Dobra TČ Made in China? Možno? - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Energijski viri (https://podsvojostreho.net/forum/forumdisplay.php?fid=18) +--- Tema: Dobra TČ Made in China? Možno? (/showthread.php?tid=51047) |
Re: Dobra TČ Made in China? Možno? - SimonS - 16.9.2014 Načeloma ne. Sam dosti kupujem pri kitajcih, ampak le robo, ki je ne rabim dnevno in mi je pomembna. Re: Dobra TČ Made in China? Možno? - kremenckov ata - 1.10.2014 Za foro sem jih kontaktiral, carine je 2.2 % na celoten račun s prevozom + DDV. Je kdo sam kdaj montiral kaj podobnega? Thank you very much for your inquiry. Hope to build a long terms cooperation with you soon! We have some updated Triaqua specification and price as attached. Our Triauqa multifunctional heat pump design is originally from Europe. It is very much adopt to the European style. It is with 90L DHW tank and 50L AC buffer tank. We have also Tritherma slim multifunctional heat pump with hydraulic box similar as Daikin Altherma heat pump as shown <!-- m --><a class="postlink" href="http://www.china-heatpump.com/low-ambient-temp-split-heat-pump-to-replace-gas-boiler.html">http://www.china-heatpump.com/low-ambie ... oiler.html</a><!-- m --> . The installation may be more familar by your installer. Function: 1. It can provide air heating, air cooling and domestic hot water in one solution. 2. Fuzzy logic intelligent control program to utilize solar passive heating for both domestic hot water and room heating. 3. Optional auto shift function to start other heating source during super cold climate. 4. Excellent auto defrost for keeping heating during -20 centigrade. Special patent outdoor design to prevent the ice building during winter heating. Built in crankcase heater to protect compressor during winter. 5. Two water tanks with 2 expansion vessels and 2 plate heat exchangers and more than 30 Hydraulic components are built inside. 6. Our patent recirculation heat pump technology enable us to use slim water tank. Before the DHW go out for shower, it will go through the heat exchanger first. It will increase the tank water about 5 centigrade. During the shower, 1/3 of shower go out for shower, 2/3 of hot water will go to the DHW water tank again. This technology will make the water tank temp drop very slowly and comfortable. 7 Weekly timers on/off for you to choose the lowest electricity price period for operation to save your bill the most. 8. Our parts are always choosen with the top brand in the world to assure quality, reliability and save maintenance cost: Heat exchanger: SWEP brand plate heat exchanger from Sweden. The compressor: Daikin brand Scroll type Heat expansion valve: Emerson brand Water pump: Wilo brand from Germany Four way valve: Saginomiya brand of Japan The above parts enable our heat pumps trouble free products. Re: Dobra TČ Made in China? Možno? - sassapo - 2.10.2014 Dejstvo je, da so kitajske TČ vedno boljše! Pred leti so so bile katastrofa, danes so že skoraj primerljive renomiranim znamkam. Edini problem nepoznanih kitajskih firm so morda rezervni deli pri inverterskih napravah, kjer ne moreš vgradit ekvivalentnega dela. Re: Dobra TČ Made in China? Možno? - jani65 - 2.10.2014 Potem je najbrž najbolje ,da se kitajka kupi ON/OF ? Re: Dobra TČ Made in China? Možno? - sassapo - 2.10.2014 Voda voda ali zemlja voda (zelo ugodno in solidno) brez razmišljanja. Kitajski on - off zrak voda...hm, ga še nisem videl takega, da bi ga lahko brez slabe vesti priporočil. Kolikor toliko se obnese na talnem, ali za gretje bazena, v kopalni sezoni seveda :lol: ps. imam eno njihovo 16kw, je praktično nova, delovala je samo za namen testiranja, jo dam zelo ugodno Re: Dobra