PodSvojoStreho.net Kar naredi dom Zabavna elektronika Videonadzorni sistem
Rad bi si nabavil wifi videonadzor iz aliexpressa,imate kakšne izkušnje,mnenja itd.?
Gledal sem te,glede na ceno ,ki je tukaj pri nas za isti dr.k,je preko aliexpressa občutno ceneje..
<!-- m --><a class="postlink" href="https://www.aliexpress.com/item/4CH-Wireless-NVR-Kit-Plug-and-Play-7200P-HD-Outdoor-Night-Vision-1-0mp-Security-Camera/32654937852.html?spm=2114.10010108.1000014.10.TJTpCS&scm=1007.13338.49930.0&pvid=5582733b-8f1c-4bae-840d-b887344dc162&tpp=1">https://www.aliexpress.com/item/4CH-Wir ... c162&tpp=1</a><!-- m -->
<!-- m --><a class="postlink" href="https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20161112052120&SearchText=security+camera+system+wifi">https://www.aliexpress.com/wholesale?ca ... ystem+wifi</a><!-- m -->
Sam sem preko Aliexpressa nabavil kamere HIKVISION in moram rečt, da so top.
<!-- m --><a class="postlink" href="https://www.aliexpress.com/item/New-Hik-Bullet-IP-Camera-4MP-DS-2CD2045-I-H-265-H-264-4MP-waterproof-Cameras/32751725649.html?spm=2114.01010208.3.30.EiNHSy&ws_ab_test=searchweb0_0,searchweb201602_2_10037_10032_10077,searchweb201603_1&btsid=adf6f42b-d14d-46ae-a748-1a27bc976cf6">https://www.aliexpress.com/item/New-Hik ... 27bc976cf6</a><!-- m -->
in
<!-- m --><a class="postlink" href="https://www.aliexpress.com/item/HIKVISION-4mm-DS-2CD2432F-IW-3MP-2MP-1080P-PIR-Audio-Mic-Onvif-Cube-HD-IP-Camera/32763954441.html?spm=2114.01010208.3.113.Gd6Jwj&ws_ab_test=searchweb0_0,searchweb201602_2_10037_10032_10077,searchweb201603_1&btsid=62b4a81d-c8ca-4153-97ae-bdb2c9a7dfba">https://www.aliexpress.com/item/HIKVISI ... b2c9a7dfba</a><!-- m -->
Snemalnika nisem kupil, pač pa snemam na;
<!-- m --><a class="postlink" href="http://www.laservis.si/prodaja/?128,ds-216j-synology-nas-streznik">http://www.laservis.si/prodaja/?128,ds- ... s-streznik</a><!-- m -->
Zadeva mi lepo deluje tudi na telefonu. Težava pri Synologi-ju je ta, da imaš v osnovi možnost priklopa dveh kamer, za kaj več pa potrebuješ kupiti dodatne licence cca. 50 ojro.
Kolk daš, tolk dobiš. A sem že dolgočasen, ko se stalno ponavljam, ne,
Vem kaj misliš,samo jaz ne rabim da vidim nekomu mozolj na obrazu,ampak da vidim kdo pride oz. hodi okoli hiše.1MP pa mislim,da je to dovlj,pa wifi mora biti,ker nimam utp kablov potegnjenih ,za elektriko pa mislim,da ne bo problem,bom potegnil iz škatle kjer imam vgradne lučke.
V info: 1Mp na tri metre ajd, še gre, na kaj več bo pa razočaranje. Mozolja na obrazu mu pa ne boš videl niti z metra oddaljenosti.
