S čim zapreti prostor? - Print verzija
+--- Forum: Ostalo (https://podsvojostreho.net/forum/forumdisplay.php?fid=23)
+--- Tema: S čim zapreti prostor? (/showthread.php?tid=49957)
S čim zapreti prostor? - El N!no - 3.3.2013
Pozdravljeni.
Prosim za nasvete kako zapreti dva prostora. Kaj bi lahko poleg vrat še uporabil.
Prostor 1:
V tem prostoru imam peč. Zraven so že ena vrata za kopalnico. Prostor se nahaja v predsobi.
[url=httpunichr("58")//shraniunichr("46")si/?2p/tI/QcDBqkX/2013-03-03-100424unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/2p/tI/QcDBqkX/2013-03-03-100424unichr("46")jpg[/img][/url]
[url=httpunichr("58")//shraniunichr("46")si/?3r/1e/4o81hDyV/2013-03-03-100428unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/3r/1e/4o81hDyV/2013-03-03-100428unichr("46")jpg[/img][/url]
[url=httpunichr("58")//shraniunichr("46")si/?2A/WS/jfifb06/2013-03-03-100438unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/2A/WS/jfifb06/2013-03-03-100438unichr("46")jpg[/img][/url]
[url=httpunichr("58")//shraniunichr("46")si/?41/Pt/314w07BU/2013-03-03-100443unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/41/Pt/314w07BU/2013-03-03-100443unichr("46")jpg[/img][/url]
Prostor 2:
V tem prostoru imam grelnik vode. Nahaja se v kuhinji.
[url=httpunichr("58")//shraniunichr("46")si/?18/Ft/20LhS35N/2013-03-03-100323unichr("46")jpg][img]httpunichr("58")//shraniunichr("46")si/t/18/Ft/20LhS35N/2013-03-03-100323unichr("46")jpg[/img][/url]
Najlepša hvala.
Re: S čim zapreti prostor? - Sivka - 3.3.2013
Nabaviš drsna vrata ali harmonika vrata. Ali pa daš karniso pa kakšno neprosojno zaveso.
Re: S čim zapreti prostor? - KereS - 3.3.2013
mogoče kaka rolo zavesa?
like this [url]httpunichr("58")//wwwunichr("46")naxiunichr("46")rs/media/images/o/Lifestyle-rolo-zavese-1unichr("46")jpg[/url]
Re: S čim zapreti prostor? - El N!no - 3.3.2013
Drsna vrata odpadejo, ker ni dovolj prostora. Sem pa pozabil omeniti, da bo prostor dnevno uporabljen tako, da bi potreboval nekaj funkcionalno uporabnega.
Re: S čim zapreti prostor? - SloCop - 3.3.2013
K mizarju pa bo naredil klasična vrata. Čeprav glede na fotko imaš za drsna čisto dovolj placa.
Re: S čim zapreti prostor? - Metka M - 4.3.2013
Zdravo,
verjetno bo najlepse in funkcionalno rešeno z obicajnimi vrati ali z eno/dvo krilnimi vrati kot jih imajo omare (pri kuhinji) in naj se sklada z omarami oziroma z ostalimi vrati
lp,m
Re: S čim zapreti prostor? - RUBMW - 4.3.2013
lepo lahko montiraš steklena kaljena vrata ( v satinato izvedbi), na način kot klasična na tečaje, me pa zanima če imaš ob strani betonsko steno, ker tečaje ne moreš vijačit na knauf steno, če je prvotno nisi pripravil za tečaje,
Re: S čim zapreti prostor? - vincent - 4.3.2013
Za malo denarja...zmontiraj karnico in zaveso. Poceni, učinkovito....ni biser estetike, a skrije kar je za zaveso (izbereš manj prosojno). To te stane 50 EUR.
Re: S čim zapreti prostor? - izotop - 4.3.2013
a sam plinski kotel nima zalogovnika, da rabite še bojler posebej? drgač pa imam občutek, da je bilo pri izvedbi precej improvizacije (gledam instalacije ipd), lahko pa sem mimo pihnil seveda..
glede samega zaključka luknje pa:
v koliko imaš možnost, ti naj mizar naredi komplet stranico oz ploščo na sprednji strani zidu, ki ima vkomponirana vrata recimo (plošča na gre od tal do stropa). če dodaš še kakšne nevidne pante ipd si zmagal, hehe.
bolj diy varianta pa je recimo, da greš v ikeo kupit dve pax stranici (tiste široke 50 cm z mat barvo so zelo poceni, kaj pa vem 20€ kos pri 230 cm višine), zraven vzameš še okovje, narediš okvir in nanj vse skupaj zmontiraš, če pa kje kaj zmanjka, zapolniš z dodatno (pred odrezano) stranico. tako sem jst (oz. me še čaka par drobnarij) opremil skoraj komplet stanovanje, izgled pa bo približno takšen, kakor bi bila zadeva izvedena po naročilu.
sem enostavno obupal nad mizarji, očitno imajo preveč dela, da se ni dalo nobenemu niti ponudba dat v roku meseca, dveh.
Re: S čim zapreti prostor? - Strelka - 4.3.2013
V kuhinji bi jaz poskusila zapreti z enakimi vratci, kot bodo na kuhinjskih elementih (odprtino se prilagodi meram vratic).
V hodniku pa po želji, mogoče v skladu z ostalim pohištvom, ki bo na hodniku. Če boste imeli pohištvo po meri, naj mizar naredi tudi "omaro" za tisti del, kjer je peč, torej zgoraj vratca, spodaj pa police ali predali.
Lahko rešiš tudi z zaveso ali rolojem, morda tudi z ozko omaro/stojalom na kolescih, ki ga zapelješ pred peč in se je ne vidi. Ko potrebuješ dostop do peči, pa stojalo preprosto odmakneš.
Re: S čim zapreti prostor? - celece - 5.3.2013
za kuhinjo:
<!-- m --><a class="postlink" href="http://www.prostorama.si/projekt02.php">http://www.prostorama.si/projekt02.php</a><!-- m -->
Re: S čim zapreti prostor? - El N!no - 30.1.2014
[quote="izotop"]a sam plinski kotel nima zalogovnika, da rabite še bojler posebej? drgač pa imam občutek, da je bilo pri izvedbi precej improvizacije (gledam instalacije ipd)
To je kotel na elektriko.
Drugače pa še vedno nisem zaprl prostora, ker nimam nobene pametne ideje.
Mislim pa da bom naredil tako kot je rekla Metka M in SloCop.
Hvala za informacije.
Lp, Nino
izotop Napisal:glede samega zaključka luknje pa:
Imaš kakšne slike kak si to naredil?
Re: S čim zapreti prostor? - lanatri - 30.1.2014
Najlepše bi bilo z drsnimi satiniranimi ali belimi vrati, ker pa imate po tleh že letvice, bi rekli, da je verjetno prisotno nekaj improvizacije. Kotel lahko skrijete tudi v Ikeino visoko Factum omaro, ki je drugače primerna za vgradni hladilnik. Poskrbeti morate le, da bo omara lepo sedla v to nišo in ne bo na desni strani nekajcentimetrska špranja. Če ne želite deljenih vrat, potem morate izbrati drugo visoko omaro.
