Attack 25-35 DPX lambda - Print verzija
+--- Tema: Attack 25-35 DPX lambda (/showthread.php?tid=42695)
Re: Attack 25-35 DPX lambda - Hanzi - 2.2.2015
Ne
da
Re: Attack 25-35 DPX lambda - sinko999 - 2.2.2015
atack profi nima podpore na elektroniki niti nima belimotov,
lambda ima dva belimota ki krmilita primarni in sekundarni zrak.
Re: Attack 25-35 DPX lambda - sstad - 3.2.2015
Moj dopis :
Dear !
I inquired about VIGAS boiler, but I have not yet decided. I'll probably
take ATTACK boiler.
I'll have a little look at the boiler.
Do ATTACK 35 DPX LAMBDA boiler do you not sell anymore.
Renovation of the boiler room will be carried out during the summer, so do
not rush to the boiler.
Greetings !
Njihov odgovor :
Dear Mr ,
we understand your decision.
With the Attack Lambda boilers it is bit difficult to get it from factory
for export.
But we do the impossible for You! :-)
We can offer the Attack 35 DPX Lambda for 2837 Eur without VAT.
It is bit more like you see in our webpage, but it is not in our power to
export this boiler in same price.
Producent make support for Slovak residents if you have property in
Slovakia. For that is bit harder to get Attack Lambda to export.
Is it acceptable price for you?
Your order can be concidered ad binding?
Best regards
ZEN-Zelená energia, s.r.o.
Ali je DPX lambda, toliko boljši po izkoristku, kot pa DPX profi, razlika v ceni je kar občutna za 1280eur.
Hvala za odgovore in lep pozdrav !
Re: Attack 25-35 DPX lambda - fab - 3.2.2015
Uuu so pa dvignili cene, sam sem dal pred 2 leti za 25lambda slabih 1900 brez DDV + prevoz 150eur. 35ka je bila se mi zdi 300 eur dražja.
Na njihovi spletni strani je cena za Attack 35 DPX Lambda
naša cena bez DPH: 2 362,03 €
Kar je kar 470eur razlike .
Re: Attack 25-35 DPX lambda - JOHHAN - 3.2.2015
Nekdo bo z "darovanjem" svojega imena za nakup na SK pač zaslužil to razliko!
lp,
JOHHAN
Re: Attack 25-35 DPX lambda - iWAN - 3.2.2015
Eno je zakon ponudbe in povpraševanja, tu ne moreš kaj. Drugo je pa mogoče, da ima že vgrajeno novo elektroniko. Preveri, ali ima kotel že vgrajen "touch panel" ali je še stara varianta na gumbe.
Za info: aprila 2013 sem svojo 35-ko lambda kupil tu:
[url]httpunichr("58")//wwwunichr("46")kotly-kolektoryunichr("46")sk/kotly/splynovacie-kotly/attack-dpx-35-lambda-14-35-kwunichr("46")html[/url] za 2087,12€+ddv in plačal za prevoz še 170€.
Re: Attack 25-35 DPX lambda - Hanzi - 3.2.2015
Jaz sem jo tudi maja 2013 kupil v Zen za približno tvoj znesek Iwan. 120 evrov se lokalnemu prevozniku za dve peči pa sta se znašli 10km od doma
Sicer pa je Johan najbrž kar zadel scenarij. Tudi če se odločiš za varianto od ZEN, dvomim da boš ti naveden kot kupec. Najbrž bo nek Slovak za katerega nisi nikdar slišal. Glede na njihove plače se bi že splačalo kakšne "sodelavce" povprašal po nakupu.
Re: Attack 25-35 DPX lambda - sstad - 4.2.2015
Ali ima kdo ta kotel ATTACK SLX 25 LAMBDA, ima večje kurišče kot DPX
Re: Attack 25-35 DPX lambda - marisol28 - 5.2.2015
Kar se tiče specifikacij za ta SLX, ni kaj, tak vlke nakladalne komore nima noben kotel v tem rangu moči.
Re: Attack 25-35 DPX lambda - Hanzi - 5.2.2015
Glede na to da je pol manjša komora dovolj velika za enkrat dnevno naložit skoraj ne vidim prednosti. Prej slabost če nisi pozoren pri nalaganju in/ali če imaš dvomljivo kurjavo. Namreč že pri pol manjšem volumnu se vžge cel kup in šoba ne podela plina, kaj se zgodi pri 2x večji nalagi raje ne razmišljam (namesto da zakadis celo vas, zakadis celo obcino).
Je pa res da je najbolj enostavno zakurili na konkretni posteljici oglja od prejšnjega kurjenja.
Tisti video na attackovi strani mi je nekam čuden (zakuris najprej drobiž, ga spustiš direkt v dimnik, naložiš drva, potem pa preusmeriš v IK
<!-- m --><a class="postlink" href="http://www.attack.sk/public/media/93170/dpx-slx+cistenieEN.mp4">http://www.attack.sk/public/media/93170 ... enieEN.mp4</a><!-- m -->
Je pa res da so te peči za naše po današnjih standardih izolirane hiše premočne. Jaz upam z mojo 30kw ogrevati vsaj 500m2 objekta. Če imaš večji nakladalni prostor, potem boš rabil še večji zalogovnik. 200l dobrih drv ne spraviš v 2k zalogovnik. Razen ce ga s talnim ohlajas pod 30.
Kdo pri nas sedaj sploh uradno prodaja attack. Na mago ne najdem več attack programa. Frankovic?
Frankovo nima nič napisanega o SLX.
Na Slovaškem pa ga očitno prodaja samo attack direkt. Cena je pa 800 evrov višja od dpx lambda oziroma trikrat višja od profi verzije.
Re: Attack 25-35 DPX lambda - sstad - 10.2.2015
Ali je kdo mogoče kupoval od tega :
<!-- m --><a class="postlink" href="http://www.azslovakia.sk/">http://www.azslovakia.sk/</a><!-- m -->
