PodSvojoStreho.net Opremljanje doma Kopalniška oprema podometni kotliček - Geberit + školjka
Zdravo,
Sem v procesu prenove kopalnice in imam vpraša je glede Geberit podometnih kotličkov in sicer mi lahko nekdo pove kaj je razlika med temi kotlički, razen v tipki:
https://www.fero-term.si/product/splakov...gma20.html
https://www.fero-term.si/product/splakov...-bela.html
https://www.fero-term.si/product/splakov...12-cm.html
https://www.fero-term.si/product/splakov...-novo.html
Zanima me še ali je na Geberitove podometne kotličke možno montirati samo zidnje školjke? Namreč raje bi imel samostoječo, ki ima prav tako, kanalizacijsko cev v steno, je glede tega kakšen standard ali je to odvisno od proizvajalca?
školjka bi bila:
https://www.fero-term.si/product/wc-skol...52-cm.html
Hvala za odgovor.
Razlika med sigmo in delto ni samo v tipki, delta je basic izvedba in nima predpriprave za razne komfortne dodatke, ima manjši nabor tipk. Za samostoječo wc školjko pa uporabiš kombifix izvedbo, vendar moraš vedeti za katero školjko ga boš uporabil zaradi priključnih mer izpiranja in odtoka.
(16.2.2025 ob 14:42)jonystar Napisal: Hello,
I am in the process of renovating my bathroom and I have a question about Geberit concealed cisterns. Can someone tell me what the difference is between these cisterns, except for the button:
I am also curious if Is it possible to install only wall-mounted toilets on Geberit concealed cisterns? Namely, I would prefer a freestanding one that also has a sewage pipe in the wall, is there a standard for this or does it depend on the manufacturer?
The toilet would be:
https://www.fero-term.si/product/wc-skol...52-cm.html  Thanks for the answer.[url=https://blox-fruits.io/][/url]
Thanks for the clear distinction in the information; the differences in the accessories will also be noticeable.
Thanks  Smile
https://minecraftpatchdownload.com/
