Objave: 1242
Teme: 92
Pridružen: Jun 2013
Granitogres is the evolved expression of fully vitrified unglazed porcelain stoneware. Granitogres
can be used both for floor and wall tiling, and is the ideal solution for high traffic places, with significant
physical-chemical stress, but can also be used for residential architecture: the most prestigious lines, successfully
matching sturdiness and a great esthetical refinement, are especially indicated for these uses. Granitogres is
suitable both for dry and wet or humid rooms (in the specific surface) and is available in several natural and relief
surfaces. The huge range of colours, sizes, surfaces and special pieces enables the widest choice of solutions,
combinations and applications to architects and designers. Granitogres is suitable for every design solution, from
the most original building of modern architecture to the restoration of classical buildings. Thanks to its superior
technical features, extremely easy laying and convenient maintenance, Granitogres is the ideal choice always!
tisti, ki prodajate buče, lahko razložim še v slovenščini.
Objave: 256
Teme: 0
Pridružen: Oct 2007
Še enkrat si poglej na kaj se nanaša tekst s katerim si vse razložil.
Zakaj noben proizvajalec razen Casalgrande Padana ne govori o granitogresu, čeprav se ta izraz uporablja vsak dan?
na kaj pomisliš ko nekdo omeni
-knauf (mavčne plošče)
-superge(športni copati)
-fleksarca(kotna brusilka)
The angle grinder was invented in 1954 by German company Ackermann + Schmitt (FLEX-Elektrowerkzeuge GmbH) in Steinheim an der Murr
granitogres je samo sinonim za družino materialov, v resnici pa je zelo stara kolekcija proizvajalca Casalgrande Padana, pravilno je pa PORCELAN GRES in je lahko izdelan v različnih tehnologijah ( polna masa, glaziran....)
druga takšna splošno priznana buča so pa lasersko rezane ploščice. Sliši se tako fancy da vsi na veliko uporabljajo, čeprav boš zasledil izrazz '' rettificato'' Postopek obrezovanja je popolnoma mehanski
Rectified tile is tile that has been mechanically finished on all sides to achieve uniformity and precision. During the manufacturing process, an extra step is taken to grind the tile to precise and consistent dimensions. - See more at: <!-- m --><a class="postlink" href="http://www.marazziusa.com/what-rectified-tile#sthash.4C1l4Ze2.dpuf">http://www.marazziusa.com/what-rectifie ... l4Ze2.dpuf</a><!-- m -->
Objave: 1242
Teme: 92
Pridružen: Jun 2013
1. pomislim na:
- knauf: podjetje
- superge: obutev za tek (naziv izhaja iz super-G)
- fleksarca: uporabljam izras samo kotna brusilka
Casalgrande Padana je morda izumil izraz granitogres in marmorgres, zraven so pa še podali definicijo kaj to je. In to sem napisal v prejšnjem postu.
torej to je popolnoma vitrificiran porcelan, kar pomeni stekleni prehod po celem materialu.
<!-- m --><a class="postlink" href="http://en.wikipedia.org/wiki/Vitrification">http://en.wikipedia.org/wiki/Vitrification</a><!-- m -->
To kako so ploščice rektificirane je čisto odvisno od podjetja. Verjetno najprej lasersko odrežejo 1cm od stene, potem pa zbrusijo robove.
Objave: 256
Teme: 0
Pridružen: Oct 2007
zakaj bi metali toliko material stran in si delali dvojno delo?
Objave: 1242
Teme: 92
Pridružen: Jun 2013
zato, ker veliko podjetij prodaja ploščice 59x59cm, zraven pa še 60x60cm. pa še za druge dimenzije je tako. verjetno z razlogom ne? preša stiska eno dimenzijo, 1. klaso režejo na laser.
odrezat morajo pa 1cm stran oz. 0,5 na obeh straneh zato, ker je rahel hribček od glazure ob robovih. in če so ploščice še polirane, to zna bit problem.
Objave: 1242
Teme: 92
Pridružen: Jun 2013
recimo sem gledal rex (kao neke luksuzne - niso vredne svojega denarja) italjanske ploščice, ki so verjetno samo rezane brez strojne obdelave. in se vidi da so stranice dejansko zelo hrapave. verjetno laser točkovno zareže v razmaku 5mm, tako da na tistem mestu cela plošča poči.
Objave: 1242
Teme: 92
Pridružen: Jun 2013
podčrtaj še "unglazed", potem pa še "chromatic effects obtained by full body colouring only".
al ti gre angleščina tako slabo, ali pa mentalna blokada in vidiš samo tisto kar hočeš?
Objave: 256
Teme: 0
Pridružen: Oct 2007
sem zaključil ker je škoda prepričevat prepričane, sicer pa je bilo govora o granitogresu
xy proizvajalcev dela ful body unglazed, pa tega razen Casalgrande in tebe noben drug ne poimenuje granitogres
Objave: 1242
Teme: 92
Pridružen: Jun 2013
casalagrande, jaz in 10000 trgovcev po svetu. samo ti si izjema. ker ti google prve rezultate vrže granitogres serijo od proizvajalca Casalgrande Padana si zdej glavni poznavalec granitogresa.
Objave: 256
Teme: 0
Pridružen: Oct 2007
ne dojameš, ni ti pomoči
pa ta pameten odneha
Objave: 307
Teme: 11
Pridružen: May 2012
Da še jaz eno povem: lepilo v merkurju MQ za 3.5 EUR 25 Kg piše da je za zunanje ploščice, potem v navodilih tudi piše da je za notranjo uporabo. Ko to lepilo naneseš na ploščico na tanko 1mm in potem z zobato gladilko na grobi omet ali estrih to prime da je kaj. Brezveze neka dražja lepila. Tako da, stvar je čisto solidna. Zdej za special zadeve je pa treba posebna lepila ni kaj.
Objave: 1242
Teme: 92
Pridružen: Jun 2013
draga lepila so fleksibilna, ker imajo plastiko notri oz. polimere... da ne bo kdo mislil dobesedno plastiko. pač na molekularnem nivoju. karkoli že, več dodatkov, dražje lepilo.
Objave: 1242
Teme: 92
Pridružen: Jun 2013
Meni je zdej keramičar položil ploščice... tip obvlada.
<!-- m --><a class="postlink" href="http://shrani.najdi.si/?1U/Eu/12hlDPT0/20140918181455.jpg">http://shrani.najdi.si/?1U/Eu/12hlDPT0/ ... 181455.jpg</a><!-- m -->
Pravi sicer da ob stenah ni potrebno dati silikona, drugi pa pravijo da se ga da. Kakšna je funkcija silikona? Da preprečuje da bi polita voda šla pod estrih in da ohranja fleksibilnost ploščic?
Objave: 307
Teme: 11
Pridružen: May 2012
Sej verjetno ti bo dal itak obrobe po stenah, ki bo tistih nekaj mm kjer do stene ni ploščice skrilo. Silikon se po mojem vedenju daje v wcju med talnimi in stenskimi ploščicami. Ni pa nujno, lahko se kar pofugira.
