Objave: 5764
Pridružen: Feb 2012
32
Mogoče bi avtorja te naloge kontaktiral. Opis krmilj od 42 strani dalje.
Drugače pa poučna zadeva, vsaj kolko sem na brzino prelistal, predvsem za vse tiste, ki sprašujejo tu gor čisto osnovne stvari.
<!-- m --><a class="postlink" href="https://dk.um.si/Dokument.php?id=67208">https://dk.um.si/Dokument.php?id=67208</a><!-- m -->
Objave: 281
Pridružen: Nov 2008
Fery, daj na mail poglej...
Objave: 16704
Teme: 48
49
Petek dan za metek.
Razen če bo kdo prej štartal iz vašega konca.
Objave: 7905
Teme: 59
Pridružen: Oct 2010
34
ROMUN SE JE JAVIL...
Hello Samo,
We have just one type of controller that has the following specs:
It has WIFI
it works for heating / cooling / domestic hot water
it has a outlet water sensor.
it will control the recirculation pump
you can add a room thermostat
you can add a DHW temp sensor
The price: 250 Euro
The controller is already tested here in Romania on more than 20 pumps – for about 1 year.
As for the specifications it is between the one that at 150 GBP and the one at 350 GBP. – but with better quality parts.
Regards,
Adrian
Objave: 6531
Teme: 76
Pridružen: Mar 2009
Naj pošlje kakšno fotko od tega krmilja pa printscreen od aplikacije (na PCju ali telefonu, če ima podporo na Androidu).
Ali je gor kakšen displej? 3-potnega ventila ni v tej ceni? (sicer je okoli 100€)
Objave: 16704
Teme: 48
49
Moj je 21 €. Z motorjem, da ne bo pomote.
Objave: 2816
Teme: 78
Pridružen: Mar 2008
Link od tripotnega, da kupimo....
Objave: 16704
Teme: 48
49
Podražil se je. Oz. druga firma.
<!-- m --><a class="postlink" href="https://www.ebay.de/itm/2-3-Wege-1-Zoll-230V-Zonenventil-Kugelventil-DN20-DN25-Motorkugelhahn-Ventil/113306418975?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D20161121134654%26meid%3D95b8c8bc1f84494f8022ced611075a20%26pid%3D100506%26rk%3D1%26rkt%3D1%26%26itm%3D113306418975&_trksid=p2045573.c100506.m3226">https://www.ebay.de/itm/2-3-Wege-1-Zoll ... 0506.m3226</a><!-- m -->
Objave: 16704
Teme: 48
49
Pumpe imam te. Iz Ebay-a so jih skinili, ampak se jih še dobi.
<!-- m --><a class="postlink" href="https://merken.at/energieeffizienz-pumpe-25-4-180">https://merken.at/energieeffizienz-pumpe-25-4-180</a><!-- m -->
