Projektant okolica Celja, Žalca - Print verzija
+--- Tema: Projektant okolica Celja, Žalca (/showthread.php?tid=85228)
Projektant okolica Celja, Žalca - Samec2329 - 19.2.2025
Člani ste se zagotovo srečali z projektanti/arhitekti s katere oni ste bili zadovoljni v smislu projektiranja/ rešitev in navsezadnje tudi cene. Gre za projekt manjše pritlične hiše klasične gradnje 120m2 v okolici Žalca.
Hvala za predloge in priporočila,
Lep pozdrav
RE: Projektant okolica Celja, Žalca - som16 - 21.2.2025
Samec2329,
si že našel projektanta??
Imaš kar nekaj birojev in projektantov.
RE: Projektant okolica Celja, Žalca - Samec2329 - 21.2.2025
Ne zaenkrat še ne, vem da jih je veliko, ampak iščem tudi po sistemu priporočil in dobrih izkušenj z njimi.
RE: Projektant okolica Celja, Žalca - garagelipstick - 27.10.2025
I understand that you need an expert. I will be happy to help you find the right person
RE: Projektant okolica Celja, Žalca - garagelipstick - 28.10.2025
I understand that you need an expert. I will be happy to help you find the right person. Contact me: ragdoll hit@gmail.com
RE: Projektant okolica Celja, Žalca - barlowlouiz - 21.11.2025
Hello,
I would recommend looking into local architectural firms or designers in the Žalec area who have experience with single-storey houses of similar size. A good approach is to check references from previous projects and ask about the price range. It is also advisable to ask acquaintances or neighbors who have built similar houses, as personal experience often helps a lot in choosing a reliable designer.
Kind regards.
RE: Projektant okolica Celja, Žalca - Anthona - 25.12.2025
I would be happy to recommend that you contact local architectural firms in the Žalec area that have good reviews. You can also check online platforms where clients share their experiences with various designers.
drive mad
Greetings!
