Toplotna črpalka motenje posesti - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Energijski viri (https://podsvojostreho.net/forum/forumdisplay.php?fid=18) +--- Tema: Toplotna črpalka motenje posesti (/showthread.php?tid=77244) |
RE: Toplotna črpalka motenje posesti - Monitor - 23.1.2020 Tukaj je malo literature iz Velike britanije države. - TČ je umeščena napačno - TČ se lahko premesti, ker na nasprotni strani hiše ne bo nikogar motila. - Državni aparat, ki je servis občanov prelaga odgovornost eden na drugega https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/48204/3307-acoustic-noise-air-source-heat-pumps-1.pdf RE: Toplotna črpalka motenje posesti - Fery - 23.1.2020 Saj, realno gledano, podnevi ne bo nič dosegel. Pa če se razpoči od hrupa. Od 22 do 6, pa so pravila zelo jasna. In zrakomlat, niti ne nujno glasen, jih zagotovo krši. Tukaj bi se dalo marsikaj postoriti. RE: Toplotna črpalka motenje posesti - Monitor - 23.1.2020 https://www.dunedin.govt.nz/services/noise-control/heat-pumps With the increasing number of heat pumps being installed in Dunedin, there has been a corresponding increase in the number of noise complaints about the units. If installed inappropriately, they can cause sleep and amenity disturbance. Siting heat pumps Noise complaints are mainly due to the inappropriate location of heat pumps close to, and facing, neighbouring bedrooms and living areas. Before installing a heat pump you should consider the effects noise from the unit may have on yourself and your neighbours. Heat pumps should be as far away from your own and your neighbours' bedrooms as possible. The fan unit should face the boundary of the property furthest away from the adjoining residences, not towards windows or outdoor living areas of a neighbouring residence. Try to avoid mounting the pump on a wall and in particular at a high level, as this can result in unimpeded transmission of noise to neighbouring properties. If possible mount the heat pump at ground level and on a solid base, preferably a concrete pad or block. Use rubber pads between the unit and the base to eliminate vibration. Ensure that where refrigeration lines pass through walls, they have adequate clearance and insulation. Vibration from within walls can magnify noise levels beyond acceptable levels. Make use of fences and walls between you and your neighbour's home as these can help reduce the transmission of noise. If a nuisance eventuates, you may need other options such as acoustic barriers or acoustic treatment. Selecting a heat pump Installers and retailers have a community obligation to provide responsible advice and service to prevent noise nuisance. Discuss noise issues with your installer before the heat pump is installed. Ask for advice on the most appropriate size of unit for the area to be heated. Select the pump that is most suitable to prevent excessive operation times or load on the unit. Choose a heat pump with a low sound power level. The exterior sound power level will be specified on the side of the unit and will give you an indication on how noisy the heat pump will be outside your house. The higher the number the louder the heat pump unit will be. The sound power level is different from the sound pressure level. Maintenance of heat pumps Tonal type sounds, or sounds with a narrow frequency range, are common from rotating parts in units, such as fans and motors. These noises can greatly increase if you do not maintain your heat pump regularly to replace worn bearings or limited life parts before they fail. Loose screws in a metal casing are a common source of buzzing or rattling noises. When you have your pump installed, ask the installer to provide you with an appropriate maintenance schedule. Sound insulation methods There may not be enough space between residences for exterior heat pump units to be installed without causing noise problems. Noise may be directly transmitted to a neighbour's house wall, or