Objave: 1973
Teme: 59
Tale moj "strokovno" poimenovan francoski kukerli se lahko narobe tolmači. Imel sem v mislih nekaj takega. So pa podvariante odvisno od tega kaj v koncept paše (moderno, manj moderno, brez balkona z balkonom....
[img]httpunichr("58")//wwwunichr("46")podsvojostrehounichr("46")net/vsebina/sites/all/files/rebrec/Rebrec_01_Enokunichr("46")jpg[/img]
[img]httpunichr("58")//wwwunichr("46")krovstvo-tesarstvounichr("46")eu/tiny_upload/slika1_47unichr("46")jpg[/img]
[img]httpunichr("58")//wwwunichr("46")mldomunichr("46")si/photos/hisa_mitjaunichr("46")jpg[/img]
[img]httpunichr("58")//picbaseunichr("46")turbosistunichr("46")si/slonep_galerija2/ponudniki/gradimo/RihterZaplanaunichr("46")jpg[/img]
Če dopuščajo prostorsko ureditveni pogoji
[img]httpunichr("58")//wwwunichr("46")delounichr("46")si/assets/media/picture/20130408/Deloindom__P3260690unichr("46")jpg?rev=0[/img]
Evo googlaj še sam - za kako idejo
Frčade
<!-- m --><a class="postlink" href="https://www.google.si/search?q=vrste+fr%C4%8Dad&client=firefox-a&hs=ldp&rls=org.mozilla:en-US:official&tbm=isch&tbo=u&source=univ&sa=X&ei=jJ-RUqG8D8uihgfWxoGYDw&ved=0CEkQsAQ&biw=1280&bih=659#q=fr%C4%8Dada&rls=org.mozilla:en-US%3Aofficial&tbm=isch&facrc=0%3Bravna%20fr%C4%8Dada&imgdii=_&imgrc=_">https://www.google.si/search?q=vrste+fr ... =_&imgrc=_</a><!-- m -->
Strešna okna
<!-- m --><a class="postlink" href="https://www.google.si/search?q=vrste+fr%C4%8Dad&client=firefox-a&hs=ldp&rls=org.mozilla:en-US:official&tbm=isch&tbo=u&source=univ&sa=X&ei=jJ-RUqG8D8uihgfWxoGYDw&ved=0CEkQsAQ&biw=1280&bih=659#q=stre%C5%A1na+okna&rls=org.mozilla:en-US%3Aofficial&tbm=isch&imgdii=_">https://www.google.si/search?q=vrste+fr ... h&imgdii=_</a><!-- m -->
Objave: 2654
Teme: 78
Pridružen: Jan 2010
[url=httpunichr("58")//shraniunichr("46")si/?24/EV/17KmMWbn/slika-015unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/24/EV/17KmMWbn/slika-015unichr("46")jpg[/img][/url]
[url=httpunichr("58")//shraniunichr("46")si/?1r/sU/2lya9SdT/1/slika-017unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/1r/sU/2lya9SdT/1/slika-017unichr("46")jpg[/img][/url]
[url=httpunichr("58")//shraniunichr("46")si/?2I/c5/2ps8l7Hx/1/slika-013unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/2I/c5/2ps8l7Hx/1/slika-013unichr("46")jpg[/img][/url]
[url=httpunichr("58")//shraniunichr("46")si/?2Q/1D/3jzjZjEz/slika-012unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/2Q/1D/3jzjZjEz/slika-012unichr("46")jpg[/img][/url]
Objave: 266
Pridružen: Dec 2006
V temi [url]httpunichr("58")//wwwunichr("46")podsvojostrehounichr("46")net/forum/viewtopicunichr("46")php?f=8&t=43614&hilit=zavajanje[/url]
sem opisal svoje izkušnje:
Kupili smo 5 oken.
Zunanje mrežasto senčilo - MHL:
Ker je bilo vroče, smo naknadno kupilo še zunanja senčila. Reklama pravi:
- Učinkovito zaustavi sončno toploto, ohrani pa razgled in svetlobo.
- Zaustavi do 80% sončne toplote.
Jaz od tega znižanja vročine/toplote nisem dosti čutil. Če rečem, da je temp nižja 1, ali 2 C, sem rekel preveč. Tako, da je to senčilo bolj natega, kakor resnična pomoč pri zniževanju temperature v mansardi.
Siesta senčilo
- Senčilo ima na zunanji strani metalizirano plast, ki odbija sončne žarke in tako ustvarja ugodne bivalne razmere.
- Optimalna kombinacija z zunanjim mrežastim senčilom, kjer lahko kontrolirate vnos toplote in svetlobe.
