Toplotno sevanje in temperature ovoja stavbe - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Energijski viri (https://podsvojostreho.net/forum/forumdisplay.php?fid=18) +--- Tema: Toplotno sevanje in temperature ovoja stavbe (/showthread.php?tid=59190) |
Toplotno sevanje in temperature ovoja stavbe - janipapillon - 6.12.2014 Ni direktno na temo, je pa za predstavo o toplotnem sevanju. Posnel sem meritve: Popoldne je bilo na Rakitni 1,7 stC <!-- m --><a class="postlink" href="http://www.wunderground.com/personal-weather-station/dashboard?ID=IRAKITNA2#history/tdata/s20141206/e20141206/mdaily">http://www.wunderground.com/personal-we ... 206/mdaily</a><!-- m --> Pozno dopoldne sem zakuril v temle 7,2 kW šporhetu <!-- m --><a class="postlink" href="https://picasaweb.google.com/janipapillon/THEBIGGESTHOBBYINMYLIFEBuildingMyLogHome#6089764468644839634">https://picasaweb.google.com/janipapill ... 8644839634</a><!-- m --> Njegova pozicija v 600 m3 velikem prostoru je vidna v prvih 20sekund tega video posnetka: <!-- m --><a class="postlink" href="https://picasaweb.google.com/janipapillon/THEBIGGESTHOBBYINMYLIFEBuildingMyLogHome#5972711878638785058">https://picasaweb.google.com/janipapill ... 8638785058</a><!-- m --> Temperatura v prostoru je bila 11,26 stC <!-- m --><a class="postlink" href="https://picasaweb.google.com/janipapillon/THEBIGGESTHOBBYINMYLIFEBuildingMyLogHome#6089768037397841890">https://picasaweb.google.com/janipapill ... 7397841890</a><!-- m --> Kaj meniš, koliko je bila temperatura notranjega stekla troslojne zasteklitve 4/16/4/16/4, Argon, z enim nizkoemisijskim nanosom? <!-- m --><a class="postlink" href="https://picasaweb.google.com/janipapillon/THEBIGGESTHOBBYINMYLIFEBuildingMyLogHome#6089765770197688050">https://picasaweb.google.com/janipapill ... 0197688050</a><!-- m --> Re: IR grelni paneli - sebastjan704 - 6.12.2014 cca 10 stC Re: IR grelni paneli - janipapillon - 9.12.2014 janipapillon Napisal:Ni direktno na temo, je pa za predstavo o toplotnem sevanju.Pričakujem, da še kdo komentira, izračuna, ugiba okrog meritev. Re: IR grelni paneli - medo9 - 9.12.2014 Premalo podatkov :twisted: Če sonce sije, so šipe toplejše, kot ponoči ali kadar je oblačno ;-) Pa o kateri šipi govorimo? O kar eni, ali o tisti, ki je najbližje peči? Re: IR grelni paneli - Žerjavar - 9.12.2014 janipapillon Napisal:Pričakujem, da še kdo komentira, izračuna, ugiba okrog meritev.Čemu pa ti bo služil ta podatek? Verjetno si izmeril temperaturo in veš, koliko je bila. Za izračunati pa je daleč premalo podatkov. Pa še zelo komplicirano je, ker je v fazi velikih sprememb (si že zakuril, se ogreva, vprašanje dosedanjega poteka intenzivnosti segrevanja, ....) Re: IR grelni paneli - janipapillon - 9.12.2014 Zasteklitev najbližja peči, =4m. Naj pripomnim da je razlika med Tzraka/Tzasteklitve na drugih dveh zasteklitvah praktično enaka. Enako je na vseh stenah v tem, še čisto odprtem prostoru. Razlike so v desetinkah. Sevanje se vendarle le deloma resorbira večina se odbije. Ker pa se to ponavlja, se praktično vse sevanje relativno enakomerno resorbira. Oblačno vreme. Severna šipa, pol metra za njo na sliki vidna cerada. Ideja je, naj bi izmerjeni podatek služil za lažjo predstavo prenosa toplote s sevanjem tistim, ki to prečitajo. Komplicirano je toliko, da sem čez palec pri oceni povprečen rezultat meritev falil za več kot pol in manj kot 1 st. Sprva je kazalo da sem se zmotil desetinko-dve , pa je izpadlo, da ima moj cenen infratermometer vkalkulirano precej drugačno emisivnost od realne na tejle šajbi.