Montaža vremenske regulacije - povpraševanje - Print verzija
+--- Tema: Montaža vremenske regulacije - povpraševanje (/showthread.php?tid=63488)
Strani: 1 2 3
Re: Montaža vremenske regulacije - povpraševanje - sassapo - 29.10.2015
Homer Napisal:
Citat:Vsaka malce boljša uporablja za izračunavo tudi notranjo influenco in se v bistvu sama nastavi.
Zgrešeno!
To je le dodatni popravek, ki naj bi odpravil odstopanja, ki nastajajo predvsem zaradi vpliva bivanja (notranji pribitki: kuhanje, tv, osebe, .....) Vremenska regulacija mora že v osnovi brez sobnega tipala vzdrževati potrebno temperaturo brez pribitkov.
Vklopiš auto adapt in regulacija se uči kakšnih 14 dni in potem popolnoma sama prilagodi krivuljo, če seltron to obvlada ne vem.
omega630... ti le nabavi, ti ne bo nikoli žal :wink:
Re: Montaža vremenske regulacije - povpraševanje - crashednburnt - 29.10.2015
sassapo Napisal:Vklopiš auto adapt in regulacija se uči kakšnih 14 dni in potem popolnoma sama prilagodi krivuljo, če seltron to obvlada ne vem.
A FWS tole zna in če da, kako se to nastavi? Danes so mi jo zagnali ...
Re: Montaža vremenske regulacije - povpraševanje - Poldee - 29.10.2015
Imas to moznost, parameter 726. Sam zal tega parametra nimam na moji :-(
Tako pravi:
3.2.3 Self-adaptation
When this function is active (parameter 726), the
temperature control is automatically adjusted; it is
therefore futile to modify the slope or the off-set in the
temperature control (parameters 720 and 721).
When this function is first activated, the end user
may experience some inconvenience for a few days.
This period of no more than a week is required by
the regulator to determine the slope and off-set in the
temperature control. We advise against changing the
temperature settings during this period.
The following instructions must be observed for the
self-adaptation system to operate correctly :
- A room thermostat must be connected.
- The influence of the ambient temperature
(parameter 750) must be set between 1 and 100%.
- Depending on the installation, the room thermostat may
have a greater or lesser influence on the temperature
control. The room in which the room thermostat is
installed must not contain any thermostatic valves.
If this is the case, the valves must be open fully.
Re: Montaža vremenske regulacije - povpraševanje - aleks - 30.10.2015
sassapo Napisal:Ne vem zakaj dva mešalna kroga, imaš pol radiatorjev pol talno?
Obstajajo precej ugodnejše regulacije,
Lahko kakšen primer prosim?
Re: Montaža vremenske regulacije - povpraševanje - omega630 - 30.10.2015
Res hvala lepa za konkreten odgovor. No, nekako sem se odločil, da bi to sezono še počakal, vmes mogoče še pri kom v živo videl in sploh uvidel kako in kaj in potem tudi nabavil.
zdravapamet - za več informacij (detajlov) se pa vsekakor oglasim na ZS
Hvala vsem...
Re: Montaža vremenske regulacije - povpraševanje - sašo65 - 30.10.2015
KOMPLET SESTAVLJA:
1 x regulator ogrevanja PROMATIC® WDC20,
1 x motorni pogon PROMIX® AVC05,
1 x sobna enota DD2+,
1 x zunanje temperaturno tipalo AF/Pt,
1 x naležno temperaturno tipalo VF/Pt,
4 x potopno temperaturno tipalo TF/Pt.
to vsebuje komplet in stane cca 500€
zdravapamet Napisal:omega 630 to je zate.
Regulacija Seltron WDC 20 za dva mešalna kroga in ogrevanje bojlerja stane z montažo pri meni 1.128,40 EUR.
