Kemamix F for facade? - Print verzija
+--- Tema: Kemamix F for facade? (/showthread.php?tid=61154)
Kemamix F for facade? - Sarah1984 - 21.3.2015
Hello,
I want to renovate the facade of my old house without outside insulation. I am experimenting a bit with kemamix F.[url]httpunichr("58")//wwwunichr("46")kemaunichr("46")si/si/vsebina/produkti/po-produktnih-skupinah/gotovo-pripravljeni-ometi-in-malte/70[/url]
On the bag is written that it can be used outside, there is also a rain and frost icon. But, on the technical data sheet, It is written that it must be protected against unfavourable weather conditions. I don't get it!
So, actually, it is not suitable for outside use without extra protection? What should I do now?
- use kemamix F and extra protection, which?
- use something else, what?
thank you for responding!
Re: Kemamix F for facade? - gremlin - 21.3.2015
It should be protected while installing and until dry.
Take technical document in English language:
<!-- m --><a class="postlink" href="http://portal.kema.si/session/kema_pdf.cfm?lang=EN&doc=TL&product=Mix_f">http://portal.kema.si/session/kema_pdf. ... duct=Mix_f</a><!-- m -->
It is stated:
KEMAMIX F fine plaster has to be cured in the same manner as other facade surfaces and protected against unfavorable weather conditions (most frequently classical protective curtains are used).
Fine mortar needs for hardening adequate quantity of water, therefore avoid direct sun and strong wind during thehardening. Surface is protecting with protective curtain or moistening with water. Avoid also working when is raining.
Re: Kemamix F for facade? - Sarah1984 - 21.3.2015
ok, :wink:
protected while working with it, now I get it. With "most frequently classical protective curtains" I understood some primer or paint or whatever. English is not my first language :?
So, no primer or water-proof paint needed after Kemamix F?
No.
Most frequently classical protective curtains:
RE: Kemamix F for facade? - MaryHayes - 3.4.2020
An injection is done for al compilers of the field. The approval of the turns and https://awriter.org/writemyessays-net-review/ is ensured for the signals for the room. The turnips done for all humans. Use is done for the top stories of citizens and pupils.
