Objave: 12385
Teme: 192
8
Ni vijaka, sem spraševal serviserja, ki mi je zamenjal pol motorke da je zamenjal pumpo(ki ni kazala popolnoma nič več). Sestavljena naj bi bila v usa, nič kaj preveč nemško (enostavno, logično)
Objave: 1184
Teme: 34
Pridružen: Apr 2009
-1
The oil pump on Stihl chain saws feeds the bar with oil while cutting. Because the oil pump is connected to the clutch on Stihl saws, the engine has to be turning the clutch at a certain speed for the bars to get oil. If the oil pump isn’t working correctly, the bar will not have proper lubrication. This can cause excessive friction on the tip and in the engine. Proper chain lubrication is essential to maximize the performance of your Stihl chain saw.
Check the adjustable oiler for proper settings. The adjustable oiler is located on the bottom of the saw. It is marked by a plus and minus sign with a little oil can pictured next to them.
2
Increase the oil volume by turning the screw counterclockwise. Start the saw and hold the bar’s tip about an inch away from a piece of wood. Depress the throttle and look for a little splattering of bar oil against the wood.
3
Use the wrench to loosen the clutch cover’s bolts. Use the screwdriver to release the bar tensioner screw. Remove the bolts and the clutch cover. Take off the bar and remove the chain from the bar.
Remove the oil plate cover with the screwdriver. Use the sharp corner of the oil plate to clean out the bar’s guide slot. Insert the oil plate at the top of the bar and scrape down the length of the bar. Repeat this until the oil plate slides smoothly down both sides of the bar, and the guide slots are free of oil, dirt and sawdust.
Pull the spark plug’s connecting rubber plug and insert enough of the starter cord into the open shaft to block the piston from moving. This will allow you to remove the clutch assembly and investigate the problem on the saw’s oil pump.
6
Remove the E-clip from the sprocket with the screwdriver. Pull off the E-clip, washer and sprocket. Remove the clutch drum as well.
7
Remove clutch with clutch removal tool. The clutches on Stihl saws are left-hand locking; to loosen, turn the bolt clockwise to take off clutch. Remove the chain brake band, above the clutch, by unscrewing it with the screwdriver.
8
Unscrew oil pump mounting screws, which are located underneath the clutch assembly. Pull the pump off of the crankshaft by gently sliding it out.
9
Unscrew the pump’s adjustment screws with the screwdriver to disassemble the oil pump. Take apart the worm, drive spring, plug and plunger from the pump's housing. Clean all the parts with gasoline, wire brush and rag. Keep any parts that aren’t damaged or broken. Replace broken or damaged parts with new ones.
10
Reassemble the old oil pump or use a new oil pump kit if most of the parts need to be replaced. Use engine lubrication to grease the worm drive, spring and its plug.
11
Reconnect the saw’s parts following these steps in reverse order.
Objave: 39
Pridružen: Jul 2011
...kaj pa o tej motorki in ceni...
<!-- m --><a class="postlink" href="http://www.mobilservis.si/trgovina/husqvarna-435.html">http://www.mobilservis.si/trgovina/husqvarna-435.html</a><!-- m -->
Je vredna napisane cene?
Objave: 12385
Teme: 192
8
goldhorn: iz katerih navodil si prepisal to?
Objave: 255
Teme: 16
Pridružen: Jul 2006
Tukaj lahko najdeš ta navodila: <!-- m --><a class="postlink" href="http://www.ehow.com/how_5973443_fix-oil-pump-not-working.html">http://www.ehow.com/how_5973443_fix-oil ... rking.html</a><!-- m -->
Objave: 2
Pridružen: Jul 2012
Moje izkušnje. Pred petimi leti ko sem hotel dati dražjo Dolmarco na servis in to sem ponovno skušal pred dnevi je takole. Servis okoli 150 EUR.
Tako sem takrat v Hofru kupil Eihell motorko za 99EUR. še danes dela. Rabim samo 1x letno z njo naredil caa 140kubikov. Jutri grem v Hofer po novo Oregon ponovno za 99EUR. Ima 3 leta garancije. Huskvarne sigurno super žage in še katere druge tako da za take ki to rabijo vseskozi sigurno bol prava odločitev. Za občasne uporabnike pa kot sem omenil ni kaj faliti z nakupom kot ga omenjam. V parih letih tudi boljšo uničiš tako imaš za 99 EUR lahko vsako leto novo. Pa še v garanciji je.
Objave: 583
Pridružen: Apr 2012
Ima kdo izkusnje z efco motornimi zagami? Namen imam kupit manjso razlicico zage te firme, pa jih tle okol nekaj hvalijo? Pozna kdo?
Objave: 18
Pridružen: Jun 2011
Pozdravljeni. Zanima me vase mnenje ali je nidel husquvarne 365 uredu? Saj mislim da je model 365. V prumerjavi z husqvarno 555? Slabosti prednosti?
Objave: 138
Pridružen: Jun 2012
555 ne poznam,poznam pa 365 in je ne priporočam (težka je in za svojo moč ne reže kot bi morala) raje vzemi 359 je precej lažja in reže ok.
Če rabiš motorko za pripravo drv cca.50-60m3 letno poglej za 359 ali za 347xp.Primi vse tri v roke.
Objave: 7877
-189
Opažam, da pri največjih trgovcih s hrano kvaliteta tehnične robe sploh ni tako slaba, kot sem mislil...pa da pri "profi" proizvajalcih nižji cenovni razred preplačaš.
Garancijski rok je bistven podatek.
Objave: 466
Teme: 35
Pridružen: Dec 2013
Ima mogoče izkušnje kdo s tole žago:
<!-- m --><a class="postlink" href="http://www.makita.si/tool/22010/EA3500S40B.html">http://www.makita.si/tool/22010/EA3500S40B.html</a><!-- m -->
Uporaba: Za odžagati kaj pri gradnji in kdaj priprava manjše količine drv.
Ali je ohišje plastično ali je kovinska litina?
Mogoče še priporočilo za katero drugo v tem cenovnem rangu (260€)?
Objave: 20
Pridružen: Jan 2013
Pozdravljeni,odločam se za nakup motorne žage,s katero bi na sezono sežagal okoli 20metrov kalanih dvr,se pravi vsega skupaj ene 10 ur žaganja al pa še manj,..pa se odločam med tema dvema: <!-- m --><a class="postlink" href="http://www.totum.si/stihl-ms251">http://www.totum.si/stihl-ms251</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.totum.si/stihl-ms291">http://www.totum.si/stihl-ms291</a><!-- m -->
pa me zanima vaše mnenje,..ali bi mogoče potreboval manj močno žago za tako malo uporabo,..hvala in lp
Objave: 117
Pridružen: Jun 2014
Imam tole...
<!-- m --><a class="postlink" href="http://www.homedepot.ca/product/homelite-35cc-14-inch-chainsaw/916034">http://www.homedepot.ca/product/homelit ... saw/916034</a><!-- m -->
...kupljena v Merrkatorju za 95€...glih drugih 20 metrov hlodovine na 30 cm razžagal...nič roke ne bolijo, lahki vžig...dela brez problema...