Ponudba zajema:
-regulator WDC 20 Seltron - 1 kos
-sobna enota DD2+ Seltron - 2 kos
-zunanje tipalo Seltron - 1 kos
-potopno tipalo Seltron - 4 kos
-pogon motorni AVC05 3 točk.2min Seltron - 2 kos
-kanali + kabli z drobnim materialom - 1 kpl
se pravi 600€ montaža..... :roll: :roll: :roll: ajde, ena sobna enota je pri tebi več, pa motorček;ne bom omenjal, koliko stane, da ti ne bo še bolj nerodno...
zdravapamet Napisal:Izjavo da ti to lahko naredi vsak klasičen električar ali elektronik pa pozabi. Ko se začnemo pogovarjati o ogrevanju ti ljudje zmrznejo na celi črti.
Za ta dela smo na svetu monterji in serviserji, ki poznamo delovanje ogrevalnega sistema in pomen nastavitev v programski opremi.
Tukaj imaš konkreten odgovor na tvoje vprašanje za kaj več pa ZS.
ne bulazni. kar nekaj forumašev si je to zmontiralo samo. tudi nastavitve so si sami nastavili. itak je za večino parametrov potrebna izkušnja uporabnika, tega niti serviser ne more našlogat. nekateri so poleg krmiljenja (kar je mimogrede "kos kolača" za človeka, ki je vsaj funkcionalno pismen in nima dveh levih rok) še kurilnice hidravlično sami zvezali.
Re: Montaža vremenske regulacije - povpraševanje - CimaBella - 30.10.2015
aleks Napisal:
@sassapo: Jaz sem razumela, da ima omega 2 mešalna kroga, ker ločeno ogreva 2 stanovanji. Me pa zanima isto kot aleksa.
Re: Montaža vremenske regulacije - povpraševanje - sinko999 - 30.10.2015
WDC20 , sama montaža traja en dan , cena iz trga je pa ponavadi 220-250€ in pa zagon nastavitev vsega...
Re: Montaža vremenske regulacije - povpraševanje - najrad1 - 30.10.2015
zdravapamet Napisal:Kot dodatno opremo lahko kupiš komunikacijski vmesnik WIFI GETAWAY GWD1 ki stane pri meni 126,15 EUR ( ni zajet v ponudbi ). Omogoča nadzor in krmiljenje preko spleta.
zdravapamet na takšne monterje kot si ti se jaz po.čijem(na piko pride š ) !
Hočeš nategnit človeka ? Kaj te v Seltronu niso poučili kako deluje GWD1 ?
Moderator-ji in vsi ,ki berete to temo razen "zdravapamet"se vam opravičujem za uporabo grde besede vendar ne gre drugače.
Tukaj je odgovor na moje lepo pisanje,ker zdravapamet prodaja buče
<!-- m --><a class="postlink" href="http://www.seltron.si/forum/gwd1---seltronhome/?p=1">http://www.seltron.si/forum/gwd1---seltronhome/?p=1</a><!-- m -->
Re: Montaža vremenske regulacije - povpraševanje - jani65 - 30.10.2015
Sam sicer vremensko uporabljam od Firšta ima pa tudi nekaj zadev od Seltrona.
<!-- m --><a class="postlink" href="http://ftp.seltron.si/web-pdf/seltron-novice-december-2014-web.pdf">http://ftp.seltron.si/web-pdf/seltron-n ... 14-web.pdf</a><!-- m -->
Re: Montaža vremenske regulacije - povpraševanje - sassapo - 31.10.2015
@sassapo: Jaz sem razumela, da ima omega 2 mešalna kroga, ker ločeno ogreva 2 stanovanji. Me pa zanima isto kot aleksa.[/quote]
Slabo berete! Napisal sem, če rabi samo en - eden mešalni krog je rešitev relativno poceni, (pod 100€) če pa gre za direktni in dva mešalna kroga, pa vsaj jaz ne vem za kakšno posebej ugodno varianto.
Re: Montaža vremenske regulacije - povpraševanje - aleks - 31.10.2015
a imaš v mislih to heat-on wchr01?
