Objave: 13279
-503
Pa Scroll kompresor v tem cenovnem razredu
hock:
Objave: 4017
Pridružen: Jul 2016
26
Pa regulacija je vključena :mrgreen:.
Objave: 658
Pridružen: Dec 2010
New Scroll Type Compressor
The new Monobloc units incorporate a new Scroll Type Compressor with a seasonal efficiency improvement of 7% over the previous rotary compressor. The new scroll type compressor is one that combines the high efficiency, low noise characteristics of the scroll compressor with the stable compressing structure of a rotary compressor, in one unit. Taking the benefits from both the scroll and rotary compressors, LG’s new Scroll Type compressor has been optimised for various cooling and heat load operations – low load at low speed, and low noise at high speed – ensuring efficiency increases and comfort improves. The new compressor incorporates new technology developed by LG – wet vapour injection. This is to control the high discharge temperature of the compressor efficiently, bringing it down from 160 to below 110°C, resulting in an expanded heating operation range and enhancing the unit’s performance at low ambient temperatures.
Cena na eni grški strani (tepse.gr) je ista, kot za stari model.
Objave: 13279
-503
Cena po preverjenih informacijah ostaja enaka kot pri starem modelu.
Objave: 49
Teme: 9
Pridružen: Jul 2014
Mi lahko še kdo prosim pove kakšno na temo glikol
Zdej pri nekaterih obvezno pri drugih priporočljivo
Ok zascita pred zmrzaljo, nekateri tukaj so že pisali da je potem prenos ali izkoristek z glikol slabši ali nekaj podobnega
Vem cena glikola v primerjavi z okvaro TC je ničelna toda mi kdo po domače malo razloži zadevo
Objave: 7259
Teme: 15
Pridružen: Sep 2008
53
Rabis vmesni izmenjevalec glikol/voda. Če je dober ploščni, potem le za kakšno stopinjo dvigne potrebni DV, kar se skoraj nič ne pozna pri SCOP.
Ne splača pa se glikola gonit npr. skozi spiralo v zalogovniku in nato iz njega odvzemat tople vode, saj bo potreben DV precej višji.
Objave: 49
Teme: 9
Pridružen: Jul 2014
No če govorimo o tem novem LG monoblok Therma V r32 to pomeni .....
Sem čist iz druge stroke pa mi tole lih ne pade direkt v glavo
Objave: 3009
Teme: 16
Pridružen: Dec 2017
-633
@csamo001 nadaljujem v temi za debato:
<!-- l --><a class="postlink-local" href="http://www.podsvojostreho.net/forum/viewtopic.php?f=7&t=70154">viewtopic.php?f=7&t=70154</a><!-- l -->
Objave: 3853
Pridružen: Oct 2013
Če nisi ravno čudak potem ob daljši odsotnosti od doma kakšnega sorodnika, prijatelja ali soseda naprosiš, da občasno malce pogleda okrog hiše (da ti jo ne okupirajo ilegalni migranti), izprazni nabiralnik, zalije rože...No, v skrajni sili bi ta oseba lahko izpustila tudi vodo iz zunanje enote TČ.
Objave: 49
Teme: 9
Pridružen: Jul 2014
In potem je zadeva rešena če prav razumem
