Lastniki TČ zrak-voda-poraba el. - Print verzija +- PodSvojoStreho.net (https://podsvojostreho.net/forum) +-- Forum: Gradnja in obnova (https://podsvojostreho.net/forum/forumdisplay.php?fid=4) +--- Forum: Energijski viri (https://podsvojostreho.net/forum/forumdisplay.php?fid=18) +--- Tema: Lastniki TČ zrak-voda-poraba el. (/showthread.php?tid=18576) Strani:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
Re: Lastniki TČ zrak-voda-poraba el. - GalloLight - 31.5.2018 April, malce z zamudo. P+N 142 m2 ogrevane površine, talno Lj Vič 4 osebe fasada EPS grafit 20 cm (sever in previs 24 cm), pod AB TP 16 cm XPS, ravna AB streha 15 cm + EPS grafit 26,5 cm + XPS 3 cm TČ Daikin 6 kW 260L 3f, Prezračevanje Zehnder ComfoAir 200 Notranja T = 21,5-23,5 stopinj Elektrika edini energent Re: Lastniki TČ zrak-voda-poraba el. - GalloLight - 31.5.2018 Maj. P+N 142 m2 ogrevane površine, talno Lj Vič 4 osebe fasada EPS grafit 20 cm (sever in previs 24 cm), pod AB TP 16 cm XPS, ravna AB streha 15 cm + EPS grafit 26,5 cm + XPS 3 cm TČ Daikin 6 kW 260L 3f, Prezračevanje Zehnder ComfoAir 200 Notranja T = 21,5-23,5 stopinj Elektrika edini energent Re: Lastniki TČ zrak-voda-poraba el. - Bullet - 31.5.2018 ogreva se 250m2. Klet - 3 prostori v izmeri 40m2, 3 radiatorji, 1 v vsakem prostoru. (nisem upošteval garaže -35m2 in veže+kurilnice -25m2) - prostori niso direktno ogrevani, so cevi od centralne, neizolirane, radiatorjev ni. Pritličje - 105m2 (9 radiatorjev) 1 štuk - 105m2 (7 radiatorjev, talno v kopalnici + lojtra) sanitarna 265L segreta na 47st - sprememba - na 45st Izolacija - podstreha na AB plošči 20cm stiropor, nekaj prostorov v kleti /1 prostor, zunanje stene; in pritličju /3 prostori, zunanje stene - izoliranih iz notranje strani z 2 cm stiroporja Okna pvc, 4-16-4. Lokacija Kranj. TČ - Nibe F2120 - 16 Poraba FEB 2018 - 1930 KWH Poraba MAR 2018 - 1442 KWH Poraba APRIL 2018 - 380 KWH Poraba MAJ 2018 - 57 KWH (ogrevanje izklopljeno 3.5., torej skoraj vsa poraba za SV). Re: Lastniki TČ zrak-voda-poraba el. - Poldee - 31.5.2018 Fujitsu 11 in 10. V maju prva 19, druga 133 kWh. Na letni ravni prva 4320, druga 6622 kWh (+ kubik drv). Very happy :-) Re: Lastniki TČ zrak-voda-poraba el. - Energetik81 - 31.5.2018 V maju poraba samo TČ (samo SV) 125 kWh pri COP=3,2 (400 kWh toplote). Koda: LJ-Barje, 4 osebe, SV na 43°C + cirkulacija 24/7, Vaillant Arotherm 8kW, elektrika edini energentunichr("46")
Izolacija 15cm EPS, 20cm SF34 v mansardi, 3-slojna okna Uw=1, povsod talno gretje, 7cm EPS pod estrihomunichr("46")Re: Lastniki TČ zrak-voda-poraba el. - Energetik81 - 31.5.2018 GalloLight Napisal:Maj.Daj ti malce razloži, kako prideš skozi mesec s ~60kWh toplote za SV? To je tko ene 6x manj kot mi, pa ne bi rekel, da smo nekaj zelo potratni. Zdaj ali imate še kolektorje, ali pa se stuširate vsak z 1 litrom tople vode. Re: Lastniki TČ zrak-voda-poraba el. - pentax - 1.6.2018 Energetik, tole zgoraj pomeni 2kWh/dan...