TČ Made in China? Možno? - jani65 - 1.1.2015 Ima kdo kakšen podatek kako deluje kakšna Kitajska TČ v tem času? Re: Dobra TČ Made in China? Možno? - BLABLABLA - 1.1.2015 Greje. Nismo še zmrznili. Re: Dobra TČ Made in China? Možno? - BLABLABLA - 1.1.2015 Moji dve kitajki (moja in tista pri očetu), sta imeli z najhujšim mrazom opreviti v noči iz ponedeljka na torek. Obe sta pokazali na zunanjem senzorju -15°C (včeraj samo -11°C). Lokacija Šentjakob ob Savi. Obe sta se zavrteli do maximuma (moja 11 kW na 130% od očeta 9 kW pa na 150%) Pomožni grelci so v obeh primerih na OFF. Za mojo lahko komentiram (ker jo lahko večkrat pogledam), da pri cca -10°C da od sebe pri maksimumu nekje 8-9 kW. Imam pa temperaturo vtoka nekje 27-28-29°C. V hiši pa cca 21°C. Ji pa jaz malo pomagam s kaminom. (jebi ga pri večjem minusu imajo drva najboljši COP) Tudi če ji nebi pomagal s kurjenjem, bi zmogla, saj čez dan ne deluje na maximalni modulaciji. Aja ogrevam pa slabih 300m2 hiše, mi je predelana iz štale (ima sicer dobro izolacijo na fasadi 8-10-14 cm stiropor), proti tlem je ba bolj en klinc izolirana. Talno je cca 60-65% površine, ostalo pa radiatorji. Sper fazna gradnja ![]() ![]() Evo tolk zaenkrat. Aja tretja sezona, kar obratuje. Re: Dobra TČ Made in China? Možno? - denisvila - 3.1.2015 Živjo, Ali mi lahko kdo napiše izkušnje oz. ali se izplača kupiti ''cheap'' ebay TČ? npr: - MICHL [url]httpunichr("58")//wwwunichr("46")ebayunichr("46")de/itm/Michl-Luft-Wasser-Warmepumpe-split-11-8-kW-/181596744451?pt=Systemkomponenten_Heizung&hash=item2a48026b03[/url] - MEETING [url]httpunichr("58")//wwwunichr("46")ebayunichr("46")de/itm/Luft-Wasser-Warmepumpe-Luftwarmepumpe-12-KW-Meeting-MD30D-230Vmax-COP-4-Neuware-/371211111337?pt=LH_DefaultDomain_77&hash=item566de80ba9[/url] - THERMAL MASTER [url]httpunichr("58")//wwwunichr("46")ebayunichr("46")de/itm/11-2KW-Luft-Wasser-Warmepumpe-Toshiba-Kompressor-R410A-LCD-LED-Bedieneinheit-/291276889240?pt=LH_DefaultDomain_77&hash=item43d1749c98[/url] Re: Dobra TČ Made in China? Možno? - jani65 - 3.1.2015 Ni mi jasno zakaj so vse te TČ do 12kw 230V ,cena ali kaj? Re: Dobra TČ Made in China? Možno? - dzamo - 3.1.2015 Ker potrebujem 12kw Re: Dobra TČ Made in China? Možno? - jani65 - 4.1.2015 Nisem mislil kaj ti rabiš dzamo ampak to zakaj so do 12kw te Kitajke 230V, 380V skoraj ni zasledit ,razen močnejše. Re: Dobra TČ Made in China? Možno? - alanford - 4.1.2015 220V (230V) je fazna napetost (med katerokoli fazo in nulo). 380V (400V) pa je medfazna napetost istega sistema. Gre samo za to, kako posrečeno prodajalec vpiše naziv. Pri enofaznih je seveda navedena vedno in samo fazna napetost. Pri trofaznih pa eno ali drugo. P.s Ja,zdaj vidim. Zgornje tri so vse enofazne. Kako lahko to poganjaš na eni fazi plus vse ostalo v hiši, mi ni jasno. Si moraš misliti, kakšen priključek moraš imeti. Re: Dobra TČ Made in China? Možno? - boris427 - 4.1.2015 Jaz imam črpalko MEETING MD50D že tri leta. Sem z Obale, tako da pri nizkih temperaturah ta črpalka pri meni ni delala in s tem nimam izkušenj.Do sedaj še nisem imel nobenih težav. Na Obali poznam še dva, ki jo imata (tudi nimata težav). Problem s temi črpalkami je predvsem v tem, da vsako leto konkretno zvišajo prodajno ceno. V treh letih so se te črpalke podražile za 50% in cene niso več tako ugodne kot takrat. Re: Dobra TČ Made in China? Možno? - sassapo - 4.1.2015 No, tudi teh 12 kitajskih KW je potrebno jemat zelo z rezervo! Navadno ne presegajo treh KW porabe, (večinoma manj) kar je za eno fazo še sprejemljivo. Nazivno moč smo namerili edino pri gretju bazena, kjer je zrak več kot 20°C ogrevana voda pa manj kot 30°C Realno bi lahko rekel, da je toplotna moč okoli 7 - 8KW |
