Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - Print verzija
+--- Forum: Ostalo (https://podsvojostreho.net/forum/forumdisplay.php?fid=23)
+--- Tema: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? (/showthread.php?tid=75496)
Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - drozmarin - 13.5.2019
ali ima kdo izkušnje z nakupom laserja križnega, samonivelirnega oz. z 3. osmi, preko spleta in sicer na Aliexpress-a? Ali podobne spletne strani.
Verjetno je zadeva dovolj dobra za navadnega smrtnika, ali?
Gledam to:
- [url]httpsunichr("58")//wwwunichr("46")aliexpressunichr("46")com/item/Green-laser-level-360-3d-12-lines-rotary-self-leveling-red-laser-beam-lines-tools-cross/32959502986unichr("46")html?spm=2114unichr("46")search0104unichr("46")3unichr("46")69unichr("46")24072800BwZ58x&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_10301_10821_537_536,searchweb201603_52,ppcSwitch_0&algo_expid=f66b330e-211e-4233-a51c-3dac2ec950a1-9&algo_pvid=f66b330e-211e-4233-a51c-3dac2ec950a1&transAbTest=ae803_3[/url]
- [url]httpsunichr("58")//wwwunichr("46")aliexpressunichr("46")com/item/HILDA-Laser-Level-12-Lines-3D-Level-Self-Leveling-360-Horizontal-And-Vertical-Cross-Super-Powerful/32996538623unichr("46")html?spm=2114unichr("46")10010108unichr("46")1000014unichr("46")2unichr("46")592b4930TtQoDA&gps-id=pcDetailBottomMoreOtherSeller&scm=1007unichr("46")13338unichr("46")128125unichr("46")0&scm_id=1007unichr("46")13338unichr("46")128125unichr("46")0&scm-url=1007unichr("46")13338unichr("46")128125unichr("46")0&pvid=92819f93-918e-4f11-bcfb-54511e13b7c8[/url]
- [url]httpsunichr("58")//wwwunichr("46")aliexpressunichr("46")com/item/KaiTian-12Lines-3D-Laser-Level-Self-Leveling-360-Degre-Horizontal-Vertical-Cross-Powerful-Level-Laser-Tool/32973306442unichr("46")html?spm=2114unichr("46")10010108unichr("46")100009unichr("46")1unichr("46")71f04015OvzSsl&gps-id=pcDetailLeftTopSell&scm=1007unichr("46")13482unichr("46")95643unichr("46")0&scm_id=1007unichr("46")13482unichr("46")95643unichr("46")0&scm-url=1007unichr("46")13482unichr("46")95643unichr("46")0&pvid=e78f9652-2eb8-48ac-aaf9-3c6b73312063[/url]
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - darkside - 13.5.2019
Sem v eni drugi temi tudi sam o tem spraseval. Sicer za manjso vsoto pa sem prisel do zakljucka da bom raje vzel boschev. Ce gledam da orvi stane 100 eur in moras se potem pri nas placati je le par eur razlike glede na boscha.
Se pa nagibam na bosch professional ki me z nemcije ceneje stane kot tukaj
Poslano z mojega SM-N950F z uporabo Tapatalk
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - arbajter - 13.5.2019
Ne kompliciraj z nekimi aliekspresi in vzemi doma Boscha:
<!-- m --><a class="postlink" href="https://www.ceneje.si/Izdelek/4078000/orodje-in-stroji/rocno-orodje/kompleti-rocnega-orodja/bosch-linijski-laser-pll-360-set">https://www.ceneje.si/Izdelek/4078000/o ... ll-360-set</a><!-- m -->
Tudi v Merkurju ali drugje ni nič dražji. Če odmisliš kake cirkuse z poštnino (pa garancijo tudi) ali našo glupo carino sploh ni za premišljevat.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - opt - 14.5.2019
Ga imam tudi sam, in lahko samo potrdim zgornje pisanje.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - drozmarin - 14.5.2019
Ja ampak ti ko imajo 3 laserje not oz. da lahko pokrivajo cel prostor, ti stanejo nad 400 EUR. Želel bi da dobim linijo na tleh in pravokotnico na njo. da imam na tleh pokritih cca 12m linije, in to je težko doseči z drugim laserjem, ali?
