Lastniki TČ zrak-voda-poraba el. - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Energijski viri (https://podsvojostreho.net/forum/forumdisplay.php?fid=18) +--- Tema: Lastniki TČ zrak-voda-poraba el. (/showthread.php?tid=18576) Strani:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
Re: Lastniki TČ zrak-voda-poraba el. - cinik - 4.1.2014 [img]httpunichr("58")//shraniunichr("46")si/f/2g/Ly/4QnoYBW/2014-01-04-dataunichr("46")jpg[/img] [url=httpunichr("58")//shraniunichr("46")si/f/D/zj/2nWyP2oL/2013-12-04-ogrevalni-sisunichr("46")jpg]Podatki o hiši in ogrevalnem sistemu.[/url] ---------------------- Posebnosti tega meseca: - veliko eksperimentiranja v sodelovanju z @Vincentom skozi veliko strani [url=httpunichr("58")//wwwunichr("46")podsvojostrehounichr("46")net/forum/viewtopicunichr("46")php?f=7&t=53455&start=5190]opisano v tej temi.[/url] Tudi rezultati eksperimentov bodo objavljeni v isti temi. ---------------------- [url=httpunichr("58")//wwwunichr("46")podsvojostrehounichr("46")net/forum/viewtopicunichr("46")php?f=7&t=53455&start=5190]Vprašanja ali komentarji v to temo[/url] Tukaj bodo moderatorji vse dosledno izbrisali. Re: Lastniki TČ zrak-voda-poraba el. - dusan001 - 4.1.2014 Lentus: poraba TČ ogrevanja+STV. Povprečne ostale hišne porabe je ca 12kWh/dan. Re: Lastniki TČ zrak-voda-poraba el. - Coil - 4.1.2014 Naj pripnem še jaz. Re: Lastniki TČ zrak-voda-poraba el. - Vader - 5.1.2014 December 2013 poraba celotno gospodinjstvo 842kWh TČ: Panasonic Aquarea 8kW + 300l bojler za sanitarno vodo nastavljen na 51 st C. Termostat v dnevni nastavljen na 22,5 st C Lokacija: južni rob ljubljanskega barja, na zahodnem pobočju, tako da je pozimi malo sonca Objekt: montažna hiša na zidani napol zasuti kleti. Ogrevano 180 m2 s talnim gretjem. Drugih virov toplote (še) ni Okna: lesena troslojna 0,6 Montažni del izoliran z 20 cm mineralne volne + 10cm neopor, streha 40cm mineralne volne Zidani del izoliran z 5cm xps (zasuti del) in 15cm eps odsuti del. Pod temeljno ploščo je še 10cm xps. S talnim je ogrevanih samo 2/3 kleti, garaža je neogrevana, je pa vhod v njo samo odzunaj in proti ogrevanim prostorom je od znotraj izolirana s 6cm eps. Re: Lastniki TČ zrak-voda-poraba el. - telmos - 7.1.2014 Slika po dveh mesecih je takale. Pridelanih 4427kWh toplotne energije, porabljeno 1271 kWh električne energije, temperatura dovoda med 41 in 44°C, povratka med 33 in 36°C povprečen COP 3.48 Micka mi zaenkrat dela dobro, čeprav sem vsako novo leto jezen na njih. Re: Lastniki TČ zrak-voda-poraba el. - rlasic - 7.1.2014 Lokacija: Štajerska Opis objekta: k+p+m (40m2+100m2+100m2)(zunanji ovoj - siporex 30cm) Izolacija fasada: 5cm stiropor (demit), cokel in klet neizolirana, vsi estrihi 6cm trdi tervol Izolacija mansarde: 20cm tervol na poševninah in 25cm na ravnem Ogrevanih m2: 200m2 + 40 m2-klet Notranja T: prostori 23°C, klet 20°C Naprava: TČ zrak-voda Panasonic aquarea t-cap 12kw, split, trofazna, inverterska + 300l sanitarni bojler (48°C) + 300l zalogovnik (max 45°C) Radiatorji povsod + dodatno 20m2 talnega - tri ločene veje (dve za radiatorje in ena za talno); razdalja med notranjo in zunanjo enoto je 16m! [img]httpunichr("58")//www2unichr("46")arnesunichr("46")si/~rlasic/slike/poraba_rl_11_12_13unichr("46")jpg[/img] Re: Lastniki TČ zrak-voda-poraba el. - standi79 - 7.1.2014 poraba celotno gospodinjstvo + ogrevanje za december v hiši imamo 22+ 1047 kW, od tega MT 618 kW in VT 429 kW sem pri Geni Re: Lastniki TČ zrak-voda-poraba el. - foxman - 8.1.2014 Vprašanje za rlasic! Ali so kWh v tej tabeli samo za ogrevanje ali je zraven tudi gospodinjska poraba? Imam namreč skoraj enako TČ Panasonic: TČ zrak-voda Panasonic aquarea t-cap 9kw, split, trofazna, inverterska + 200l sanitarni bojler (48°C) + 100l zalogovnik (max 45°C)! Opis hiše: - hiša v Dupleku zidana iz opeke 29cm letnik 1967, ogrevam vseh 115m2. - klet neizolirana 1m vkopana 14C (v kratkem bom toplotno izoliral strop s 8cm str. - vsa hiša se ogreva na radiatorje 