Bom pa dal še en predlog za slučaj, ko ni UTP/FTP kablov, na razpolago pa je kabel (ali pa kje blizu) 230V:
<!-- m --><a class="postlink" href="http://tendacn.com/en/product/P200.html">http://tendacn.com/en/product/P200.html</a><!-- m -->
Se pravi da rabiš kupiti ene dva taka kompleta (v škatli sta 2 kosa), vtakneš ga (ali kako drugače povežeš v omrežno napajanje 230V v hiši, blizu kamere, kamero povežeš z enim UTP kablom na ta adapter, tako tudi preostale kamere, in na mestu, kjer želiš imeti snemalnik (oziroma registrator, disk, ali kar si se pač namenil nabaviti) vtakneš v prvo vtičnico spet tak isti adapter in imaš preko energetskih vodnikov 230V žično povezane vse kamere in "snemalnik". Ali pa še več adapterjev, vtakneš v štrom, vklopiš UTP in nanj napravo in jo imaš v "mreži", eno, dve, tri, deset, če je treba. Brez tistega nadležnega menjavanja baterijskih vložkov po kamerah, če pa kamero napajaš z DC12V usmernikom si pa tako vezan na omrežno napajanje, torej zgoraj opisan primer potem omogoča vse "odprto" za vse rešitve, vse nadgradnje, menjavo kvalitetnejših kamer, bla, bla, bla...
Zakaj samo tri metre?Po slikah prodajalca je slika ok tudi iz večje oddaljenosti!
A verjameš prodajalcu, posebej kitajskemu? Ko boš ti točil solze razočaranja bo on tisoče kilometrov daleč štel tvoj denar. To ti pišem zato, ker sem do danes že zmontiral eno ali dve kameri takih in drugačnih resolucij in poznam slike, katere zmorejo take in drugačne kamere.
Na koncu pa tako ali tako vedno "dobiš" le toliko, kolikor si investiral. Da pa se razumemo - nočem te prepričevati proti tvojemu nakupu. Pri teh investicijah se ne splača kar takoj zaleteti z nakupom. V kolikor v hiši še nimaš protivlomnega sistema svetujem raje nabavo najprej tega in šele potem video nadzornega sistema kot podporo prvemu.
Saj ne rečem, lepo je kolegom pokazati okolico hiše na telefonu, pa še kako kamero malo zaobrniti. Ampak - mine.
Dober kompromis je nakup pri digitkliku, kitajska roba, samo preizkusena in tudi njihov support je ok. Cena sicer nekaj visja, a ni hudega.
Megapixli niso vse in z visanjem resolucije gre dol tudi svetlobna obcutljivost (cena pa gor Smile ), tako da ne bi pretiraval z njo po nepotrebnem.
Lp, g
Ker se menimo o kamerah katere imajo resolucijo v razponu med 1 in 5Mp, tako razmerje je nekje tudi v €, tista svetlobna občutljivost ne igra nobene vloge. Z njo se tolažijo tisti, ki so za kamero dali manj in so potem nad njo razočarani.
Ne bo ravno drzalo ... Sem delal s profi resitvami, brez skrbi, in ko je svetloba kriticna, gibanje pa hitro, vsak MP dol steje ... (no, steje velikost piksla). Ne verjamem, da je pri nizkocenovnih to vseeno, pricakoval bi se slabse.
Nekdo, ki investira v kamero 5Mp si ne bo dopustil kritične svetlobe in bo pod kamero osvetljevalec , običajno z valovno dolžino 915 nm, kar je za človeka nevidna svetloba. Ker pa je vse povezano z cekini in ker velika večina na to gleda izključno skozi tisti euro se take stvari potem tudi dogajajo. In kamera 1Mp pri sliki v ČB spektru ima sliko poden od podna, če te zadeve poznaš, veš, da se ne more primerjati s sliko, ki jo sproducira kamera 3, 4 ali 5Mp. V vseh pogojih.
MP nima nobene odvisnosti od svetlobne moci kamere. Ce je optika slaba in nima svetlobno mocnega objektiva nima veze ali je 10mp ali 1mp.
Poslano z mojega LG-H815 z uporabo Tapatalk
#13
Optika kot tudi vse ostalo pri kameri ima vezo z cekini. To je tisto, kar trobim že ves čas, ne samo tule.
#14
digitklik trži dahuo (2. največji proizvajalec teh zadev, menda). Pod svojim imenom jih trži tudi Mobicom, ki pa ima nek sloves, ko pride do alamnih sistemov in videonadzorov. Čeprav je kitajska roba...
#15
@arbajter: a mora biti Tenda po vsej hiši na isti fazi ali ni pomembno?
1 2 3 4 5 6
