PodSvojoStreho.net Gradnja in obnova Energijski viri Gorilniki na pelete
Katran v peči.
<!-- m --><a class="postlink" href="https://www.google.si/search?q=katran+v+pe%C4%8Di&sa=X&espv=210&es_sm=93&tbm=isch&source=iu&imgil=hk4t9cR-VnY4sM%253A%253Bhttps%253A%252F%252Fencrypted-tbn1.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcRce4ErRGtuGsxlVWJcSdp1KiNHY4rnym02DeEgpKZYFKGFdXXoQA%253B160%253B119%253BvtE5xgihgkwM-M%253Bhttp%25253A%25252F%25252Fwww.podsvojostreho.net%25252Fforum%25252Fviewtopic.php%25253Ff%2525253D7%25252526t%2525253D35300&ei=vGa8UrbaLsXc4QSxuIHwAQ&ved=0CHgQ9QEwCg&biw=1280&bih=704#facrc=_&imgdii=_&imgrc=OgmAnn3kqT1vTM%3A%3BlOb4WE8BIpAALM%3Bhttp%253A%252F%252Fwww.strojnistvo.com%252Fimages%252Fforum%252F1257360020_PB042297.JPG%3Bhttp%253A%252F%252Fwww.strojnistvo.com%252Fforum%252Fviewtopic.php%253Ft%253D23174%2526start%253D15%3B3648%3B2736">https://www.google.si/search?q=katran+v ... 648%3B2736</a><!-- m -->
Katran v dimniku.
<!-- m --><a class="postlink" href="https://www.google.si/search?q=katran+v+pe%C4%8Di&sa=X&espv=210&es_sm=93&tbm=isch&source=iu&imgil=hk4t9cR-VnY4sM%253A%253Bhttps%253A%252F%252Fencrypted-tbn1.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcRce4ErRGtuGsxlVWJcSdp1KiNHY4rnym02DeEgpKZYFKGFdXXoQA%253B160%253B119%253BvtE5xgihgkwM-M%253Bhttp%25253A%25252F%25252Fwww.podsvojostreho.net%25252Fforum%25252Fviewtopic.php%25253Ff%2525253D7%25252526t%2525253D35300&ei=vGa8UrbaLsXc4QSxuIHwAQ&ved=0CHgQ9QEwCg&biw=1280&bih=704#facrc=_&imgdii=_&imgrc=iUkmfUGmMZveCM%3A%3Bme6m6fI24tMu4M%3Bhttp%253A%252F%252Fwww.mko.gov.si%252Fuploads%252Fpics%252Fkatranske_obloge.jpg%3Bhttp%253A%252F%252Fwww.mko.gov.si%252Fsi%252Fdelovna_podrocja%252Fgozdarstvo%252Fnavodila_za_pravilno_kurjenje%252Fzgorevanje_lesa_v_malih_kurilnih_napravah%252Fzgorevanje_lesa%252F%3B300%3B225">https://www.google.si/search?q=katran+v ... B300%3B225</a><!-- m -->
Čistilo za katran.
<!-- m --><a class="postlink" href="https://www.google.si/search?q=katran+v+pe%C4%8Di&sa=X&espv=210&es_sm=93&tbm=isch&source=iu&imgil=hk4t9cR-VnY4sM%253A%253Bhttps%253A%252F%252Fencrypted-tbn1.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcRce4ErRGtuGsxlVWJcSdp1KiNHY4rnym02DeEgpKZYFKGFdXXoQA%253B160%253B119%253BvtE5xgihgkwM-M%253Bhttp%25253A%25252F%25252Fwww.podsvojostreho.net%25252Fforum%25252Fviewtopic.php%25253Ff%2525253D7%25252526t%2525253D35300&ei=vGa8UrbaLsXc4QSxuIHwAQ&ved=0CHgQ9QEwCg&biw=1280&bih=704#facrc=_&imgdii=_&imgrc=laQAQ2SKX1GvPM%3A%3B3qOKBxAj5aWgIM%3Bhttp%253A%252F%252Fwww.france-turbo.si%252Fwp-content%252Fuploads%252F2010%252F03%252Frep-1722.jpg%3Bhttp%253A%252F%252Fwww.france-turbo.si%252Fkatalog%252F1327%252Fodstranjevalec-katrana%252F%3B480%3B640">https://www.google.si/search?q=katran+v ... B480%3B640</a><!-- m -->
Moje bistvo vprašanja je, zakaj nastane katran, kaj je narobe pri gorenju,
Zgeleda da nepopolno izgorevanje se pravi kisika. Če bi imel peč ki vedno gori s naravnim vlekom in TDP nekje 220 stopinj bi bilo morda idealno.
