Vgradna led svetila - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Napeljave (https://podsvojostreho.net/forum/forumdisplay.php?fid=17) +--- Tema: Vgradna led svetila (/showthread.php?tid=48286) |
Vgradna led svetila - branci - 29.11.2012 lep pozdrav sem pred nakupom vgradnih lučk za dnevni prostor (kuhinjo, jedilnico, dnevno sobo)ko meri 10x5m torej 50m2 od tega je še nekaj kvadratov poševnine na vsaki strani gledal sem recimo te na dx <!-- m --><a class="postlink" href="http://dx.com/p/3w-300-330lm-3000-3300k-3-led-warm-white-light-bulb-90-265v-142584">http://dx.com/p/3w-300-330lm-3000-3300k ... 65v-142584</a><!-- m --> in <!-- m --><a class="postlink" href="http://dx.com/p/5w-500-550lm-3000-3300k-led-warm-white-light-ceiling-down-lamp-100-260v-141162">http://dx.com/p/5w-500-550lm-3000-3300k ... 60v-141162</a><!-- m --> in te <!-- m --><a class="postlink" href="http://dx.com/p/5w-500-550lm-3000-3300k-led-warm-white-light-ceiling-down-lamp-100-260v-141162">http://dx.com/p/5w-500-550lm-3000-3300k ... 60v-141162</a><!-- m --> ali pa tole iz ebay-a <!-- m --><a class="postlink" href="http://www.ebay.co.uk/itm/GU10-Downlight-Fixed-Fire-Rated-50W-Die-Cast-Aluminium-Twist-and-Lock-White-/390426960805?pt=UK_Light_Fittings&hash=item5ae742a3a5">http://www.ebay.co.uk/itm/GU10-Downligh ... 5ae742a3a5</a><!-- m --> in te ledice <!-- m --><a class="postlink" href="http://www.ebay.co.uk/itm/GU10-Downlight-Fixed-Fire-Rated-50W-Die-Cast-Aluminium-Twist-and-Lock-White-/390426960805?pt=UK_Light_Fittings&hash=item5ae742a3a5">http://www.ebay.co.uk/itm/GU10-Downligh ... 5ae742a3a5</a><!-- m --> prve so mi zanimive ker imajo nizko vgradno višino, ampak nikjer ni podatka o kotu svetilnosti in pa če lučka crkne a je potrebno celo zamenjat katero barvo svetilnosti naj gledam 3000k ali 6000k kakšna je razlika koliko svetil rabim? a bi jih bilo kakih 18 dosti? poševnine imam na eni strani po celi sirini prostora 5m in sega 2,3 v prostor na drugi strani je kukerli in je poševnine samo 2.5m po sirini in 2.3m v prostor a bi bilo potrebno nekaj lučk dati tudi v poševnine ali bi bilo vredu če dam prvo vrsto lučk takoj ko se začne ravni strop, poševnine pa brez priporočate kaj bolšega? Re: Vgradna led svetila - todjo - 29.11.2012 Oglej si ponudbo tukaj [url]httpunichr("58")//wwwunichr("46")inledunichr("46")si/vgradna_svetila/vgradna_svetila_mr16[/url]. lp Re: Vgradna led svetila - yogo - 29.11.2012 Če že kupuješ LED svetila vzami sistem z GU10 podnožjem. to pomeni, da nabavi LED žarnico z GU10 podnožjem in pa samo vgradno ohišje za halogen žarnice. Ko ti bo žarnica crknila jo enostavno zamenjaš. V tvojem primeru moraš nabavit komplet novo lučko, kar zna bit po par letih težava... tudi sicer pa bo 3x1W premalo, saj svetijo res bogo... Kar se tiče svetilnosti je tako. Navadna žarnica ima svetilnost cca 2700-3300k. To je nekak najbolj prijetna svetloba za kako spalnico, dnevno sobo saj je svetloba bolj "rumena".. Tam kjer potrebuješ boljšo vidljivost, npr kuhinja, kopalnica pa lahko daš tudi 5000-6000k. v tem primeru bo svetloba bolj bela. Jaz sem v kuhinjo ( mansarda, poševen strop) dal 8 X LED 3x3W, 6000k. v skupni prostor v katerem je tudi jedilnica, odprt hodnik in kuhinja sem vgradil še dodatnih 11 x LED 3x3W, 6000k. Prostor je velih cca. 39m2, ledice so vgrajene vzdolžno po celi dolžini prostora. Ko prižgem vseh 11 žarnic je svetlobe povsem dovolj. Ko pa potrebujem še dodatno svetlobo v kuhinji pa vklopim še ostalih 8 kom. v dnevno bom vgradil 6x LED, 3x3 W, 2700-3300k, ker rabim bolj prijetno svetlobo. Nabavil sem pa take žarnice: <!-- m --><a class="postlink" href="http://www.alibaba.com/product-gs/367507440/Dimmable_LED_GU10_3_3W_CREE.html">http://www.alibaba.com/product-gs/36750 ... _CREE.html</a><!-- m --> Ohišja so pa od DIMCO: <!-- m --><a class="postlink" href="http://www.dimco-svetila.si/static/uploaded/htmlarea/files/catalog/01_downlight_spotlights.pdf">http://www.dimco-svetila.si/static/uplo ... lights.pdf</a><!-- m --> Re: Vgradna led svetila - ginekolog - 29.11.2012 Led svetila imajo slab CRI in neprijetno, hladnejšo svetlobo. Dobro premisli, če si jih želiš gledat v dnevni. Za kakšno rahlo ambientno svetlobo so pa ok. Re: Vgradna led svetila - yogo - 29.11.2012 Vse odvisno od tega, kakšno svetilnost vzameš. 2700-3300k so povsem OK za dnevne prostore Re: Vgradna led svetila - ginekolog - 29.11.2012 Reprodukcija barv ja slaba nedovisno od barve svetila. Napiši led cri na google in bo več jasno. Mene zelo moti, nekdo pa morda niti ne opazi. Re: Vgradna led svetila - Homer - 29.11.2012 Precejšnje zavajanje! Citat:The closer an LED light comes to 100 on the color rendering index (CRI), the more naturally colors are rendered, and the light is perceived as more pleasant. The CRI of fluorescent tubes is often around 72. Cree LED lighting fixtures have a CRI of between 92 and 94. Povedati je treba da je CRI faktor odvisen od temperature. Tako ima npr sveča, ki gori pri 1700K CRI=100, pa me nihče ne bo prepričal, da so tisti rdečkasti odtenki "natur barva" Kakor me tudi nihče ne bo prepričal, da je LED 2700K bolj "natur" kot tista 6000K Re: Vgradna led svetila - vincent - 29.11.2012 kot že omenjeno...najbolj enostavno je kupitlučke s standardnim podnožjem. Zdaj kako žarnico boš pa ti na koncu al noter je pa tvoja stvar..ali bo reflektor 40 W ali ledica 1 W, 2 W, 3 W, 4 W....nima veze. Lučke so cca. 5 do 6 EUR po kosu...ledice pa cca 5 EUR in naprej. |