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - T0RN4D0 - 14.5.2019
Zelenega boscha jst ne bi. Kako je s temi kitajci ne vem, za preverit je pred uporabo ce so tocni. Ker ce se ne mores zanest na tocnost je taksno orodje neuporabno.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - darkside - 14.5.2019
@drozmarin: v drugi temi smo prišli do tega da je bolje profesionalnega
pa še primerjava cen:
[url=httpsunichr("58")//wwwunichr("46")mimovrsteunichr("46")com/laserji-libele-vodne-tehtnice/bosch-linijski-laser-gll-3-80-professional-0601063s00]KLIK[/url] brez stojala
[url=httpsunichr("58")//wwwunichr("46")rubartunichr("46")de/Bosch-Linienlaser-GLL-3-80--mit-Handwerkerkoffer-06159940KD-p10151034?utm_medium=cpc&refID=106&utm_source=idealo_de]KLIK[/url] s stojalom
čeprav osebno se bolj nagibam na to, da bi vzel s teleskopsko palico. nisem pa še nabavil.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - ophidian - 15.5.2019
zeleni bosch no go, sem testiral 2 različna kosa PLL360, in laserji z oddaljenosto od centra različno višino kaže.....laser je v obliki dežnika. Pri obeh. Tu pri nerotacijskih je prisma, ki pač ima svoje optične defekte, ki jih ni možno skalibrilat.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - Matjaz_V - 15.5.2019
OK, koliko pa je pri 360-ki tega odstopanja in na kakšni razdalji?
Citat:Verjetno je zadeva dovolj dobra za navadnega smrtnika, ali?
Najbolj je odvisno, za kaj ga rabiš. Npr. pri naši obnovi prastare hiše (letnik 37) se odvadiš gledat na vsak milimeter. Boljše spiš.
Jaz ga imam ("marelastega" Boscha) in mi je kar veliko pomagal pri delu. Eden boljših nakupov. Edino razočaranje je, ko ga poskusiš uporabiti zunaj ob dnevni svetlobi, ampak o tem sem pred nakupom že nekaj prebral in nisem bil presenečen.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - pentax - 15.5.2019
Tega Boschevega GLL 3-80 je imel knaufar pri meni...zelo uporabna zadeva. Je rekel da je preizkusil tri različne laserje in na koncu pristal na temu. Ni pa poceni, tako kot je ponavadi pri vseh teh zadevah.
ja, na koncu sem gledal GLL2-80. Potem nisem kupil nič od Boscha, ampak navadnega križnega iz hoferja za 34€. Začuda kaže točno (+/-1mm) kamorkoli in kakorkoli sem si reference naredil z vodno cevko.
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - Fery - 15.5.2019
Ne vzamem čip orodja, pa če ga za mano vržeš.
Zadnjič se nas je polno drenalo na bajti, štromar edini z Ryobi mašinami. Zgledal je kot klošar. Takemu ne bi zaupal niti žarnice zamenjati.
Btw, zaradi takih laserjev sem že balkonca dal gratis. Dvokrilnega, pič... mat...
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - ex5522 - 15.5.2019
Pri zadevah, ki naj bi bile natančne in precizne, kot so recimo laserji se le tega NE KUPUJE na bolšjaku ali na aliexpresu !
Tam se kupujejo stvari, kjer to NI glavna lastnost produkta oz je to sekundarnega pomena
Re: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - grega09 - 16.5.2019
ophidian Napisal:zeleni bosch no go, sem testiral 2 različna kosa PLL360, in laserji z oddaljenosto od centra različno višino kaže.....laser je v obliki dežnika. Pri obeh. Tu pri nerotacijskih je prisma, ki pač ima svoje optične defekte, ki jih ni možno skalibrilat.
Zanimivo. Jaz sem ga kupil (tistega s stojalom). Potem ga malo uporabljam (nič hudo natančnega) in pred kratkim naletim na temo tu na forumu o odstopanjih tega laserja (ponovljivost pri premikih, efekt dežnika, itd.) in sem se odločil da ga preverim.
Postavil sem ga 1 m od ene stene in 5 m od druge. Potem sem kontroliral različne točke na liniji s šlaufvago. O efektu dežnika ni bilo zaznati nič, prav tako se pri premikih laserja (sem ga parkrat ruknil in vrgel iz položaja in počakal, da se umiri) ne pozna za več kot +-1 mm ali pa še manj. Za gradbena dela težko zaznavna odstopanja. Še posebej pri veliko naših "gradbincih", ki jim je +-5 cm že v redu. Big Grin
Seveda pa to spada pod malo bolj delikatna orodja in če pride do malo močnejših udarcev, ga je dobro preveriti. Pa premikati ga je treba ugasnjenega, da se zaklene in ne niha.
RE: Samonivelirni laser, 3D laser, - Aliexpress - izkušnje? - H20 - 26.12.2019
Mene pa zanima ali mora biti sprejemnik od istega proizvajalca kot je laser ali lahko kupš katerega koli in deluje? Potrebujem za gradbena dela...