indirectly from reflection off the wall of the house being heated, or a combination of both. Higher frequency sounds are readily reduced by structure, but lower frequency sounds may penetrate structures unless they are reduced at the source. If you are unable to locate the unit away from the vicinity of neighbour's rooms, some degree of noise control is usually necessary. We have a detailed handout called 'Heat Pumps and Noise Reduction' that describes some of the principles of noise control that can be employed to reduce noise from the heat pumps. Conceptually, a soundproof enclosure should provide a noise reduction of at least 5 decibels. If it is well constructed, you can be reasonably sure of a 10 decibel reduction, and you may be able to achieve a 15 to 20 decibel reduction. Noise rules Generally noise is measured at or within the boundary of any dwelling not on the same site. We will respond to noise complaints and determine if it is necessary to reduce noise emissions to ensure a reasonable level of noise is achieved. A failure to comply with Section 16 of the Resource Management Act 1991 may result in enforcement action being taken in accordance with the Resource Management Act 1991. Resource Management Act 1991 Section 16 of the Resource Management Act 1991 makes every occupier of land responsible for adopting the best practicable option to limit noise emissions from their property to a reasonable level. Dunedin City District Plan The District Plan contains noise maps that identify appropriate noise limits for different areas of the city during different times of the day. These limits are used to identify a reasonable level for noise emissions from heating and ventilation equipment. The District Plan noise limits are measured in dBA (L10), which is a sound pressure level with a frequency weighting that more closely approximates the response of the human ear to sound. While District Plan maps should be used to precisely determine the reasonable level of noise for an area, indicative noise limits are provided in the table below. City Area Day-time (7.00am to 9.00pm) Night-time (9.00pm to 7.00am 24 hours on Sundays & statutory holidays) Shoulder period (7.00am to 8.00am Monday to Friday 6.00pm to 9.00pm Monday to Saturday) Inner Suburbs 50 or 55 dba 40 dba 45 dba Outer Suburbs 50 dba 35 dba 45 dba City Centre 60 dba 60 dba n/a Rural 55 dba 40 dba n/a RE: Toplotna črpalka motenje posesti - csamo001 - 23.1.2020 (23.1.2020 ob 00:01)Monitor Napisal: Tukaj je malo literature iz Velike britanije države. Saj verjamem, da te moti sosedova TČ. Ampak z vsakim nadaljnim takšnim vpisom si vse bolj podoben ipičnemu otroku in vedno manj verodostojen. Ker kje točno piše, da je sosedova TČ umeščena napačno? Ostali dve alineji pa sta tvoje mnenje, nič drugega. Državni aparat je npr. res servis občanov, ampak, če noben veljaven predpis ali zakon Republike Slovenije ni kršen, potem nima državni aparat kaj za posredovat. In kaj točno bi rad dosegel z limanjem tega, kar se dogaja na Novi Zelandiji? Raje tukaj poglej, če se dejansko kje kršijo tvoje pravice, vključno s prilogami: https://www.uradni-list.si/glasilo-uradni-list-rs/vsebina/2018-01-2127?sop=2018-01-2127. Bi pa od nekoga, ki ga sosedova toplotna črpalka tako moti, kot praviš, da te, pričakoval, da je zakonodajo že zdavnaj preštudiral. Pa si jo? RE: Toplotna črpalka motenje posesti - matofill - 23.1.2020 Znanec je imel identično težavo, sosed je svoje puhalo postavil 70 cm od meje, tako, da je pihalo v njegov prostor in ropotalo, pa še trdil, je, da če lahko ograjo postavi 60 cm od meje brez soglasja lahko tudi ropotuljo .... Je bil kreg več mesecev, nato je znanec, na bolhi kupil staro satelitsko anteno precej veliko 180 cm v bistvu samo krožnik z nosilci ...... No to parabolo je montiral na svojo stran meje obrnjeno , k sosedu....., sosed , se je na enkrat začel močno pritoževati, nad hrupom, ki mu ga je znanec samo odbijal ...... sedaj je ene