Skupina ogrevalnega kroga - Print verzija
+--- Tema: Skupina ogrevalnega kroga (/showthread.php?tid=64412)
Skupina ogrevalnega kroga - selassie1 - 1.2.2016
mene pa zanima ce je nujno potrebna Skupina ogrevalnega kroga DN 25 ki stane 1 kos 600€, imel bom pa pec na drva kwb classicfire 18kw? Zanimam se pa zato ker so mi eni monterji naredil ponudbo z tem sistemom, v drugih ponudbah pa tega ni vkljucenega. Prilozene imate tudi obe ponudbe istega proizvajalca. Hvala za razlago
1. ponudba:
[url=httpunichr("58")//postimgunichr("46")org/image/6j7rcwk5x/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/6j7rcwk5x/Binder1_Page_1unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/51mb1cff9/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/51mb1cff9/Binder1_Page_2unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/ffn4ul05x/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/ffn4ul05x/Binder1_Page_3unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/hvoy8fi8l/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/hvoy8fi8l/Binder1_Page_4unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/7x3zly8t1/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/7x3zly8t1/Binder1_Page_5unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/e30ueydcl/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/e30ueydcl/Binder1_Page_6unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/k58h5g1sl/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/k58h5g1sl/Binder1_Page_7unichr("46")jpg[/img][/url]
2. ponudba:
[url=httpunichr("58")//postimgunichr("46")org/image/5mjpn026t/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/5mjpn026t/Ponudba_160008_NA_KLJU_1_Page_1unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/jk6h61pn9/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/jk6h61pn9/Ponudba_160008_NA_KLJU_1_Page_2unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/j4qlzaec5/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/j4qlzaec5/Ponudba_160008_NA_KLJU_1_Page_3unichr("46")jpg[/img][/url]
[url=httpunichr("58")//postimgunichr("46")org/image/m08ajw7px/][img]httpunichr("58")//s18unichr("46")postimgunichr("46")org/m08ajw7px/Ponudba_160008_NA_KLJU_1_Page_4unichr("46")jpg[/img][/url]
Re: Skupina ogrevalnega kroga - kucin - 1.2.2016
Ne vem no, ko sem jim jaz pošiljal za predračune za KWB peč na pelete sem dobival nenormalno visoke cene, skratka mam občutek da na ta KWB vsi "pljačkajo" od uvoznika v Šempetru sploh pa do monterjev...katastrofa!Verjamem da so peči dobre, samo da mi zaračunajo pol še 2000 EUR za premontažo iz kurilca na to peč ( v bistvu samo premontirat dve cevi iz prejšnje peči na novo peč, ostalo vse ostane) in potem še nek zagon za 600 EUR to pa je višek.Skratka "odjebal" sem jih.
Re: Skupina ogrevalnega kroga - vrtalnik - 1.2.2016
Nič ni nujno potrebno.
Lahko vzameš sete od seltrona,ki so cenejši za cca 120 eur po kosu.
Ali pa ti mešalne kroge naredi monter,vendar ne zgleda tako lepo,čas montaže pa tudi stane.
Re: Skupina ogrevalnega kroga - aoven - 2.2.2016
14 jurjev za kotlovnico na drva... Pri čemer polovico vzame samo peč. In po tvojem je to ugodno!? Za pograbit z vsemi štirimi!?? Confusedhock:
No, morda sem kaj spregledal... A ima zlato prevleko?
Aja, pa monter si... To je pa drugo.
Citat:Je pa dobro če se v te stvari razumeš
Ah, saj nekaj malega pa razumem: dober posel mora bit tole!
Osebno si služim kruh povsem v drugi sferi, ampak vseeno vem, kdaj bi tako zagreto zagovarjal rešitev, ki je objektivno gledano povsem predraga. Jasno kdaj: kadar bi imel kaj od tega v zakulisju.
@zdravapamet: Sicer moram priznati, da so mi tvoje objavljene slike izvedb kotlovnic zelo všečne... A če mi tukajle hočeš reči, da nimaš pri nabavi tako dragega kotla nič koristi (če ga tudi ti montiraš), potem mi pa ni več nič jasno. Dober in izkušen (da ne dodam še korekten) monter/izvajalec bi moral stranki tudi svetovati, kje lahko brez bistvene degradacije rezultata največ prihrani! Ti si pa naredil tukaj ravno kontra. Rekel si: pograbi, ker je ponudba "once in a lifetime", da ne rečem malodane v stilu "neverjetno, a so pijani, da tako pod ceno dajejo!?".
