PodSvojoStreho.net Gradnja in obnova Klasična gradnja Položaj oken
Spoštovani,
prosim vas, če lahko poveste na kakšen način se izvede fasada in vgradnja oken tako, da je okno čisto na zunanjem robu fasade, brez polic. Namreč ni mi jasno kako je to možno, če bomo dali na opeko še 20 cm izolacije.
Hvala.
R.
Takole:
[url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?D/XA/1YyaQNAn/1/20070207151538unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/D/XA/1YyaQNAn/1/20070207151538unichr("46")jpg[/img][/url] [url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?h/qm/4RT8v1PG/20071207100730unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/h/qm/4RT8v1PG/20071207100730unichr("46")jpg[/img][/url] [url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?O/13q/Ld9fXGZ/20090201144906unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/O/13q/Ld9fXGZ/20090201144906unichr("46")jpg[/img][/url] [url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?2S/10Y/1KztM69B/20090201144804unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/2S/10Y/1KztM69B/20090201144804unichr("46")jpg[/img][/url]
Police pridejo na izolacijo.
tomice Napisal:Takole:
OK
za zunanje police mi je jasno, prosim pa te za razlago kako se pritrdijo okna in notranje police?
Takole:
[url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?I/fE/CnFNEac/20070207152132unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/I/fE/CnFNEac/20070207152132unichr("46")jpg[/img][/url] [url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?1R/Ic/4quCmi5X/20070602092450unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/1R/Ic/4quCmi5X/20070602092450unichr("46")jpg[/img][/url] [url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?39/4x/2lV3dhLl/20080109142714unichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/39/4x/2lV3dhLl/20080109142714unichr("46")jpg[/img][/url]
Okna se privijačijo samo ob strani v zid, police položiš pa na zid do profila pod oknom, kjer je prav rob na katerega se polica nasloni, s kajlami daš v vago, zapurpenaš, potem pa pridejo okoli ometi. Nobena znanost.
Očitno ne bereš. Vprašanje je bilo na zunanji rob fasade oz. izolacije. Zato mu ni jasna izvedba. Kot tudi meni ni in kaj takega še nisem videl. Mogoče lahko Rezka da kako sliko take montaže. Sicer pa verjetno misli to, kar ima na slikah Tomice.
in kaj naj bi po tvoje potem nosilo okno - privijačeno v stiropor ali pa v tervol....
Če želiš kvalitetno prirtrditev potem mora biti vijak v zidu !! :!:
Pri primeru, ko se okna vgrajuje bolj na zunaji rob, se jih vgrajuje na kovinske L profile, na eno stran se vijači okno, na drugo v zid. Uporablja se pri posebnih željah, zaradi zunanjega izgleda ali pa velike pozornosti tudi na majhne toplotne mostove.
Se opravičujem. Niti pomislil nisem na možnost, da bi nekdo montiral okna povsem na zunanji rob 20 cm debele izolacije. Torej bodo na notranji strani police globoke 40 cm.
Do sedaj sem videl samo izvedbo z L nosilci, kjer je okno iz zidu v izolaciji za debelino okvirja.
Montaža okna na način, da je poravnano z zunanjim zidom, je običajni približek idealnega stanja, ko je okno montirano v izolaciji. Za normalno hišo je to dovolj dobro zmanjšanje toplotnega mostu, za kaj več pa je potrebno imeti primerno okovje in izkušnje. Občutek imam, da so težave ob nestrokovni montaži okna v izolaciji lahko veliko večje kot pa koristi od totalnega zmanjšanja toplotnega mostu Torej, če nimate mojstra, ki je to že kdaj delal, priporočam montažo na rob zidu. Okno lahko v principu gleda še malo bolj ven, samo da podložni profil leži še na zidu.
