PodSvojoStreho.net Opremljanje doma Kopalniška oprema kje kupiti malo lepši kopalniški ventilator
Iščem po netu in naletim samo na staro grdo klasiko...
Jaz bi kaj takega kot:
<!-- m --><a class="postlink" href="http://www.broan.com/display/router.asp?ProductID=649">http://www.broan.com/display/router.asp?ProductID=649</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.broan.com/display/router.asp?ProductID=100489">http://www.broan.com/display/router.asp ... tID=100489</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.broan.com/display/router.asp?ProductID=100527">http://www.broan.com/display/router.asp ... tID=100527</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.broan.com/display/router.asp?ProductID=100580">http://www.broan.com/display/router.asp ... tID=100580</a><!-- m -->
pa še <!-- m --><a class="postlink" href="http://www.hunterfan.com/product_detail.aspx?id=7830">http://www.hunterfan.com/product_detail.aspx?id=7830</a><!-- m -->
<!-- m --><a class="postlink" href="http://www.pax.se/eng_index.html">http://www.pax.se/eng_index.html</a><!-- m -->
ali
<!-- w --><a class="postlink" href="http://www.maico.de">www.maico.de</a><!-- w -->
dobri tihi, lep ventilator....dobi se v merkurju...
prednosti...lahko menjaš pokove,
pokrov enostavno spereš z vodo, ko se nabere umazanija....
module imaš...timer, vlagomer, ir senzor...itd
[url=httpunichr("58")//wwwunichr("46")shraniunichr("46")si/?1i/6H/3tscXLnj/airflowkatalogunichr("46")jpg][img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/t/1i/6H/3tscXLnj/airflowkatalogunichr("46")jpg[/img][/url]
[img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/f/3k/de/4imjCAK0/14032008-056unichr("46")jpg[/img]
[img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/f/1n/On/4GsCHBgG/14032008-059unichr("46")jpg[/img]
[img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/f/18/l5/3ORiaIdq/14032008-060unichr("46")jpg[/img]
[img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/f/1j/Oo/Xik5Ppq/14032008-062unichr("46")jpg[/img]
[img]httpunichr("58")//wwwunichr("46")shraniunichr("46")si/f/1W/wp/4HtTcI44/14032008-064unichr("46")jpg[/img]
pedenjdeklica,
morda vsaj okvirno poznaš ceno manjšega modela (s senzorjem vlage) ?
In če je poleg stenske možna tudi stropna montaža?
[url]httpunichr("58")//wwwunichr("46")vorticeunichr("46")it/defaultunichr("46")aspx?idPage=73&idInsieme=1937&idRigaSelezione=40[/url]
jaz imam Vorticovega, sam moj je podometen, tako da ven gleda le ličen pokrov
Zaspanc Napisal:pedenjdeklica,
možna je stropna, stenska itd montaža
ventilator stane malo čez 60 eur če se ne motim
senzor vlage je pa okoli 40 ??' ampak ne me za besedo prijet...
drugačen pokrov je okoli 25 eur.... .
itd...
mam ga doma in lahko pritdim da je špica (imam sredi hiše wc brez oken samo ta ventilator z timerjem 5 min...in je ok...
Ne držim za besedo, samo okvirno za lažjo predstavo me zanima.
Hvala.
ta ventilator je bil design award winer... in predvsem to ni iz kitajske kot airmate itd...
karantanka Napisal:[url]httpunichr("58")//wwwunichr("46")vorticeunichr("46")it/defaultunichr("46")aspx?idPage=73&idInsieme=1937&idRigaSelezione=40[/url]
In ko ti crkne, kaj boš potem?
cace, oprosti, ampak opazila sem, kako negativno gledaš na vse stvari. Pri večini postov si predstavnik nekih negativnih mnenj in pomislekov ...
Dnevi so sadeži in naša vloga je, da jih užijemo.
(Jean Giono, 1895--1970)
Ni negativno.
Reci raje praktično, da manj boli glava ko zadeva morebiti res crkne :wink:
s55ra Napisal:cace, oprosti, ampak opazila sem, kako negativno gledaš na vse stvari. Pri večini postov si predstavnik nekih negativnih mnenj in pomislekov ...
Pomisleke (oziroma dilemo) ima večina, ki odda svoje vprašanje na forum, se ti ne zdi? Če bi vedeli, za kaj se odločiti, najbrž nebi spraševali.
O neki stvari pa si vsak pač ustvari negativno ali pa pozitivno mnenje.
cace Napisal:
Zadeva je tako narejena, da lahko notranji del (motor ...) v celoti menjaš, tako da v tem, da je škatla podometna ne vidim problema.
karantanka Napisal:
cace Napisal:
Potem pa ni problema, če se da menjati. Pri nekaterih modelih je vse skupaj zalito s plastiko, tako da prav nič ne moreš zamenjati.
ne ta ventilator je cela zverina, tud ni bil najcenejši, sam sem si ga vseeno privoščila Smile