pol leta mimo, sosed pravi da bo morda po sezoni malo prestavil toplotno črpalko...... parabola je pa še vedno..... RE: Toplotna črpalka motenje posesti - Blue30 - 23.1.2020 Vem za primer v prlekiji, ko so morali zadevo rešiti zaradi soseda. @Monitor Če daš delati uradne meritve, če vzameš odvetnika, če narediš bilokaj, te bo vse stalo $$$. Če res ne gre z narezkom in steklenico vina, odkartaj teh €500, da boš imel mir. Sicer pa kam bi potem prestavil kišto? A že prej nista govorila s sosedom ali je kak starejši zatežen gospod ali je njegova bivša zdaj pri tebi? Res neverjetno, da se soseda ne bi mogla zmenit..si ne znam predstavljat. RE: Toplotna črpalka motenje posesti - bohinc - 23.1.2020 Jaz nekdaj tudi ne... Kar je TČ na vasi skregala prej dobre odnose v žlahti, ter ni več možnega dialoga , me ne preseneča več... Tudi težko je prek palca soditi, kdo ima bolj prav.... V primerih prekomernega hrupa oškodovanci... vendar zna stati .... RE: Toplotna črpalka motenje posesti - sassapo - 23.1.2020 (23.1.2020 ob 06:10)Blue30 Napisal: Vem za primer v prlekiji, ko so morali zadevo rešiti zaradi soseda. Vse se da, če se le hoče. Se mi pa zdi, da je te volje, predvsem med mladimi občutno manj kot včasih. Mi, smo se in se še vedno, vse zmenimo. Ps. Brez pira, ali karkoli že, pa jasno ne gre
RE: Toplotna črpalka motenje posesti - Homer - 23.1.2020 Saj je komentiranje odveč...... On si je "dal v glavo", da mora TČ biti na drugi strani hiše in ne pristaja na noben kompromis ali dogovor, kaj šele da bi soseda povabil na en prigrizek in pir ter poiskala nek kompromis. In ko štartaš enkrat na nož, bo druga stran nehala pogovor Zahteva preselitve na drugo stran pa lahko pomeni tudi še pa še razbijanja po hiši, kar pa sosed ne more pristati. Skratka popolno tišino ne more zahtevati, ker je ta morda bila preden so avtomobili in delovni stroji začeli z vožnjami skozi naselje. RE: Toplotna črpalka motenje posesti - Fery - 23.1.2020 Ponoči lahko z lahkoto zahteva netuljenje sosedove TČ zraven svoje bajte. V to sem ziher. Prav se je treba lotiti in bo. RE: Toplotna črpalka motenje posesti - peleti12 - 23.1.2020 (22.1.2020 ob 08:55)Monitor Napisal: a) Sosed ni za dialog. monitor Kako je lahko sosed in s čigavim soglasjem postavil hišo 1m od meje? Kako je lahko med hišo in mejo postavil še toplotno črpalko? Dvakrat ste očitno šli na led! Sdaj vam ne ostane drugega kot, da sprožite postopek motenja posesti, ker se sosed ne drži pravil vi mu pa še to omogočate. Iščete rešitve šele ko so problemi nastali in ne preden bodo nastali! Tukaj sti dve rešitvi ali pravna pot ali pa 2m visoka ograja na meji! RE: Toplotna črpalka motenje posesti - bozgom - 23.1.2020 @peleti12 kako pa veš, katera hiša je stala prej in kdo je komu kaj dovolil? Pa kje obstaja kak zakon/uredba/predpis... da kjerkoli na svoji parceli ne smem postavljati kakšno stvar, ki ni gradbeni objekt, če s tem ne posegam v zračni ali podzemeljski prostor sosednjih parcel? PS poznam pa človeka, kateri se je obregnil ob kapljice katere so ob dežju padale s kape na škarpi na njegov travnik tam 20 m od hiše. RE: Toplotna črpalka motenje posesti - Poldee - 23.1.2020 Brez komentarja. Nobenga ne zebe, to je. RE: Toplotna črpalka motenje posesti - pomagač - 23.1.2020 Tale hrup se pa vleče kot ena kača... Nisem vsega prebral, vendar, ker gre za strnjeno naselje, kar gradnja hiš je, dovoljen hrup na meji ponoči ne sme preseči 40becibelov in pika. Iz tega naj avtor izhaja in fura zadevo dalje. Kako, smo pa že napisali. RE: Toplotna črpalka motenje posesti - bozgom - 23.1.2020 (23.1.2020 ob 17:38)pomagač Napisal: Tale hrup se pa vleče kot ena kača... Nisem vsega prebral, vendar, ker gre za strnjeno naselje, kar gradnja hiš je, dovoljen hrup na meji ponoči ne sme preseči 40becibelov in pika. Iz tega naj avtor izhaja in fura zadevo dalje. Kako, smo pa že napisali. Lahko linkaš zakon/predpis/uredbo kjer je to navedeno? PS- verjetno bomo lahko zaprli kar vse ceste po državi. |
