PodSvojoStreho.net Gradnja in obnova Energijski viri Rekuperatorji razlika
#16
nas rekuperator dela na sledeci nacin:
Airflow Mode
When the supply air temperature is between 0° and -20°C, antifrost will automatically activate. This will reduce the supply airflow rate and increase the extract airflow rate to prevent frost forming on the heat exchanger. During antifrost operation the supply motor can stop for 15 minutes per hour and run for 45, depending on the temperature below 0°C.
If the supply air temperature is -20°C or below the supply fan switches off and the extract fan continues to run at reduced rate to prevent frost forming on the heat exchanger.
An additional option is Anti Frost with Heater Mode which should be selected if a pre heater is fitted... -> no, grelca mi nimamo.
#17
Hvala gt001, nisem vedel da imajo rekuperatorji to funkcionalnost.
Sem sel se bolj podrobno brati user manual pa tudi za Lossnay pise nekaj podobnega:
[Slika: Q0b21hz.png]
#18
Imam LG, ni vrhunski a cisto ok dela.
Btw; a je filter ki se menjuje iz kakega posebnega materiala (tkanina), ali lahko uporabim kar enako kot je za kuhinjske nape?
#19
Ne vem, kaksen filter material je v kuhinjski napi. Obicajno se za rekuperatorje uporablja filter material G4 ali pa F7.
Ce ti okvir / ohisje filtra omogoca lastno menjavo filter materiala, se le-ta dobi na metre...
#20
Kje bi to vedeli (lahko vzamem stari filter zraven),  in kje se kupi na metre?
Originalni filter (2 kosa) staneta 75 eur :/
#21
https://www.konuskonex.si
#22
Hvala, preverim
1 2