Prostor res zatemni. Ampak ob tem niso povedali, da se na oknu (nad senčilom) zbira kondenz, da nam je kapljalo po oknu navzdol ter nato po obrobi. Pa čeprav smo imeli radiator v liniji okna. Ja rekli boste, da toplota ni sušila okna, ampak saj tega niso omenili, da se okna v primeru montaže senčil ne sušijo. In to me je najbolj razjezilo. Ali pa naj napišejo, da so uporabna le poleti. No, tudi sedaj, ko ne kurimo več, se na steklu nabira kondenz. Tega pa ni, ko senčila ni, in je zrak krožil ob oknu.
Če menite, da smo kaj narobe naredili, svetujte. Ostalim pa v vednost, kaj se jim lahko zgodi z nakupom dodatne opreme Velux, ki je "skoraj" neuporabna ali pa vsaj ni koristna tako, kolikor jo reklamirajo.
Objave: 221
Pridružen: Jan 2013
V mojem primeru glede zunanjih senčil lahko rečem da sem zadovoljen.Razlika je očitna in ni samo 1-2 stopinje,pred montažo senčil mi je priplezal do 29-30c,po montaži pa mi pride do 24.5c,kar se zelo pozna na udobju.Imam pa 6 oken ggu p06 in so poleti obsijana od 8-19h.Se pa strinjam,da je dodatna oprema za okna absolutno predraga!!!
Objave: 12059
Teme: 16
Pridružen: Mar 2009
27
Siesta je super. Sploh za ponoči lol 100% ni zatesnitev. Je pa 99% (odvisno tudi od montaže). Glede vročine... Ni važno koliko je izolacije. Če imaš samo "senčilo" potem bo vroče. Pika.
Objave: 6909
Teme: 51
Pridružen: Apr 2010
-69
Zdejle bom pa malo zaspamala...
Gledam od johana 1 in tretjo sliko - kjer sta dva okna vskupaj, vmes pa špirovec. Tako imamo tudi mi - 4x2 izvedba in me nekaj zanima...
Povsod bo 30cm Urse SF35, bi se dalo tale vmesni špirovec obleči v kaj drugega, da bi bilo manj glomazno. Nekaj sva razmišljala o "astronavtski" foliji - tako so mi v žargonu rekli, najbrž veste o čem govorim. Bi bilo to sporno iz kakeršnegakoli vidika? Zdaj OK, ne bi se prerekali o toplotni izolativnosti po tistem špirovcu v dolžini okna, vzamem v zakup, če je probelm, da bi malenkost več uhajalo tam skozi. Kaj pa kondenz, možnost izvedbe, kake druge težave ali malenkosti pri katerih je treba biti previden? Nekako me "zmoti", da je v tistem vmesnem delu strop toliko spuščen.
Objave: 12059
Teme: 16
Pridružen: Mar 2009
27
Pa ga spusti manj... Doma imam tako narejeno. 30 vse ostalo, "špirovec" pa samo toliko da je gips + par cm izolacije. Tam ti izolacija nič ne pomaga, ker od strani "uhaja" toplota...
Objave: 12028
Pridružen: Oct 2009
Citat: ne bi se prerekali o toplotni izolativnosti po tistem špirovcu v dolžini okna, vzamem v zakup, če je probelm, da bi malenkost več uhajalo tam skozi. Kaj pa kondenz, možnost izvedbe,
Če imaš še možnost, daj izolacijo (stekleno volno) nad špirovec v zračni kanal do kritine (obrobe). Kjer sta okni na vsaki strani špirovca, itak ni zračnega kanala. Nimam izkušnje, se mi pa zdi, da bi moral to vstaviti ob vgradnji okna. Tudi če bo le 5 cm bo več kot nič.
Objave: 10
Pridružen: Jan 2014
strešna okna so super, ker omogočijo toliko svetlobe v stanovanju, da je res fino, ampak je njihova cena, seveda če govorimo o dobrih izvedbah in ne o tistih najcenejših, res prav preveč zasoljena. če dodaš še prava senčila in se poskušaš poleti pred vročino čim bolje obraniti, pa je bolje, da sploh ne razmišljaš več o ceni. Kar se mene tiče, so frčade tako bistveno boljša rešitev, lahko pa frčadam dodaš če lep balkonček in si zmagal
Objave: 1638
Pridružen: Aug 2009
3
@Johan_R
Na slikah pogrešam vodoravno vrhnjo špaleto pri strešnem oknu. Vedno delaš navpično spodnjo in vodoravno vrhnjo špaleto. Na ta način zrak neovirano kroži in ni težav. Pri nas ni niti enkrat karkoli kapljalo ali kaj podobnega.
Glede senčil pa obvezno zunanja. Mi smo dali rolo senčila, ki jih spomladi potegnemo dol in jeseni spet nazaj sicer se počutiš kot v mikrovalovki.
Objave: 12059
Teme: 16
Pridružen: Mar 2009
27
edid... Ne. Sploh. Časi se spreminjajo...
Objave: 1638
Pridružen: Aug 2009
3
@firefly
Kako to misliš, časi se spreminjajo?
