Objave: 11281
Teme: 92
Pridružen: Jan 2006
če jaz prav razumem se pogovarjamo o 5 metrskem drogu na strehi!
kje je daleč od glav, pa tudi precej potrebna višina je zagotovljena.
če bi jo papostavlja na tleh...pa seveda s 5 metri nimaš kaj dosti početi
Objave: 110
Pridružen: May 2005
Ker je toliko ovir in pomislekov, sem se odločil obrniti se na tistega, ki ima v svoji politki načelo "vmešavanja". Če bodo kaj ovirali pri postavljanju, bodo prišli marinci! Zmenjeno.
Poglejte na to stran:
<!-- m --><a class="postlink" href="http://www.aeromaxenergy.com/installs.html">http://www.aeromaxenergy.com/installs.html</a><!-- m -->
Lakota 1KW Wind Turbine Generator $1299 Retail.
Poglejte težo generatorja! Teža 16 kg za 1 kW!
Jaz bi pa vseeno potreboval eno vsaj 5 kW za ogrevanje.
Objave: 110
Pridružen: May 2005
1kw LAKOTA wind turbine, tudi specialne za uporabo na jadrnicah.
The Lakota is in the class of 1kW generators and stands out from all in the
same class. The leaps ahead of conventional wind turbines that the Lakota has
begin with its power to weight ratio, this 900W turbine typically peaks around
1500W and weighs only 35 lbs, 16 kg. Its blades are made of aerospace engineered
100% unidirectional carbon fiber that makes them stiff and light, far more
advanced than the fiberglass or high density plastic blades our competitors
use. Through our "Stealth Acoustic" technology the Lakota is virtually
silent, people like to call them "good neighbor turbines." You can see our
turbine in the Wikipedia at <!-- w --><a class="postlink" href="http://www.wikipedia.com">www.wikipedia.com</a><!-- w --> under wind turbines. Finally,
we have the lowest cost per watt of any turbine on the market. There are many
different ways to calculate the cost per watt, particularly skewed to make
the creators turbine look good, and of them if you put in the Lakota 900W
starting at the price that we can provide it will be the lowest cost per
watt!
Objave: 11281
Teme: 92
Pridružen: Jan 2006
po slikah sodeč (link) vetrnice niso pritrjene na ne vem kaka drogove - ka rpomeni da ne sme biti nobenih problemov s pritrjevanjem na strehi - prav tako pa na strehi hiše niti več ne rabiš neke hude višine - torej je obremenitev še toliko manj.
zadeva zgleda kar lična.
Objave: 1190
Teme: 23
Pridružen: Aug 2005
za Vigma:
Power Output:
Sea Level: 900 Watt nominal at 28.8 mph
500 Watt nominal at 21.5 mph
Peak Power maintained (up to 1200-1500Watts) in all wind above 30mph
more pa res lepo pihati da dobiš kaj :....900 Watt nominal at 28.8 mph,= kar lepa vipavska burja.....
Po taki noriji je VIGMA Jarenina postala poleg Nemčije edini dealer najkvalitetnejših malih wind turbin v Evropi.copy...
glede na zgoraj napisano se ti začenja rahlo kisati.......dream on.....
kaj nič več ne prodajate sanjskih kolektorjev (za katere nihče ne ve proizvajalca in ni nikjer testov ) in (NASA) toplotnih črpalk, ki delajo z faktorjem 4 pri -15st. C.............
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
(samo mimogrede, sedaj prodajate tudi "fotocelice" -- pa veš kaj je to :wink:
očividno so ti pojmi malce tuji...in mešaš vse tako na počez.....fotocelica ni enako sončna celica.....)
Objave: 1339
Teme: 26
Pridružen: Dec 2005
Tista vetrnica je igračka. :? Glede na debato, ki se je razvijala prej, govorimo o vetrnicah, ki dajejo elektriko. Mislim, da se take vetrnice, ki nima elise vsaj 5 metrov premera, sploh ne splača postavljati.
Objave: 238
Teme: 14
Pridružen: Dec 2005
neki čist neumestnega bi dodal...a ni na tem forumu kao nezažlejeno reklamiranje?... kje ste sedaj administratorji in zakaj te vigme ne zbanate dol????...njegovo reklamiranje se vleče čez pol foruma pa ga tolerirate...zbriši ga dol :!:
LGP, Centri
Objave: 1227
Teme: 38
Pridružen: Jan 2006
Ah, to ni nobena resna reklama...
Objave: 110
Pridružen: May 2005
Ne vem, zakaj zdaj toliko besa, ko sem samo napisal, kar se mi je dogodilo.