<!-- m --><a class="postlink" href="http://www.youtube.com/watch?v=OEKmTtpFLNM">http://www.youtube.com/watch?v=OEKmTtpFLNM</a><!-- m -->
avtobus52 Napisal:Moje bistvo vprašanja je, zakaj nastane katran, kaj je narobe pri gorenju,
Katran nastaja zaradi prenizke temperature vode v kotlu in posledično slabega gorenja. Pa poizkusite kurit od zgoraj ne od spodaj pri takih kotlih. Se veliko bolje obnese, če se lepo zloži drva in zakuri zgoraj.
Za izgorevanje so potrebne 3 komponente:
a. kisik
b. toplota
c. gorivo
Možni vzroki, da dopolnem jokovot-a:
a. neustrezna količina kisika (preveč zraka zaradi nastavitve ventilatorja oz. premočnega vleka dimnika hladi gorivo), neustrezno razmerje primarnega in sekundarnega kisika (konstrukcija izgorevalne komore), ni vmešavanja sekundarnega zraka (konstrukcija izgorevalne komore).
b. Če se gorivo hladi, to ne more zgoreti pri visoki temperaturi. Ta je pogoj za popolno vplinjanje goriva in izgorevanje plinskih produktov, med drugim ogljikovodikov, ki tvorijo osnovo katrana. Hlajenje goriva ima osnovo v dodajanju hladnega goriva na gorišče (pregorevanje) - to konstrukcijo uporablja večina v Sloveniji narejenih gorilnikov. Če je količina goriva, ki se doda prevelika, je potreben seveda čas, da se to gorivo ogreje, vplini in zagori. Če sledi nova količina goriva, je produkt seveda dim, prah, katran.
Če se dovaja preveč zraka, ta znižuje temperaturo izgorevanja. Za to je kriv dušik (v zraku ga je 78%). Skratka potrebno je dovajati dovolj (ne premalo in ne preveč).
Idealno bi seveda bilo, da bi bil dovodni zrak predgret, seveda bitka za nižjo prodajno (proizvodno) ceno, gorilniku tega ne omogoča. Srečamo pa uporabo predgrevanja v peletnih specialkah. Še pomnite tovariši, da so nekateri boljši gorilci za ELKO greli olje? Analogija tam je bila viskoznost in boljše pršenje skozi šobo.
c. O tej točki pa je bilo dovolj povedanega.
Po meni je edina prava rešitev nastavljanje vsakega sistema z inštrumentom, ki bo pokazal osnovne parametre (ostanek O2, vlek dimnika, CO, CO2, temperaturo TDP), ki vodijo k dobremu rezultatu izgorevanja. Posledično verjamem se znižajo emisije prahu, zmanjša možnost nastajanja oblog in seveda izkoristek kotla.
Hvala za pojasnila, pri svoji peči ugotavljam, da imam dobro izgorevanje, obloge na peči, pa je pepel, ker je sive barve. Mogoče se motim.
telmos Napisal:
Kurim na povratek vode 70 stopinj 250-300stopinj TDP. Kurim od zgoraj navzdol se super obnese. Dolgo gori. Samo zakaj se ustvari črni dim ko odprem zgornja nalagalna vratica? Dovod zraka je podpih in naredil sem odprtino na vratcih za večji dovod zraka in s tem povečal vlek. Je prav ali ni? Peč čista očiščena po enem kurjenju tako se lepo sveti peč od znotraj. No kurim na drva. Na pelete ista stvar.Nevem pa kako narediti ta primarni in sekudarni dovod zraka.
