Lastniki TČ zrak-voda-poraba el. - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Energijski viri (https://podsvojostreho.net/forum/forumdisplay.php?fid=18) +--- Tema: Lastniki TČ zrak-voda-poraba el. (/showthread.php?tid=18576) Strani:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
Re: Lastniki TČ zrak-voda-poraba el. - bohinc - 28.2.2019 Citat:TT EVT18kW ogreva 200m2 (šteti prostori z 20 kom.raditorji ),og. TČ 949+ STČ 162 = 1111 kWh [url]httpunichr("58")//wwwunichr("46")bohinjunichr("46")eu/template/pages/station/reportMonthlyunichr("46")php?date=2019/2[/url] FEB 2018 : TČ 1394 + STČ 168 = 1562 kWh [url]httpunichr("58")//wwwunichr("46")bohinjunichr("46")eu/template/pages/station/reportMonthlyunichr("46")php?date=2018/2[/url] Vremensko vodenje preklopim (če-ko :mrgreen: se spomnim...) na konstantno ob velikem dnevnem nihanju zun. t. [url]httpunichr("58")//prntscrunichr("46")com/mrixvc[/url] temu primerna ''lestvica t.'' na grafu... Re: Lastniki TČ zrak-voda-poraba el. - Popson31 - 28.2.2019 Lokacija: Strihovec pri Mariboru, 380m nadmorske visine, ogrevanih 205m2 od skupno 240m2, vse talno gretje. Ogreva se na 22stc, notranja T 22-23stc, SV na nazivnih 42, na izhodu bojlerja je cca 44stc. TC: mitsubishi 8kW 3 fazna, SV 300L 3.4m2 kaca Rekuperator: vent vut 350 vb ec Fasada: isospan 9cm eps grafit + 5cm kamena volna Zidovi kleti: 10cm xps Tla proti zemljini: 5-7cm xps + 5cm purenit Mansarda: 30-40cm volna 0.39 Okna: VEKA alphaline 90 troslojna Uw 0.8 Ogrevanje po vremenski krivulji, brez vpliva notranjega korektorja. Poraba po stevcu za ogrevanje in SV za mesec FEBRUAR 550 kWh, TC je pridelala 1815 torej je priblizen COP 3.3. Povprecna zunanja T 4 stc in povprecna Rh 71%. Celotna poraba elektrike za gospodinjstvo in ogrevanje za februar je 805kWh, od tega VT 350kWh in MT 455kWh. Re: Lastniki TČ zrak-voda-poraba el. - Energetik81 - 28.2.2019 Februar poraba komplet TČ kotlovnice (gretje in SV) 525 kWh. Mesečni COP = 3,0. Povprečna mesečna temperatura je bila +3,8°C, povprečna mesečna vlažnost 66%. Lanski februar 783 kWh. Koda: LJ-Barje, 4 osebe, ogrevanje P+M 135m2 na 21,5°; SV povprečno na 43°C + cirkulacija 18/7, Vaillant Arotherm 8kW, elektrika edini energentunichr("46")
Izolacija 15cm EPS, 20cm SF34 v mansardi, 3-slojna okna Uw=1, povsod talno gretje, 7cm EPS pod estrihomunichr("46")Re: Lastniki TČ zrak-voda-poraba el. - xavi - 1.3.2019 Poraba 1.2.-1.3.2019 713 kwh (dvoslojna okna, 8 cm izolacije, 140m2, 22C) Re: Lastniki TČ zrak-voda-poraba el. - janir - 1.3.2019 Kronoterm wpl 13HT Priklopljena 20.4.2018 Porabe; Maj 166kwh Junij 97kwh Julij 78kwh Avgust 64kwh September 120kwh Oktober 424kwh November 890kwh December 1650kwh (od tega SV 118kwh, grelci 50kwh) Januar 1953kwh (od tega SV 120kwh, grelci 152kwh Mansardo grejemo na 22.5 stopinj (termostat oz. kontroler KT1) , v pritličju vseskozi čez 24,5 st.. Sanitarno vodo grejemo na 46 st.(pride do 50). Lokacija;Litija prebiva; 6 odraslih (2 gospodinjstvi -2 tuš in 2 banja) Letnik 1972 k+p+m Leta 2002 nova fasada (10cm stiropor) in v mansardi nova AJM dvoslojna okna 1.1W/M klet in pritličje stara lesena dvoslojna okna klet 4 radiatorji pritličje 8 radiatorjev mansarda 9 radiatorjev (od tega 2 še nadstopje više, kjer sta v špici mansarde še 2 otroški sobi in galerija) grejemo pribl.270 m2, v kleti garaža in kurilnica neogrevani prej smo greli na KO+drva, poraba 1620l+8.5 m3 drv na sezono (povprečje 7 sezon) Februar 1240 kwh (od tega san. voda 103kwh) Re: Lastniki TČ zrak-voda-poraba el. - B0TER - 1.3.2019 Poraba za februar, ogrevanje + sanitarna - 502kWh Lokacija: Logatec okolica, 544mnv TČ Fujitsu