Kovinoplastika Lož - maloprodaja - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Stavbno pohištvo (https://podsvojostreho.net/forum/forumdisplay.php?fid=15) +--- Tema: Kovinoplastika Lož - maloprodaja (/showthread.php?tid=83180) |
Kovinoplastika Lož - maloprodaja - gugl - 14.2.2023 Zdravo, ali ima kdo kakšno informacijo, katere trgovine imajo maloprodajo okovja za polkna od Kovinoplastike Lož? Rabil bi namreč daljši nosilec (da pride skozi izolacijo do opečnega zidu), ki na steni drži odprto polkno (pritrdilec za polkno ali kako se imenuje). Hvala RE: Kovinoplastika Lož - maloprodaja - kadotr - 15.2.2023 Telefoniraj v Kovinoplastiko... RE: Kovinoplastika Lož - maloprodaja - cinnamoncowardice - 2.6.2026 (14.2.2023 ob 15:05)gugl Napisal: Zdravo, @dino game Najprej se splača preveriti pri Kovinoplastika Lož oziroma njihovem prodajnem oddelku. Pogosto lahko povedo, kateri trgovci imajo njihove izdelke na zalogi ali pa naročijo točno določen kos. RE: Kovinoplastika Lož - maloprodaja - Krowncrafts01 - 9.10.2026 Heavy metalworking and custom fabrication projects require serious focus, especially when you're comparing detailed retail specs and dimensions. Whenever my brain feels completely fried from looking through technical datasheets, taking a quick mental break with https://theidlebreakout.com helps clear my head before jumping back into the specs. RE: Kovinoplastika Lož - maloprodaja - jakabaesj3 - 14.10.2026 (9.10.2026 ob 03:43)Krowncrafts01 Napisal: Heavy metalworking and custom fabrication projects require serious focus, especially when you're comparing https://www.doberavto.si/nasveti detailed retail specs and dimensions. Whenever my brain feels completely fried from looking pohištvo po naročilu through technical datasheets, taking a quick mental break with helps clear my head before jumping back into the specs. Heavy-duty shutter stays mounted into hollow brick require chemical injection anchors rather than standard expansion plugs for long-term hold |