če bi vodo segreval recimo vsak dan kvečjemu tik pred večernimi tuširanji, koliko bi s to energijo uspel segreti 260l bojler kakršnega ima uporabnik? Ravno zato sem kakšen dan nazaj spraševal kdaj sploh porabljate uporabniki toplo vodo razen za kopanje/tuširanje čez dan. Pri nas imamo toplo vodo na voljo 24/7 ampak je res vprašanje koliko se sploh, če se rabi v ostalem delu dneva. Mogoče imajo pri @Gallolightu ta sistem uporabe tople vode uveden doma. Re: Lastniki TČ zrak-voda-poraba el. - jernejk - 1.6.2018 Mi tudi pridemo s 50-60kwh za SV čez mesec. Trije odrasli, tuširanje vsak dan zvečer. Ostalo tople vode skoraj ne rabimo. Re: Lastniki TČ zrak-voda-poraba el. - Fantocci - 1.6.2018 Pri nas gre zadnje dni tam po 1.5kWh na dan. Trije se stuširamo in to je to. Jaz se stuširam skoraj s hladno, ker to navadno naredim po večernem bicikliranju in mi paše, da se malo pohladim. Dobro, da imamo le 200l bojler, 300l bi bil brez veze, v manjšem bojlerju so manjše izgube, pa še pokril sem ga s starimi dekami zgoraj, kjer je temp. najvišja. Cirkulacije ni. Kuhamo pa ne med tednom; če pa je kaj posode, se zalaufa pomivalc (priklopljen na hladno vodo, greje jo sam). Druge porabe tople vode ni. Re: Lastniki TČ zrak-voda-poraba el. - jernejk - 1.6.2018 Enako, tudi pri meni ni cirkulacije, imam pa 200L bojler pravtako. Re: Lastniki TČ zrak-voda-poraba el. - Energetik81 - 1.6.2018 pentax Napisal:Energetik, tole zgoraj pomeni 2kWh/dan...če bi vodo segreval recimo vsak dan kvečjemu tik pred večernimi tuširanji, koliko bi s to energijo uspel segreti 260l bojler kakršnega ima uporabnik?Za 6,6 stopinj. Sicer so samo nazivne izgube 200-300L bojlerja na ravni 2kWh/dan. Tako da Gallolight očitno tople vode sploh ne uporablja. Fantocci Napisal:Kuhamo pa ne med tednom; če pa je kaj posode, se zalaufa pomivalc (priklopljen na hladno vodo, greje jo sam). Druge porabe tople vode ni.Štedilnika/pulta/mize noben ne pomiva? WCji, kopalnice itd, to pomivate z mrzlo vodo ali kako? Re: Lastniki TČ zrak-voda-poraba el. - JaBK - 1.6.2018 druga tema bo za te stvari boljša... In da nisem čisto OT: 119kwh SV in Stb. Re: Lastniki TČ zrak-voda-poraba el. - Fantocci - 1.6.2018 Energetik81 Napisal:Štedilnika/pulta/mize noben ne pomiva? WCji, kopalnice itd, to pomivate z mrzlo vodo ali kako? Štedilnik/pult/miza se obriše z vlažno krpo, včasih celo z namenskimi čistilnimi robci, če je zelo mastno. Tu pa res ne boš nabil neke porabe tople vode. Kot sem že dejal, med tednom se ne kuha doma. Zvečer pa se je sadje, čokolino in take gluposti. Pa SV se ogreva le na 40°C, čemu bi na več, če ni potrebe. Re: Lastniki TČ zrak-voda-poraba el. - Energetik81 - 1.6.2018 Odgovarjam v sosednji temi: <!-- l --><a class="postlink-local" href="http://www.podsvojostreho.net/forum/viewtopic.php?f=7&t=70154&p=869571#p869571">viewtopic.php?f=7&t=70154&p=869571#p869571</a><!-- l --> Re: Lastniki TČ zrak-voda-poraba el. - edid - 1.6.2018 Maj 2018 - hišni števec: 247kWh (TČ (voda + ogrevanje): 48 kWh, gospodinjstvo: 199 kWh) [NEH v okolici Medvod, ogrevano 200/240m2, Fujitsu 11kW HP, 4 osebe, 280L bojler] |