WS Komfort 10kW + 200l bojler Ogrevanje imam nastavljeno samo po vremenski krivulji 24/7 na 23°C Hiša P+M 137m2 Pod estrihom v pritličju proti zemljini je skupno 24 cm EPS, nad betonsko ploščo mansarde je na poševnini 30cm, na ravnem delu 40 cm steklene volne. Zidano je z Ytong TB40, zaenkrat še brez fasade. Okna z 3 zasteklitvijo. Po vseh prostorih je položeno talno gretje, drugih virov ogrevanja ni. Spodaj je graf temepratur, ki se zajemajo vsakih 6ur. Re: Lastniki TČ zrak-voda-poraba el. - klunka - 1.3.2019 TČ Alpha innotec LWD 90A (9kw): V hiši 240m2 ogreva se 180m2, vsepovsod radiatorji, gretje nastavljeno na 22.5 stopinj (sobni korektor+ogrevalna krivulja - zunanja temp.), dejanska temperatura prostorov je okoli 23 stopinj. Sanitarna voda je ločena, TČ je samo za gretje. lokacija Krško fasada (12cm stiropor), dvoslojna okna 1.1 W/m2K, v kleti izoliran strop 8 cm stiroporja. Na podstrešju 35cm tervola. Skupaj 12 radiatorjev, po večini predimenzioniranih. Poraba zima 2018/2019: September: 56,9kwh, Oktober: 81,3 kwh, November: 391,6 kwh in pridelanih 1361,2 kwh toplote (COP 3,47)povp.temp 8,16 December: 668,4 kwh in pridelanih 2088,6 kwh toplote (COP 3,12)povp.temp 2,65 Januar: 764,1 kwh in pridelanih 2403,5 kwh toplote (COP 3,14)povp.temp 1,08 Februar: 537,5 kwh in pridelanih 1819 kwh toplote (COP 3,4) Re: Lastniki TČ zrak-voda-poraba el. - JaBK - 1.3.2019 ogrevanje: 308kwh SV: 212kwh Stb: 3kwh SKUPAJ: 522kwh Hiša: K+P+N 235 m2 neto ogrevane površine + 20m2 galerije (600m3 neto prostornine), talno Okolica Kranja, 5 oseb TČ Panasonic Aquarea 5kw + 300L bojler, Prezračevanje Helios KWL EC/ET 500m3, Notranja T = 23 stopinj Elektrika edini energent Re: Lastniki TČ zrak-voda-poraba el. - gt001 - 1.3.2019 02/2019 Celotna poraba elektricne energije (edini vir) 660kWh. Poraba TC (IVT_AX09) za ogrevanje 290kWh Hisa dobra NEH, soncna lega, neto 175m²/505m³ 22°C talno, STC 42-47°C, 3 osebe. Re: Lastniki TČ zrak-voda-poraba el. - JaBK - 1.3.2019 Nisem brala vseh tistih dolgih tem o IVTjki... Ogrevaš samo hišo ali tudi SV? Re: Lastniki TČ zrak-voda-poraba el. - gt001 - 1.3.2019 Samo hiso, SV ogreva STC (se iz casov EB). Re: Lastniki TČ zrak-voda-poraba el. - edid - 1.3.2019 Februar 2019 - hišni števec: 659 kWh (TČ (voda + ogrevanje): 461 kWh, gospodinjstvo: 198 kWh) NEH v okolici Medvod, ogrevano 200/240m2, Fujitsu WS 11kW HP, 4 osebe, 280L bojler, vse na elektriko Re: Lastniki TČ zrak-voda-poraba el. - DMhouse - 1.3.2019 DMhouse Napisal:Zdravo.Poraba za mesec februar 427 kWh od tega 42 kWh za gretje sanitarne vode. Temperatura v hiši 22°C, razen ko jo je sonce segrelo tja do 24°C podnevi
Re: Lastniki TČ zrak-voda-poraba el. - Alien2018 - 1.3.2019 Februar 525 kwh vsa poraba TČ, rekup, gospodinjstvo, vse komplet. 600 m nmv 150 m2 1.4 litrska hisa, 21st, 4 osebe Re: Lastniki TČ zrak-voda-poraba el. - Turbo - 1.3.2019 Lokacija:Mengeš, povprečna zunanja temperatura +2,9°C (2,7°C topleeje kot lani!!). Poraba TČ: 162 kWh v VT in 394 kWh v MT, skupaj 557 kWh (od tega 111 kWh za toplo vodo), oz. 19,9 kWh dnevno. Glede na lansko porabo 31% manj. Način ogrevanja: TČ Fujitsu WS 11 kW , 180m2 talnega gretja ,ogrevanje na 21,5 °C + 300 l bojler (48°C) Tihi način (Low noise) med 21:00 in 24:00, ogrevanje bojlerja v LN, če je zunanja temperatura nad +2°C. Izolacija: opeka 30cm + 16cm EPS, cokel 14cm xps, mansarda 26cm UNIFIT 035, okna PVC dvoslojna 1,1 Še izris povprečnih dnevnih temperatur (rdeča) z lanskimi (rumena) in dnevne porabljene energije (VT=draga tarifa, ker ogrevam toplo vodo v MT=poceni tarifa, je le ta razdeljena na ogrevanje bojlerja in preostala poraba v MT). |