10kom - fasada klasično zaribana (3-5 cm omet) - streha obnovljena izolirana po ravnem 30cm, poševnina 20cm - okna nova PVC 3-slojna - notranja temp. čez dan 22C, ponoči 21C - 200L sanitarna voda, 100L zalogovnik Poraba elektrika ogrevanje+SV in gospodinjstvo 2013: -sept. 584 Kwh -okt. 826 kWh -nov. 1140 kwh -dec. 1885 kwh Črpalka je bila vgrajena meseca Julija 2013, prej ogrevanje na olje in drva (poraba neznana, ker je sem hišo kupil in jo obnovil. Fasada 15cm bo verjetno izvedena letos ali v 2015. lp. Re: Lastniki TČ zrak-voda-poraba el. - rlasic - 8.1.2014 To je poraba za ogrevanje in pripravo sanitarne vode. Imam poseben števec Landis-gyr in preko njega nato merim porabo kompletne kurilnice - vse - črpalke, regulacija, TČ! Naša mesečna poraba ostalega dela pa je okrog 700-800kw, poleti ko pride še črpalka za bazen in tri klime je malce več. Sta pa v hiši dve družini z vsemi "pripadajočimi aparati", zato pa je poraba tako velika! Re: Lastniki TČ zrak-voda-poraba el. - sašo65 - 9.1.2014 sašo65 Napisal:Celotna poraba december 930kwh VT580/MT350sem kr "zadel" le malo manjša razlika med VT in MT je - drugače pa prišla položnica: 111,47€ (111,47€/928kwh= 0,1201) povprečje dan 29,93kwh / še razčlenitev v grobem / 8 gospod./ 17 gretje/ 5 SV/ December 2013 je bilo 305kwh el.kar je zneslo 45€ + cca 350 lit. ELKO za gretje bajte + SV v grobem skupno 400€ Definitivno decembra (lanski in predlanski) nista primerljiva (nimam podatka povprečne temp. ampak mislim, da je 12/2013 bil kr občutno toplejši.....vsekakor pa lahko rečem, da sem na "dobrem" 1:3 ("COP" 3,56 :mrgreen: ) Bo kr ok. ampak vseeno bi rad vsaj teden "ameriške" zime, da vidimo kaj Fujitsu zmore :lol: Re: Lastniki TČ zrak-voda-poraba el. - misko - 9.1.2014 Poraba decembra 1040kWh za ogrevanje in sanitarno vodo. Lokacija mb, zubadan 11kW, okrog 210 m2 ogrevano 24h na 22-23,5st, 25m2 garaza ogrevana na 18st, 15m2neogrevano. 5cm fasade, cokel polovico neizoliran, vkopana klet neizolirana, okna k1.1, mansarda 25cm sf 35. Vse radiatorji NT sistem do 40st vtoka. 300l sanitarne vode ogrevano na 47st. Zaenkrat zadovoljen. Poraba dec je malo visja, ker sem se igral z nastavitvami in antilegionelnim programom ene 3x. Re: Lastniki TČ zrak-voda-poraba el. - Berghaus - 10.1.2014 Debate v DEBATO. Re: Lastniki TČ zrak-voda-poraba el. - vincent - 14.1.2014 vincent Napisal:Poraba december 2013: 2,8 kWh/m2* oz. 18,0 kWh dnevno. Račun GENi vsa elektrika: 99 EUR Sorazmerni delež za SV in ogrevanje: 69 EUR 559 kWh ... (809 kwh skupaj - 250 kwh povprečje gospodinjstvo) Re: Lastniki TČ zrak-voda-poraba el. - MI2 - 15.1.2014 MI2 Napisal:Poraba decembra za ogrevanje in TSV 901 kWh po posebnem števcu oz. enako kot dec/12. Celoten račun za dec/13 je 169.20 eur. Poraba zadnje dni... Sonce neposredni pribitki in kolektorji za TSV, pečenka v pečici. Skratka vedno na termostatu v dnevnih prostorih 21-22.5°, nihanja porabe so zelo velika. Re: Lastniki TČ zrak-voda-poraba el. - xavi - 23.1.2014 xavi Napisal:Odštevam minute, ko bom štartal z zgoraj omenjeno HP črpalko. Piše se 23 januar 2013Minilo je eno leto od zagona TČ Fujitsu waterstage HP 11 kw. Natančnih podatkov zaradi enotnega števca ne morem podati (odštevalni v uporabi od 18.1.), tako jih bom dodal pripono cca. Skupni račun za elektriko je v vsakem primeru enak. Skupna poraba 9077 kw. Samo TČ cca. 5427 Ostalo gospodinjstvo 3650. Se pravi, vzel sem neko povprečje 10 kw dnevno za skupno gospodinjstvo. Cenovno samo ogrevanje cca. 667 eurov. V primeru, da je dnevna razlika +- 1kw je to na letni ravni nekje 45 eurov, pa če še dodamo relativno nizko porabo v zadnjem mesecu, bi rekel, da bi bil letni strošek max. 750 eurov. Ob tem moram poudarit, da sem kamin v tem času zakuril vsega 3x, med tem ko sem v starih časih kurilnemu olju z kaminom izdatno pomagal, da sem prišel na 1800 l na sezono. Se pravi prihranek prvo sezono blizu 1200 eurov. Skupna investicija (TČ, 300 l bojler, montaža)z vrnjeno subvencijo ekosklada 6500 eurov. |
