><!-- m -->). Pravijo, da rabijo kak dan ali dva, da ocenijo koliko bi krmilje koštalo in kako dolgo bi razvoj trajal. Bilo je tudi rečeno, da če je res tako simpl kot izgleda, bi bila prva rešitev za čimprejšnjo uporabo razvita "zelo hitro".
@csamo001 glede na vse skupaj najbolj pametno. Pa sem preprican, da glede na zelje, ki jih tukaj navajate, komplet regulacija nebo drazja od tiste ki jo ponuja romun. Ce primerjam z regulacijo, ki jo bo Igor naredil meni, kjer bo zdruzil 3 razlicne sisteme, sem skoraj preprican, da bo cifra se nizja od romunove. Pa je izdelek nas, z garancijo, podporo za naprej v primeru dodatnih zelja ali nadgraditve sistema itd. V primeru skupinskega narocila pa verjetno lahko racunate se na dodatni popust.
csamo001 Napisal:Moja pumpa gre jutri dopoldan na Prof.El (<!-- m --><a class="postlink" href="http://www.profel.si/">http://www.profel.si/</a><!-- m -->). Pravijo, da rabijo kak dan ali dva, da ocenijo koliko bi krmilje koštalo in kako dolgo bi razvoj trajal. Bilo je tudi rečeno, da če je res tako simpl kot izgleda, bi bila prva rešitev za čimprejšnjo uporabo razvita "zelo hitro".
Moji predlogi za krmilje:
- gledajo naj temperaturo vtoka in povratka, tako lažje kontroliraš tistih optimalnih dT pod 5°C kar omenja sassapo.
- uporabijo naj tudi senzor zunanje temperature in sprogramirajo krmiljenje po vremenski krivulji in z notranjim senzorjem kot dodatnim nadzorom (za hitro kompenzacijo notranjih dobitkov ali izgub)
- krmiljenje po vremenski krivulji naj ima možnost nadzora (nagib, vzporedni odmik)
- naj predvidijo izhod za krmiljenje grelca SV v bojlerju (logika: če se v nekem prednastavljenjem času SV ne ogreje na želeno temperaturo, se ogrevanje SV prepusti potopljenem grelcu v bojlerju, TČ pa se vrne na hišo). To se lahko zgodi v slabo izoliranih ali velikih hišah, pri zelo nizkih zun. temperaturah ali pri želji po zelo visoki temperaturi SV. Torej naj obstaja možnost nastavitve tega časa in temperature SV.
- kako bo s krmiljenjem OČ: ali naj dela vedno (ko je aktivirana neka kombinacija za moč + na zunanji termostat za zaščito pri nizkih temperaturah) ali naj se to prepusti krmilju.... (sem bolj pristaš trotelziher hardverske rešitve v tem primeru)
(naj še kdo doda kakšen komentar ali idejo, AlanFord jih je že zadnjič nekaj navedel)
Sem naredil kompilacijo tvojih in alanfordovih predlogov in jih poslal Igorju.
Sem govoril s sosedom, ki ima kompletno razvit svoj krmilnik za ogrevanje. Od lotanja proca na PCB dalje.
Seveda je to šala mala. Zgolj droben problem je in sicer se mu reče čas. Bo pa priletel mimo.
csamo001 Napisal:Sem naredil kompilacijo tvojih in alanfordovih predlogov in jih poslal Igorju.
Zelo dobro specificirajte zahteve. To, da v razvoj naročiš samo en krmilnik za TČ, zelo verjetno vodi v razočaranje.
Za SV bi sam dodal podporo za dva senzorja. Spodnji, zgornji. Dve strategije ogrevanja SV, čim hitreje ali čim bolj optimalno (če ne sledi potreba po ogrevanju). kakšen timer oziroma urnike boste tudi verjetno potrebovali. Kakšna nočna funkcija z omejitvijo frekvence oziroma hrupa, če gre za glasno napravo, ...
Danes sem tudi jaz dobil črpalko. Hvala Fery-u za organizacijo nakupa in nekakbošlo ( Klemnu )za prevoz do mojega doma.
Paket sem odprl in notri je bila celo toplotna črpalka. Fery sem pričakoval beli prah od paradajzmafije Smile
Odprl sem pokrov za elektroniko in naredil malce reverz inženiringa in vprašanja ali 24V ali 12V napajanje.
Vhodni del vezja je pod kovinsko ploščico desno zgoraj od glavne plošče s strani.
Odvije se dva vijaka in pridete do vezja ( slika1).
Narisal sem še shemo vhodnega dela ( slika2)
Če imamo 12V napajanje je tok skozi optične ločilnike 5mA. V primeru 24V je tok 10mA.
Maksimalen tok optičnih ločilnikov je ponavadi 20mA. S slik žal nisem razbral oznak optičnih ločilnikov.
Stanje delovanja TČ se javlja preko dveh relejev.Ta dva pa krmili toplotna in ti so 12V. Mogoče je nekdo videl na relejih 12V in je zato prišla informacija , da mora biti 12V.
