Polaganje ploščic na stik - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Opremljanje doma (https://podsvojostreho.net/forum/forumdisplay.php?fid=5) +--- Forum: Talne in stenske obloge (https://podsvojostreho.net/forum/forumdisplay.php?fid=19) +--- Tema: Polaganje ploščic na stik (/showthread.php?tid=57349) Strani:
Re: Polaganje ploščic na stik - gt001 - 24.7.2014 ok, recimo, da je temp. razlike cez leto ~8°. pri tej temp razliki ima keramika raztetkov ~0,05mm/m. Pri 6m sirokem prostoru to znese 0.3mm. Na prvi pogled je to nic, pri trdih materialih, brez moznosti absorbiranja pomikov, pa ni vedno nedolzno. Ta raztezek mora keramika nekam stisniti/kompenzirati. Ne gre drugace. Re: Polaganje ploščic na stik - korenje - 24.7.2014 Sicer tukaj <!-- m --><a class="postlink" href="http://www.ceracasa.com/650007_en/FAQ%27s/">http://www.ceracasa.com/650007_en/FAQ%27s/</a><!-- m --> pišejo da: 1. Grouting can absorb the imperfections in the base, and help to avoid these imperfections affecting the tile. 2. It impedes and balances the ability to grip at the inferior part of the base when subject to weight. 3. Ceramics which have been treated with glazes are impervious to water or steam. This is where the grouting facilitates the transition of water through the tiled surfaces. It is important that the grouting is capable of diffusing steam from the inside of the surface out and to avoid penetration from water, outside - in. This is because excessive amounts of water from exterior to interior can deteriorate both the adhesive and the base. It is important to take into account that the grouting is exposed to the same environmental and chemical ‘attacks’ as the tiles – and so should have the appropriate resistance to external factors. Re: Polaganje ploščic na stik - papez46 - 24.7.2014 Berghaus Napisal:papez46 Napisal:Ne rečem, da ne pokajo - in si lepo pojasnil zakaj. Bravo. Iz tega lahko samo jasno in glasno potegnemo zaključek: Polaganje keramike na stik - kjer je talno gretje ........ NO-GO! Pa želje in fikcija gor, ali pa dol. Kjer talnega NI in je ogrevanje rešeno na kak drugačen način pa - JA, če si upaš...... :wink: 8) Citat:ok, recimo, da je temp. razlike cez leto ~8°. Ja, 0,3mm na 6m je ali pa ni veliko. V tem primeru pa - ker keramika ne more kompenzirati tega - lahko tak res "akademski" raztezek kompenzira ustrezno izbrano lepilo. Re: Polaganje ploščic na stik - gt001 - 24.7.2014 pri keramiki je se en hec: razteznostni faktor betonske podlage (estrih) je skoraj 2,5x visji od rf keramike. tako se podlaga razteza se bolj kot same keramicne ploscice, kar seveda vnasa dodatne obremenitve. Re: Polaganje ploščic na stik - papez46 - 24.7.2014 Ja, in zaradi tega so "najcenejša" in toga lepila za keramiko povsem neprimerna za tako početje. Jasno da so in obstajajo - pa še prav preveč jih ni treba iskat - namenu primerna lepila. So pa malo dražja. In seveda, ker je že za keramiko šlo 50€ ali več za m2, je sedaj treba "šparat" pri lepilu. :mrgreen: Potem pa poka in odstopa. :roll: In spet in še enkrat - vsak posamezni del gradnje, je treba vedno in zmeraj gledati kot del neke celote, ki mora na koncu "špilat". 8) |
