Objave: 13321
Teme: 13
Pridružen: Jan 2008
-503
če sem prav videl sta vgrajena TECUMSEHA
bo pa tudi star kompresor na R22 čisto zadovoljen z R290 kateri se lepo meša z mineralnim oljem, saj gre v biti za utekočinjen nafti plin
Objave: 7905
Teme: 59
Pridružen: Oct 2010
34
12-13 jurjev, sem našel v nekem lanskem ceniku...
Objave: 740
Teme: 11
Pridružen: Jan 2012
Altherma HT - ustreza MCS
[url]httpunichr("58")//wwwunichr("46")microgenerationcertificationunichr("46")org/admin/documents/MCS%20007%20-%20Issue%202unichr("46")1%20Product%20Certification%20Scheme%20Requirements%20-%20Heat%20Pumps%202011unichr("46")10unichr("46")26unichr("46")pdf[/url]
Who needs RHI when there’s SAS?
Lee Housing Association is a community-based organisation that aims to provide good quality accommodation. Swan House was originally built for students, split into four blocks, each block contains four 5-shares and eight 2-shares, all are served by the original under-floor heating system since 1979, serviced by electric wires within the floor construction. The original under-floor heating installed had no controls to vary temperature; it was either on or off.
Lee Housing was looking for an efficient heating system, where all components could be stored outside of the apartments, due to space constraints. Climate Facilities, a Space Air / Daikin approved dealer, offered and installed the complete Space Air Daikin Altherma HT System. Space Air for over 30 years has designed and manufactured accessory components to compliment the Daikin product range, one of which is the weather-proofed enclosures. These were made for the indoor unit (containing a secondary DX cycle and heat exchanger to reach those higher temperatures efficiently) so it could be positioned outside the building along with the outdoor unit, as per the tender request. Every Space Air supplied system comes with prefabricated piping kits to optimise the energy efficiency of the system and wattmeter’s to monitor the energy usage of the Space Air Daikin Altherma air/water heat pump, the kits and meters are also covered in weather and vandal proofed enclosures.
Each block now consists of 2 x 16kW heat pump units a total of 128kW with a nominal COP of 3.08 (the original system had a nominal COP of 0.8 when installed). The out of date under-floor heating system has been replaced with radiators provided with TRV’s (thermostatic radiator valves) for residents to control the internal temperature. Independent reports suggest that by replacing the old under-floor electric system with the Space Air Daikin Altherma HT high temperature heat pump provides a 68% reduction in heating fuel use and cost and a payback period of 15 years. Based upon 8p/kWh this equates to an annual saving of £18,986 in year 1.
The Daikin Altherma HT system is MCS certified and holds the European Eco-label accreditation.
Objave: 7905
Teme: 59
Pridružen: Oct 2010
34
Povračilna doba v primerjavi z ogrevanjem na elektriko torej 15 let. Malo je nejasno napisano, če so v izračun povračilne dobe všteti tudi radiatorji...
Objave: 13321
Teme: 13
Pridružen: Jan 2008
-503
veš kaj, Daikin HT nima za burek proti zgoraj omenjeni, še vedno je "obična" klima TČ in kot kaže bo to tudi ostal :wink:
mislim, da je na tem forumu že dovolj ekonomistov in tgovcev, ki hvalijo samo tisto kar oni prodajajo, vse ostalo pa popluvajo. Forum pač ni namenjen trgovanju, ampak pridobivanju neke realne slike v svetu TČ, katera je pa zaradi takšnih reklamatorjev popolnoma izkrivljena.
Objave: 1804
Teme: 21
Pridružen: Feb 2011
Dokler bo meni in še tisočim po svetu Daikin HT:
-deloval zelo tiho tudi ob največjem mrazu
-pri izkoristkih do 75% napram prej
-segrel vodo do 80C
-ne izgubljal moč
-imel garancijo 5 let v Evropi(pri nas samo 3 leta zakaj že???)
-imel ceno z normalnim bojlerjem in 11kw enoto za dobrih 9000€ na ključ!!!
