PodSvojoStreho.net Gradnja in obnova Napeljave Disinfection source water which systems
Hello Smile
I have source water(probably rain water coming out of the ground), but I need some system for disinfection. I have been told that a system with UV-light is needed. I will start doing some research so that a system can be installed next year.
For the moment, I have the following questions:
- Which companies in Slovenia(or others countries) have reliable systems?
- Is a system with UV-light absolutely neseccary or are there other systems?
- In case of UV-light system, should there be additional filters installed and for what purpose?
thank you
First you need to know what kind of water Will you use..is this a ground water, underground water or rain.
Than you put this water on test (for example: JP Vodovod Kanalizacija d.o.o. Vodovodna cesta 90, Ljubljana -> Laboratory (ask for Mrs. Vlasto Kramarič Zidar). You Will bring sample of water to laboratory. According to results you Will check for appropriate filters (if necessery) and/or UV light.
Well,
the water is coming from a source in the mountains. It has been tested some time ago and it is microbiological contaminated, not much but a UV-light is nessecary.
For now, I need to know which companies are reliable for buying an installation with UV-light. I have heard that some UV-lights are bad quality and are not working well. For this reason I have started up this topic.
<!-- m --><a class="postlink" href="http://www.saw.si/prodajni%20program/uv_montagna.html">http://www.saw.si/prodajni%20program/uv_montagna.html</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.mesec.si/sl/mesec-sistemi-prodajni-program/hisni-sistemi/uv-dezinfekcija-vode">http://www.mesec.si/sl/mesec-sistemi-pr ... kcija-vode</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.bistravoda.si/uv-dezinfekcija/uv-dezinfekcija.html">http://www.bistravoda.si/uv-dezinfekcij ... kcija.html</a><!-- m -->
thank you!
I'll have a look at it.
Anyone has good experience with uv-desinfection of source water?