Čez noč in čez dan je bilo zunaj 2 stC, razvidno, tudi veter, na polinkani vremenski postaji. Notri je bilo zjutraj 8,6 stC. Po 6h kurjenja takega (<!-- m --><a class="postlink" href="http://www.lanordica-extraflame.com/en/woodburning-cookers/rosetta_p9001">http://www.lanordica-extraflame.com/en/ ... etta_p9001</a><!-- m -->) štedilnika je bila Tzraka ob šipi 11,26 stC. Teh meritev sem lani veliko naredil, omenjeni ∆T, ki ga ugibamo, računamo pa v zelo različnih pogojih ostaja znotraj ±1 stC; desetinke naj ne bodo pomembne. Re: IR grelni paneli - mirator - 9.12.2014 Tudi jaz te ne razumem, kaj bi pravzaprav rad povedal ali dokazal in kaj ima tvoj štedilnik z ir paneli? V tvojem primeru prevladujeta prestop toplote in konvekcija, sevanje pa ni primarno. Pa pomeri temperaturo stropa nad štedilnikom. Re: IR grelni paneli - janipapillon - 9.12.2014 Govorimo o sevanju. In če(ker) sevanje ni primarno bo Tpovršine ovoja stavbe in na oknu kakšna :?: napram Tzraka nekaj cm stran :?: :?: Nič ne bi rad dokazal. LE POKAZAL BI. In nimam pojma kolikšen procent toplote od celotne pretvorbe energije v toplotno, oddata s sevanjem tale šporhet ali pa IR grelni paneli. Ali kdo ve? Re: IR grelni paneli - medo9 - 9.12.2014 Če bi imel (jaz) na voljo kakšna "tipala", bi ti lahko izmeril keramično ploščico, ki je pod IR panelom in potem primerjal s ploščicami, ki so bolj stran. Ker pa nimam, ti pa lahko samo povem, da so po občutku ploščice pod panelom bolj tople (ali pa manj mrzle), kot tiste v kotu. Razliko med IR paneli in šporhetovimi ir žarki pa ti lahko razložijo pri Themaray, piši jim; so zelo komunikativni. Re: IR grelni paneli - Žerjavar - 9.12.2014 Citat:kolikšen procent toplote od celotne pretvorbe energije v toplotno, oddata s sevanjem tale šporhet ali pa IR grelni paneli. Ali kdo ve?To razmerje se izračuna. Glavni dejavnik je površinska temperatura grelnika - višja temperatura, višji delež sevanja. Vpliv pa ima tudi hitrost gibanja zraka ob grelni površini - vertikalna grelna površina ima manjši delež sevanja kot horizontalna. Za grobo informacijo, je pri 50 C sevanja blizu 40 %, pri 120 C pa blizu 70 % (zapisano po spominu iz izračuna pred kakim letom). Re: IR grelni paneli - janipapillon - 9.12.2014 medo9, živjo, pusti tipala. Ugibaj temperaturo notranjega stekla. Zunaj 2 stC. Notri zrak @12 stC. Re: IR grelni paneli - medo9 - 9.12.2014 zakaj bi ugibal, če ne razumem, čemu to služi? :roll: Re: IR grelni paneli - janipapillon - 9.12.2014 Če ne za kaj drugega pa za to, ker sem te nagovoril da ugibaj Sem bil pa ja menda tudi dovolj jasen: Naj služi boljši predstavi o prestopu toplotne energije ter vplivu sevalnega dela v danih okoliščinah. Re: IR grelni paneli - medo9 - 9.12.2014 "Sevanje" šporheta ni primerljivo z IR paneli, zato je to po mojem brez veze. Še IR paneli imajo različne valovne dolžine, če sem si prav zapomnil. Over&out. Re: IR grelni paneli - janipapillon - 9.12.2014 To, če dobri paneli oddajajo FAR IR(?), zastekljen šporhet pa spekter do vidnega elektromagnetnega valovanja, ne pomeni neprimerljivosti. |
