6.11.2018 ob 15:54
ZADNJI ODGOVORI ROMUNA...
What is included in the price:
- 3-way valve? – NO – this is part of the each house system – not all systems are the same – not part of IVT heatpump or controller.
- which and how many sensors? – one outlet water temp sensor – all rest will be added for each house according to the needs/ room thermostat, DHW thermostat
- do you have an instruction manual in english? – it is in Romanian now but if we work together i will sent it in English
- is a wiring plan included? YES with pictures and description
- what is the WiFi range (when taking into account reinforced concrete - walls)? 300m line-of-sight /10 m – between 2, 3 walls – depends on the wall.
- delivery date for 20 pcs? – we currently have a 20 pcs order that we will finish by end of next week. If you make the order this week. We will start your order next and we will finish all 20 around December 6.
