Prenova skednja v lesen vikend - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Montažni sistemi in les (https://podsvojostreho.net/forum/forumdisplay.php?fid=14) +--- Tema: Prenova skednja v lesen vikend (/showthread.php?tid=85665) |
Prenova skednja v lesen vikend - frahit - 17.8.2025 Zdravo, Sem lastnik skednja, ki bi ga želel predelati v vikend. Podkleteni del je zidan, kakor tudi nosilni stebri za skedenj, ostalo je leseno. Zidan del bi želel ohraniti, lesenega pa adaptirati. ali me lahko prosim kdo napoti na projektante/arhitekte/izvajalce, ki bi to počeli? Hvala in lp RE: Prenova skednja v lesen vikend - lyly19 - 21.8.2025 Iščem tudi uglednega izvajalca za popravilo moje lesene hiše. Nam lahko kdo pomaga? RE: Prenova skednja v lesen vikend - som16 - 21.8.2025 lyly19, iz katerga koca si napiš! Hodoš ali Izola ??
RE: Prenova skednja v lesen vikend - frahit - 24.8.2025 (21.8.2025 ob 10:25)som16 Napisal: lyly19, Zdravo, Ja seveda. Cerknica. Hvala vnaprej. RE: Prenova skednja v lesen vikend - pugoing - 13.10.2025 Iščem tudi uglednega izvajalca za popravilo moje lesene hiše. Nam lahko kdo pomaga? lovemoney2 RE: Prenova skednja v lesen vikend - avareed - 4.12.2025 Introduction Renovating an old barn into a functional weekend house is an exciting project that combines creativity, practicality, and sustainability. Using modern assembly systems and wood construction techniques , you can turn a rustic structure into a comfortable, warm living space while preserving its historical charm. 1. Planning and Design
Renovating a barn into a wooden weekend house blends rustic charm with modern comfort. With careful planning, the right assembly systems, and a focus on sustainability, you can create a unique retreat that is both functional and visually appealing. RE: Prenova skednja v lesen vikend - ColeHarry - 12.12.2025 Carefully plan the electrical wiring, plumbing, and heating systems, particularly in older barns that were not originally escape road game built for living purposes. |
