PodSvojoStreho.net Gradnja in obnova Montažni sistemi in les Prenova skednja v lesen vikend
Zdravo,
Sem lastnik skednja, ki bi ga želel predelati v vikend. Podkleteni del je zidan, kakor tudi nosilni stebri za skedenj, ostalo je leseno. Zidan del bi želel ohraniti, lesenega pa adaptirati. ali me lahko prosim kdo napoti na projektante/arhitekte/izvajalce, ki bi to počeli? Hvala in lp
Iščem tudi uglednega izvajalca za popravilo moje lesene hiše. Nam lahko kdo pomaga?
lyly19,
iz katerga koca si napiš!
Hodoš Sad ali Izola Wink ??
(21.8.2025 ob 10:25)som16 Napisal: lyly19,
Zdravo, Ja seveda. Cerknica. Hvala vnaprej.
        lovemoney2
Introduction
Renovating an old barn into a functional weekend house is an exciting project that combines creativity, practicality, and sustainability. Using modern assembly systems and wood construction techniques , you can turn a rustic structure into a comfortable, warm living space while preserving its historical charm.
1. Planning and Design
  • Assess the structure: Check the foundation, walls, roof integrity, and load-bearing elements.
  • Define functional spaces: Decide on the number of rooms, bathrooms, kitchen layout, and living areas.
  • Integration with nature: Take advantage of natural light and the surrounding landscape; barns often have large open spaces suitable for lofts or mezzanines.
2. Wood and Assembly Systems
  • Wood as primary material: Offers warmth, insulation, and aesthetic appeal. Common choices include spruce, pine, or larch.
  • Modern assembly systems: Prefabricated panels, modular wood frames, or timber frame kits speed up construction and ensure structural stability.
  • Insulation: Combine wood walls with natural insulation materials (cellulose, sheep wool, cork) for year-round comfort.
3. Renovation Process
  • Structural reinforcement: Replace or repair damaged beams, reinforce walls, and update the roof structure.
  • Flooring and insulation: Install proper subflooring and thermal insulation, especially if the barn was originally cold and drafty.
  • Windows and doors: Use double-glazed windows and wooden doors to enhance energy efficiency and maintain rustic charm.
  • Utilities: Plan electrical wiring, plumbing, and heating systems carefully, especially in older barns not designed for habitation.
4. Interior Design and Finishing
  • Rustic-modern style: Keep wooden beams and original textures visible, but add modern furniture and finishes.
  • Open-plan concept: Utilize large open spaces typical of barns for living-dining-kitchen areas.
  • Storage solutions: Use lofts, built-in cabinets, and under-stair storage to optimize space.
5. Sustainability and Comfort
  • Energy efficiency: Insulate walls and roof, install energy-efficient heating, and consider solar panels if possible.
  • Natural ventilation: Take advantage of the barn's tall ceilings and large doors for airflow.
  • Eco-friendly materials: Reuse existing wood where possible, and select low-VOC paints and finishes.
Conclusion
Renovating a barn into a wooden weekend house blends rustic charm with modern comfort. With careful planning, the right assembly systems, and a focus on sustainability, you can create a unique retreat that is both functional and visually appealing.
Carefully plan the electrical wiring, plumbing, and heating systems, particularly in older barns that were not originally escape road game built for living purposes.