Sploh ni nobena reklama, ker takšne male vind turbine tudi jaz ne potrebujem in jih tudi ne bom, čeprav so prav idealne za jadrnice.
Zakaj samo meni očitate reklame, ko pa posamezniki pri vsaki temi navajajo Web naslove, kje lahko kaj kupiš. Napeljevanje na določene strani pa naj ne bi bila reklama? Če pa jaz napišem, kaj lahko pri Vigmi nabavite, pa je reklama?
Po mojem pa vsak, ki pride na ta forum želi izvedeti, kje in kaj bi lahko nabavil za svoje potrebe ali dobiti kakšen nasvet. Od koga pa naj dobi koristen nasvet, če ne od tistega, ki se na zadevo zares spozna? Borovničan je tu od sile, nas druge kar ozmerja z nevednostjo!
Wind turbine so moja osebna obsesija in sem želel le slišati, kaj ljudstvo o tem misli. Načelno pa ljudstva sploh ne rabim. Dva ali trije vidijo koristnost, drugi pa istak samo zavidljivo kritizirajo. Sicer sem pa se že odločil. 5 kW wind turbina na drogu, ki se da položiti, tako da bi dajala štrom samo pozimi, poleti pa bi bila na tleh, da se je ptiči in nekakšni naravovarstveniki ne bi bali. Dovolj vetrovno pa je tudi samo pozimi. Poglejte samo, kako cefra zastavo tam, kjer še niso podrli prvomajske smreke in to v dežju!
Seveda vem, da tudi najboljše vind turbine izkoristijo največ polovico moči vetra, ampak to sploh ni pomembno, ker že v tovarni izdelajo tako veliko, da pri deklarirani hitrosti vetra da nazivno moč.
Pa še to. Nobena atmosferska toplotna črpalka nima pri minus COP 4, ima pa tak COP dobro postavljena geotermalna toplotna črpalka. Solarni bojlerji pa se odlično obnesejo.
Pozdrav.
Objave: 1339
Teme: 26
Pridružen: Dec 2005
Vigma, pa ti bo elektro odjemal elektriko? Kaj pa papirji z elektrom, problem? Meni se zdi vetrnica odlična ideja. Edini problem je ta, da sem mogoče malo preveč velik estet. Vprašanje je, kako zgleda tak klopotec na strehi?
Drugače pa poskusi najti podatke o vetru, to je takoimenovana "vetrna roža", če se ne motim. Iz tistega boš dobil ven povprečno hitrost vetra v celem letu in psledično si lahko izračunaš tudi koliko energije boš ustvaril... tako okvirno.
Drugače pa ti samo reklamiraj... tisti ko ga interesira (kot sem jaz), bo pogledal, tisti ko pa ga ne interesira, pa pač ne. simpl.
Objave: 110
Pridružen: May 2005
[img]httpunichr("58")//wwwunichr("46")wind-sailunichr("46")com/wsImages/IMG_0902_3KW%20Closeup%20BESTunichr("46")JPG[/img]
Zelo zanimiva wind turbina, ki so jo skonstruirali ruski vojaški podmorniški inženirji z vertikalno osjo. Zdaj pripravljajo proizvodnjo, ne boste verjeli, v Ameriki!
Objave: 110
Pridružen: May 2005
LAKOTA wind turbina je trenutno najkvalitetnejša turbina te velikosti.
Pred drugimi ima te prednosti:
- s posebno patentirano tehnologijo deluje virtualno skoraj neslišno
- tehta le 17 kg in ima najboljše razmerje med močjo in težo
- kraki propelerja so le pri tej turbini narejeni iz karbonskih vlaken
- pri zelo močnem vetru se ne ustavi z zavoro, ampak se propeler premakne v vodoravni položaj in deluje še naprej.
- krake propelerja izberemo gleda na stopnjo vetrovnosti na terenu
[img]httpunichr("58")//wwwunichr("46")aeromaxenergyunichr("46")com/images/Installed%20WTGs/LAKOTA%20Skies012%20smallunichr("46")JPG[/img]
Objave: 414
Pridružen: Aug 2006
A si preveril število vetrnih dni v Sloveniji in potrebno minimalno hitrost vetra? Preverjeno je, da se vetrnice na našem področju NE izplačajo. Minimalna hitrost vetra je 3,2 m/s, št. dni v SLO z takšno jakostjo vetra pa je manj kot 25% na letnem nivoju. Naslednji problem je, da za vetrnice, ki imajo skupno višini več kot 12 m, kar tvoja vetrnica je, potrebuješ en kup dovoljenj, med drugim tudi od aviacije. skratka, POZABITE
čista energija
