Pritrjevanje lesa na kontaktno fasado - Print verzija
+--- Tema: Pritrjevanje lesa na kontaktno fasado (/showthread.php?tid=82339)
Pritrjevanje lesa na kontaktno fasado - wooly - 19.7.2022
We currently have a ~25 cm contact facade under construction on our newly built house
We want the ceiling of the overhanging terrace (1000x200cm) to be light
We have Siberian larch boards available 400x10x2.3 cm
We are getting conflicting advice from Fasader and others. What is the best way to attach the boards to the ceiling? Should there be a wooden frame under the outer layer? Do we need to attach the boards to the concrete with very long screws? are  styrofoam inserts enough? is glue an option?
