Nastavitev Normstahl ultra pogona - Print verzija
+--- Tema: Nastavitev Normstahl ultra pogona (/showthread.php?tid=85912)
Nastavitev Normstahl ultra pogona - SGrega - 23.10.2025
potrebujem pomoč. prestavil sem garažna vrata za 50cm ven in zato sem prestavil tudi pogon.
Po montaži se vrata niso pravilno odpirala in zapirala (zaprla so se do polovice in tudi odprla do polovice).
Pregledal sem vse možne spletne strani, vprašal chatGPT, pogledal youtube video, ampak vrata se odpirajo in zapirajo čisto na random in po svoje.
Ima mogoče kdo izkušnje s tem pogonom ali pa kakšna dejansko uporabna navodila (Normstahl nima nič).
V prilogi je slika mojega pogona.
RE: Nastavitev Normstahl ultra pogona - fizikalec15 - 24.10.2025
Cardo door ultra manual.
Je Google našel navodila v slovenščini.
RE: Nastavitev Normstahl ultra pogona - SGrega - 24.10.2025
(24.10.2025 ob 08:19)fizikalec15 Napisal: Cardo door ultra manual.
Hvala lepa. Očitno sem bil preveč osredotočen na Normstahl, ampak je očitno proizvajalec drug, Normstahl pa ima samo nalepko gor.
RE: Nastavitev Normstahl ultra pogona - KylieGray - 22.11.2025
Hi Greg,
the displacement of the garage door by 50 cm caused the Normstahl Ultra Drive to lose its reference body before the full opening and closing. That's why the doors move randomly or get stuck in patterns. Here are a few steps that often help:
  1. Reset the drive to factory settings to delete old limits.
  2. Again set the limits before opening and closing according to the panel on the unit so that the motor knows exactly where to stop.
  3. Check the force or torque setting. If it is too low or high, it can cause uncontrolled movement.
  4. Make sure the door is balanced correctly. Improper weight or springs can cause malfunctions.
  5. Check whether the drive is flush with the door skin. A small shift can trigger wild behavior.