-imel dobro rešeno rešitev zmanjšanega tlaka z dvokompresorsko enoto in s tem mnogo zmanjšanim obremenitvam naprave
bo to še vedno zelo dobra alternativa zamenjavi fosilnim gorivom na TČ. Sem pa že pisal da so v ITA in FRA in pa SANYO tudi TČ do 70C vendra so zaenkrat predrage. Tdui v praksi "se baje" ne izkaže SANYO kaj bolje z COP-om. Tako da do takrat je ta po tvoje "Klima TČ" odlična izbira.
Sop a seveda še druge HT TČ do 65C TT in pa DIMPLEX.
Objave: 5764
Teme: 1
Pridružen: Feb 2012
32
Potem Fujitsu nima niti za piroško. S takimi komentarji me vedno bolj oddaljujete od bilo kakega nakupa toplotne črpalke.
Objave: 13321
Teme: 13
Pridružen: Jan 2008
-503
xavi... zgoraj omenjena je on - off mašina daikin in fujitsu sta pa oba klima inverterja.
pač ne gre metati vse v isti koš :wink:
Objave: 1368
Teme: 5
Pridružen: May 2010
če bi jaz poslušal nekatere strokovnjake tudi ne bi imel tč in bi kuril na drva........
resnica je da nihče ne ve 100%resnice za katerokoli tč-BISTVOpri meni je bilo da sem se ODLOČIL za tč in mi ni zal-ker imam dokaj izolirano hišo imam za radiatorje dovolj toplo vodo cca do 47st. pri -18st zunaj drugače bi jaz osebno kupil če ne bi imel izolacije daikin ht ali pa tisto francosko na r290-samo zame finančno nedosegljivo
Objave: 188
Teme: 6
Pridružen: Jul 2011
Tole prerekanje kaj je boljše slabše je pa že res neokusno, dokler bomo mi skozi zimo prišli z 860eur z SV mi je čisto vseeno katera TČ je boljša slabša (20 letno povprečje - 3000l kurilnega olja, neizolirana hiša) predvsem uporabnika ogrevalnega sistema zanima funkcionalnost in ekonomičnost pa ne govorimo da je Daikin HT naj izbira, verjetno bi se s katero drugo ogrevalno napravo ravno toliko prihranili ali pač ne, to si naj pa vsak po svoje razlaga, nobenega pa ne slilimo da si nabavi ravno to TČ, je pa pač to tema o Daikin HT, splošnega kritiziranja o še ne videni napravi je pa nepotrebno.
Objave: 1804
Teme: 21
Pridružen: Feb 2011
ČE bi jaz poslušal monterje bi bila za mene tudi dobra rešitev vgradnja:
-GREE klima TČ (ker je poceni)
-vgradnja plinskega kotla(ker je bolj stabilna od TČ Zrak voda)
-in še vse TČ za 15000€ in naprej
Odločil sem se po svoji vesti in zaenkrat mi ni žal.Prej smo porabili 3800l kurilnega olja za cca 250m2,sedaj porabimo 1150€ na leto za 300m2 ogrevalne površine. Ubistvu smo za 70-73% zmanjšali stroške napram porabi z kurilnim oljem in to nam je bistvo. To je naša situacija. Vsak ima pa drugačno in primerjat porabo z drvmi napram porabi z TČ je čisto out.
Objave: 1368
Teme: 5
Pridružen: May 2010
če misliš moj post ne govorim o porabi z drvmi-
ampak če bi poslušal "strokovnjake"bi še danes kuril na drva in olje....ali pa zelo preplačal kurilno napravo- ze zdavnaj sem ugotovil da je bistvo zasluzek zato so vse tč ali zanič ali iste zelo dobre odvisno kdo razlaga-ne glede na pisanje na forumu sem se jaz zase odločil na podlagi strokovnih kriterijev(zame je merilo original tehnična dokumentacija ne pa razni prospekti in super podatki prodajalcev) posameznih tč in sem napisal katere bi kupil za svojo hišo-daikin ht in HRC 70