Moja ugotovitev: Napajalnik je lahko 12V ( če dela Fery-u) do 24V BREZ PROBLEMA.
.jpg   IMG_20181106_171524_L.jpg (Velikost: 50,43 KB / Prenosi: 450)
.jpg   shema vhod IVT_L.jpg (Velikost: 42,88 KB / Prenosi: 449)
cheba Napisal:
Tudi z Igorjem sem se pogovarjal na način, da bi bilo za pravo ceno najbrž kar nekaj interesentov za nakup.
Kar se želja posameznikov tiče sem pri Igorju še najbolj ziher, da se bo znal prilagodit (pač za neko doplačilo). Že pred časom, ko je bil pri meni zaradi hibridne TČ, sva nekak prišla na to, da on dejansko "po meri" dela rešitve. Se mi pa zdi, da tričetrt funkcionalnosti krmilij spada v kategorijo "za vsakogar" in to je ta osnova, ki bi jo blo treba čimprej vzpostavit.
off- ta Igor je kolk pomnim naredil krmiljenje za FWHP 11 ki jo je kupil (samo zunanjo enoto )cca 7 let nazaj en znanec, delal je na marborskem letališču, na forumu je uporabljal nick " gmajnar" .....zadeva vem, da je bila spidenana v nulo, dela še danes, nažalost "gmajnarja" ni več...
Bi znal bit, ker večinoma se "igra" ravno s Fujitsotom.
csamo001 Napisal:
cheba Napisal:
Ker je kar nekaj nas takih, da nas baše čas, se bom rade volje, če bo sprejemljivo, pridružil skupini, da bo povečano število izdelkov ugodno vplivalo tako na avtorja kot na nas kupce. Samo, ali boš ti vodil seznam potencialnih kupcev? Koliko nas sploh je?
Ni vse črno kar je belo.
jaz sem potencialni kupec krmilja...
nimam pa posebnih zelja/potreb, ker bo TC le za ogrevanje.
alanford Napisal:
csamo001 Napisal:Tudi z Igorjem sem se pogovarjal na način, da bi bilo za pravo ceno najbrž kar nekaj interesentov za nakup.
Začnimo na začetku. Če bo Igor postavil sprejemljivo ceno, potem ga vsekakor preferiram pred Romunom. Saj najbrž je Romunov izdelek tudi izpraven, ampak kolikor sem tam razumel situacijo je tisto krmilje nastalo silom prilike, ker Vidrih ni bil sposoben sproducirat tega kar je obljubil in je Romun ostal na 20 prodanih TČ in s kurcem v roki (brez krmilja). Ni Romun oziroma njegov tehnik torej proizvajalec krmilij, temveč je prodajalec ogrevalnih naprav. Kar bo najbrž pomenilo bistveno manjšo prilagodljivost na dodatne zahteve, kar je tako že nakazal v zadnjem mailu. Pa seveda ga nimamo pri roki, pa tujec je, pa angleških navodil še ni, itd.
Igor dobi jutri mojo TČ in predvidevam, da mi bo do petka lahko povedal kolikšna bi bila cena krmilja, ki bi najbrž pokrilo večino zahtev posameznih uporabnikov, ter kakšen bi bil dobavni rok. Poleg tega se profesionalno ukvarja točno s tem področjem in ima že marsikaj razvitega, npr. <!-- m --><a class="postlink" href="http://www.profel.si/produkti/dialog-eq/">http://www.profel.si/produkti/dialog-eq/</a><!-- m -->. Je torej iz foha in točno to kar vsaj jaz od dobavitelja takšne igračke pričakujem.
Če sem prav razumel Fery-ja je tudi njegov sosed pol(profi) in si bo tudi on pogledal kaj lahko skupaj spravi in za kakšno ceno. In spet je prednost pred Romunom to, da ga imamo pri roki in ga lahko za rokav, če bo kakšna težava. Če se še on pohila in nam recimo do konca tedna da neko realno oceno koliko bi krmilje koštalo in kdaj bi bilo perajt, imamo sladke skrbi.
Predlagam, da do petka počakamo kaj svane na vseh treh koncih in potem začnemo zbirat naročila na enak način, kot smo jih za TČ; torej sporočite meni, če ste zainteresirani, da naredim nek seznam, in pridemo do neke cene za "osnovno" krmilje. In da seveda vemo kaj bo sploh v osnovnem krmilju zajeto... od tu naprej, če bo dobavitelj dovolj fleksibilen, pa bi vsak posameznik z njim uskladil še kakšno "srčno željo".
gt001 Napisal:jaz sem potencialni kupec krmilja...
Samo na prejšnji strani smo že 4 interesenti, kolega je vzel na firmo 3 komade TČ in tudi ne bo sam delal krmilja, prav tako som16 ne (sva se včeraj pogovarjala). V bistvu je že v tem trenutku interesa za okoli 10 komadov krmilij, pa verjamem, da marsikomu, če bo le cena prava, tudi ne bo za pocat zadeve skupaj in bo raje naročil narejeno krmilje.
1 ... 73 74 75 76 77 ... 541 Pojdi na stran