Mislim pa da je konstukcijsko peč narejena tako.
some1 Napisal:
jani65 Napisal:Gorilec CM. Polž deluje 4min, gorilec 16min do izpihovanja, tem.kotla 67sC,dvižni vod 40sC ,moč kotla 20kw in gorilca, tem.dim.plinov max. 150sC
Jani čudno tole. Pri meni ( enako CM) traja cikel do izpihovanja cca. 14min in 45s.Temp. kotla 72.C, dvižni vod 40-45.C, ( štarta pri 59.C), moč kotla 20kw, gorilec 14kw. Temp. dimnih plinov 170.C.
kako si pa izmeril delovanje polža v enem ciklu?
Ja Some pri teh gorilcih,kotlih in peletih je marsikaj čudno. Na transporter imam vezan števec obratovalnih ur,tudi na foto celico gorilca bi zmontiral pa ne najdem načina. Kotel je CK 25 ,gorilec 35. Tu lahko prihajajo razlike. Koliko m2 ogrevaš, število radiatorjev,regolacija,izolacija hiše.... . Pri nas je 18 radijatorjev,navadna fasada
jah ogrevam cca. 150m2 ( 12 radiatorjev ). Izolacija je 5cm ( severna stran 10cm). Regulacija navaden štiripoten ventil. Sicer pa letos ogrevam zgolj termosifonsko ( brez črpalke ).
Jani si probal kaj nastavljati gorilec? Ker sem siguren, da lahko precej izboljšaš razultate oziroma zmanjšaš cikel.
Nastavljal vse mogoče pa ni nekih občutnih spremeb.Sprememba je edino med lanskimi in temi peleti ,ki jih imam sedaj ,ko je kotel rabil približno 23 mim.Lanske natavitve so bile večinoma tovarniške,letos sem spremenil doziranje, ter za malenkost zmajnšal obrate ventilatorja.
telmos Napisal:
Pod tole se podpišem. Vsi lastniki kotlov ne naredite napake in si preberite navodila za svoje peči.
Tudi jaz sem z zmanjšanjem moči gorilca ter posledično temperature dimnih plinov (ker je to na foromu že moda) mislil da bom kaj prišparal. Figo, sam peč in dimnik sem zapacal.
V navodilih za mojo peč piše, da mora delovati med 65 in 95 stopinj (temp. kotlovske vode), tmp dimnih plinov pa je med 180 in 240 stopinj, ker drugače se nabira katran in ostalo.
Ker gre za staro Buderusovo litoželezno tehnologijo in peletni gorilec. No sem si privoščil odstopanje v minus in sicer tako, da peč ne deluje nikoli pod 55 stopinj , tmp. plinov pa se giblje med 130 in 170. Predelal sem pa jo z manjšimi modofikacijami tako, kot je bilo to v navodilih za njo ko se je kurilo kurilno olje (pokrit strop, rešetka ter zadnja stena).
V bistvu podoben princip kot etiksova Viadrus (moja je boljša se pri rezanju z fleksom sploh ne iskri Confusedhock: kot Viadrus he he :mrgreen:
kje je @monter se nič ne oglaša pa tudi na ZS ne odgovarja .
Da ni slučajno rikno,nekaj vprašanj sem mu zastavil glede gorilca pa nič od tega.
ficko
Nisem rikno, sem prisoten, malo je blo dopusta malo je blo letanja zdaj pa dalje akcija
"Monter", vprašanje zate, gorilec Lamorg.., moć na 3 stopnji, kurim na modularno, katere parametre bi moral nastavljat ko se iz moči tri vrne na moč ena, potrebno bi bilo malo nastavit, v knjigi piše da se - moč dva nastavlja, čeprav je na displeju izpisana enka.
1 ... 54 55 56 57 58 ... 90 Pojdi na stran