Še enkrat: nič osebnega nimam proti tvojim prikazom izvedb - zdijo se mi profesionalne. Ampak če bi moral za tako izvedbo preplačati nekaj tisoč evrov (kao pri materialu), bi bil pa resno razpi*den! Profi izvedba mora biti všteta v originalni ceni in renomeju izvajalca, ne pa skrita za dragim materialom.
Se bom tukaj ustavil, ker ti ne želim delati krivice. Moja glavna kritika je, da se ponudba kot taka prikazuje kot blazno ugodna, ko pa to zelo očitno ni. Morda je med vami monterji "poznavalci". Ampak kaj pa stranka ve o tem? Samo to, kar ji ti poveš.
Re: Skupina ogrevalnega kroga - Hanzi - 2.2.2016
Pogojno bi sprejel ce ti dajo 6 let garancije in servisiranja (letni pregled).
Sicer sem preprican da imas v rangu od 10-15 jurjev ponudb kolikor zelis. Tudi za mercedes kotle.
Ponudbe za Čehe in slovake se pa gibljejo globoko pod 10 jurji. (s kolektorji da ne bo pomote)
Re: Skupina ogrevalnega kroga - Muzkontar - 2.2.2016
Mimogrede, kakšna pa je hiša, kjer bo ta kurilnica?
Če je to starejši in slabše izoliran objekt, mogoče raje razmisli, da investiraš npr. v toplotno izolacijo (fasada, okna, streha,...).
V tako pripravljen objekt boš lahko po tem posegu dal precej cenejšo napravo.
Tukaj moras imeti se kurilnico veliko vsaj 10m2 da spravis vse notri (2 zalogovnika, bojler, velika pec.
Re: Skupina ogrevalnega kroga - sašo65 - 2.2.2016
zdravapamet Napisal:Tako ponudbe berejo naivni in neuki ljudje. Na žalost jih je kar veliko.
na splošno žalost, pa na "tvojo" (in tebi enakim) srečo.....ovce so za striženje_že od nekdaj...
Re: Skupina ogrevalnega kroga - bk9105 - 2.2.2016
Ena opazka iz moje strani, zakaj se peči in zalogovnike, ki imajo oboji 6/4 priključke, povezuje s colskimi cevmi?
Kdo pa to počne? Jaz imam zalogovnik in peč povezana z DN 32.
Re: Skupina ogrevalnega kroga - sassapo - 2.2.2016
Hm... največjo bučko je napravil moj bežni znanec ko je na eni od najboljših lokacij za sistem voda voda v sloveniji. Na nekaterih lokacijah v Polzeli je temp. talnice vseskozi med 16 - 17°C. Ni pomagalo nobeno prepričevanje in tudi, če bi mu dal pisno, da mu povrnem vso investicijo če ne bo super zadovoljen! Ne, tukaj je človek investiral skoraj 18k€ v kotlovnico na trdo kurivo in 5 kolektorjev. Kuri svojega Frolinga in uživa, čeprav se zaveda, da bi bila investicija v TČ precej nižja in obratovalno ugodnejša.
Ljudje smo si pač različni, eni si s prihranki kupijo avto, drugi naredijo kotlovnico :lol:
Smem vprašat, kolikšen del te cene so kolektorji in potrebna podpora?
Pa pustimo EKO sklad ob strani, ker je večinoma le reklamna poteza. V večjih občinah ni v praksi več prav nobene šanse za subvencijo pri kotlih na drva in TČ, zaradi obstoječega toplovoda, plinovoda ali plana zanju.
Komur gre skozi, pa seveda super!
Re: Skupina ogrevalnega kroga - mišek2014 - 2.2.2016
To velja za mestne občine, vse ostalo ni problem.
Kolektorje in podporo ocenjujem na tri jurje do 4 jurje (z montazo).
Kako je z attack garancijo. Slovenska, Slovaška, tvoja?
Precej podoben sistem je moj,(attack in 6 kolektorjevl s tem da nimam wdc in da imam zunanji izmenjevalec in locen bojler, ker ob izdelavi zalogovnika nisem našel pametne resitve za spirale v njem.
Vem pa koliko me je zadeva stala (s kotlom kupljenim na Slovaškem). Sedaj se dobijo tudi kombinirani zalogovniki za pametno ceno. Pred tremi leti sem ga pa dal narediti, ker sem dobil poceni material. Upam da bo dolgo zdrzal (6mm plocevina namesto 3-4mm). Danes bi nekaj stvari spremenil, sicer pa zadovoljen. Nekoc jih mogoce bom.
