Hitachi Yutaki S - Print verzija
+--- Tema: Hitachi Yutaki S (/showthread.php?tid=45915)
RE: Hitachi Yutaki S - pentax - 23.8.2022
@00christian00, did you try to set up Favourite button on Unit controller, there is option to setup DHW Boost? At least, this was option on R410 previous version (year 2016).
<a href="https://ibb.co/jZbpNyc"><img src="https://i.ibb.co/jZbpNyc/dhw-boost.jpg" alt="dhw-boost" border="0"></a>
By default this button is for so called Eco mode, you can change it in settings. You know how to enter to Service Mode?
These two modes (options)  for DHW were possible in my R410 (year 2016) version - at bottom:
<a href="https://ibb.co/dr4yM0b"><img src="https://i.ibb.co/dr4yM0b/dhw-modes.jpg" alt="dhw-modes" border="0"></a>
I would say, you have selected Efficeny mode, for best COP.
RE: Hitachi Yutaki S - 00christian00 - 25.8.2022
@Pentax,
Sadly DHW control option is not available with the new controller. I don't know if it is just a controller issue or they removed the option from the new R32 unit. The technician from Hitachi said the new color controller is compatible with the old R410 units so probably the reverse is true. I should get my hands on one to see if it changes anything.
The service center seem to be puzzled about the issue, they don't know much about the new unit however.
They escalated the problem to Hitachi internal tech, but it seem some are in vacation.
I have made a lot of tests, but always ends up with the same results, I have a feeling the DHW logic at high temperature is completely broken in the new r32 units.
The DHW boost is available as a button in the new controller, but it does nothing until it falls below 41.
Everything seems to works fine only if I enable the external heater option, that way it starts the DHW heating as soon as it falls under 50 degrees, problem is it is using the heater instead of the heat pump to do so. It starts the heat pump only below 41 degrees.
RE: Hitachi Yutaki S - hitacho - 17.9.2022
Zdravo,
prejšnjo kurilno sezono sem imel kontrolno enoto nastavljeno kot termostat- sicer deluje, ampak kaže precej nenatančno temperaturo, včasih se tudi (pre)počasi odziva na spremembe, tako da je bilo kar nekaj heca, da najdeš tistih ugodnih 21,5.
Torej sem dal zdaj navadni žični termostat na 13 in 14 in dobivam stalno alarm:
40 - Indoor Incorrect LCD setting Current LCD configuration does not
allow proper operation
Kje ga biksam? Ima kdo podobno izkušnjo?
Ali mora biti kakšen poseben termostat? Ta je neki ELRO kt100, ima COM, N/O in N/C. Povezal sem na COM in N/O.
Hvala. LP
RE: Hitachi Yutaki S - basg4 - 18.9.2022
Imam novo Yutaki S 6KW. Premišljam o sobnem termostatu EMOS P5623.  Kakšne izkušnje oziroma nasvet? Sem popoln začetnik na tem področju.
RE: Hitachi Yutaki S - tona gas - 18.9.2022
basg4, jaz imam EMOS T15RF deluje super je brez žic pa še kar nekaj nastavitev obvlada.
Ima tudi nastavitev na koliko ti niha temperatura +-.
RE: Hitachi Yutaki S - hitacho - 18.9.2022
@tona gas
...in ko si ta termostat priključil na sponke 13,14, nastavil pump controlled by thermo, je že delalo ok?
hitacho, poglej eno stran nazaj smo aprila to obdelovali,meni zdaj deluje sicer ne zdaj ker je vse izklopljeno ampak upam ko zalaufam da bo delovalo v prehodnem obdobju.
Bom pa letos zalaufal na radiatorjih prisilno kroženje zraka preko ventilatorjev bom videl če bo projekt uspel?
RE: Hitachi Yutaki S - KRSimpa - 19.9.2022
Tona gas,
Verjetno misliš ventilatorje montirati pod radiator?
Zrak pa bodo ventilatorji pošiljali skozi reže radiatorja navzgor. Pri tem se bo ogrelo veliko več zraka, kot pri normalnem delovanju.
RE: Hitachi Yutaki S - didi - 20.9.2022
Evo, še moja izkušnja vezave sobnega termostata na kontakta 13 in 14 in težave z obtočno črpalko (OČ).
Imam TČ yutaki S letnik 2021 z novejšim zaslonom. Med kontaktoma 13 in 14 ni bilo mostička. Po priklopu termostata (zaradi višje histereze sem izbral anolognega) sem moral konfigurirati vhod 1.
Ker se po izklopu termostata OČ ni izkopila, sem moral premakniti dep switch DSW4 pin 5 na ON. V meniju še nastaviti čas delovanja, min čas vklopa, min čas izklopa in pogoj zaustavitve (nastavil na temperaturni) OČ. Nastavil sem tudi min čas vklopa in izklopa kompresorja. Ta nastavitev je začela delovati šele po nastavitvi dep switcha DSW4 pin 5 na ON.
RE: Hitachi Yutaki S - tona gas - 20.9.2022
KRSimpa, da v mojem projektu je mišljena montaža rač.ventilatorjev na cca 50cm povezani so preko naležnega cevnega termostata, da ne laufajo v prazno oziroma da se vklopijo na določeno temperaturo .
RE: Hitachi Yutaki S - sassapo - 20.9.2022
tona gas... dobiš kot radiator dolge radialne ventilatorje, kateri so pravi za ta namen. Axialni ne bodo učinkoviti, saj pihajo točkovno, pa še sesalni so.
sassapo, kolko pa stane tak od oka ? Radiator v projektu imam 2m dolžine 22-tko.
Sem nabavil 6 kom vent. pa regulator za vrtljaje no napetosti da ne šibajo na polno.
Tisti iz notranjih enot klim bi bili zastonj, saj vse končajo na odpadih. Drugače pa lahko kupiš tiste za kamin, za konvektorje... Po pregledu enega cenika je dolžine 400mm 34€
RE: Hitachi Yutaki S - bvs - 19.10.2022
Ali je možno Hitachija frekvenčno omejiti, da ostane optimalnem področju in da ne skače z obrati v iberture? Tokovno se da, vendar to ni enako.
RE: Hitachi Yutaki S - hitacho - 23.10.2022
Glede nastavljanja termostata...sem moral konfigurirati vhod 1.
AHA, torej moraš povedati da vhod 1 upošteva (sponke 13 in 14). OK nisem še proval, bom v kratkem.
Zanima pa me še nekaj. Nastavim, da kompresor stoji 12min in deluje 8min v nastavitvah. Se usedeva s frendom na pir ob polnoči, TČ je nastavljena na eko način (5 stopinj manj kot čez dan) in kompresor deluje 6 min, stoji 6 min, deluje 6 min, stoji 6 min... ZAKAJ? Če je nastavljeno na 12min da stoji in 8min da deluje...ZAKAJ? Smile
